1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: cross-compiling v7.0.7
From: Pierrick M Hanlet via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 15 Jun 2023 16:19:13 +0000
Hi Mark,
I do actually have these definitions:
CROSS_COMPILER_TARGET_ARCHS=linux-arm_raspberrypi2
linux-arm_raspberrypi3 linux-arm_raspberrypi4 linux-arm_terasicsoc
linux-arm_achilles linux-x86_64cross linux-x86_i486 linux-ppc_mvme8100
and
CROSS_COMPILER_HOST_ARCHS=linux-x86_64
As mentioned before, if I have CROSS_COMPILER_TARGET_ARCHS empty, then
there is no problem building for the host.
Thank you,
Pierrick
On 6/15/23 10:16, Mark Rivers wrote:
> Hi Pierrick,
> I am cross-compiling with base 7.0.7 (actually master on May 18) and it works fine for me cross-compiling for vxWorks-ppc32.  I just made these changes to configure/CONFIG_SITE:
> diff --git a/configure/CONFIG_SITE b/configure/CONFIG_SITE
> index 03ec6d1..12f5ab1 100644
> --- a/configure/CONFIG_SITE
> +++ b/configure/CONFIG_SITE
> @@ -96,14 +96,14 @@
>   # Which target architectures to cross-compile for.
>   #  Definitions in configure/os/CONFIG_SITE.<host>.Common
>   #  may override this setting.
> -CROSS_COMPILER_TARGET_ARCHS=
> +CROSS_COMPILER_TARGET_ARCHS=vxWorks-ppc32
>   # If only some of your host architectures can compile the
>   #  above CROSS_COMPILER_TARGET_ARCHS specify those host
>   #  architectures here.  If the combination is complicated,
>   #  set CROSS_COMPILER_TARGET_ARCHS in the appropriate
>   #  configure/os/CONFIG_SITE.<host>.Common files instead.
> -CROSS_COMPILER_HOST_ARCHS=
> +CROSS_COMPILER_HOST_ARCHS=linux-x86_64
>   #  The 'runtests', 'tapfiles' and 'junitfiles' make targets normally only run
>   #  self-tests for the EPICS_HOST_ARCH architecture. If the host can execute
> Mark
> -----Original Message-----
> From: Tech-talk <[email protected]> On Behalf Of Pierrick M Hanlet via Tech-talk
> Sent: Thursday, June 15, 2023 6:08 AM
> To: [email protected]
> Subject: cross-compiling v7.0.7
> Greetings all,
> Something broke, or I missed new instructions in building the modules in
> v7.0.7 for cross-compiled platforms.
> I'm building for several platforms.  The host build is fine, but when the cross-compiled platforms start building a new RELEASE.linux-x86_64.local is created with "EPICS_BASE = ", i.e.
> empty.  I did not experience this with
> v7.0.5.
> Cheers,
> Pierrick
> Pierrick Hanlet
> Fermi National Accelerator
> Accelerator Front End Controls
> +1-630-840-5555 -- lab
> +1-312-687-4980 -- mobile
> "Whether you think you can or think you can't, you're right" -- Henry Ford
Pierrick Hanlet
Re: cross-compiling v7.0.7 Mark Rivers via Tech-talk
cross-compiling v7.0.7 Pierrick M Hanlet via Tech-talk
RE: cross-compiling v7.0.7 Mark Rivers via Tech-talk
Prev: Re: cross-compiling v7.0.7 Andrew Johnson via Tech-talk
Next: Re: cross-compiling v7.0.7 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: RE: cross-compiling v7.0.7 Mark Rivers via Tech-talk
