1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: cross-compiling v7.0.7
From: Andrew Johnson via Tech-talk <[email protected]>
To: [email protected]
Date: Thu, 15 Jun 2023 10:49:45 -0500
Hi Pierrick,
On 6/15/23 6:07 AM, Pierrick M Hanlet via Tech-talk wrote:
Something broke, or I missed new instructions in building the modules in
v7.0.7 for cross-compiled platforms.
I'm building for several platforms.  The host build is fine, but when
the cross-compiled platforms start building
a new RELEASE.linux-x86_64.local is created with "EPICS_BASE = ", i.e.
empty.  I did not experience this with
v7.0.5.
Hopefully the fix should be to just delete that file and run 'make' again in that directory, but if you have a more complex local build process (e.g. if you're building on multiple host arch's) that might need some modifications. How were you doing the cross-builds?
Getting the build rules right for generating the modules/RELEASE.<host>.local file was tricky, and there were some changes made to them between 7.0.5 and 7.0.7:
$ git log R7.0.5.. -- configure/RULES_MODULES
commit 098ee6c063c25c3b4483d7d5a0b6c8c6d8d17769
Author: Andrew Johnson <[email protected]>
Date:   Sat Sep 3 10:59:26 2022 -0500
    Oops: Fix to RULES_MODULES
commit efc7cbaf7f93c1bc58f98b30b9d20a27bc0a7f91
Date:   Fri Sep 2 14:10:27 2022 -0500
    Build system fixes related to INSTALL_LOCATION
    * The build can't descend into external submodules when there is no
    configure/RULES_TOP file present in $(INSTALL_LOCATION).
    * Recreate modules/RELEASE.<host>.local if configure/CONFIG_SITE or
    configure/CONFIG_SITE.local have changed.
    * Move the distclean of modules/RELEASE.<host>.local to RULES_TOP
    * Several comment and white-space changes
commit 191ff137f17eecde9e836f0f9aeaec5eecb73b24
Date:   Wed Nov 24 21:58:32 2021 -0600
    configure: Use GNU Make's abspath instead of fullPathname.pl
    Add new INSTALL_ABSOLUTE variable, remove duplicates.
There are some comments at the top of the RULES_MODULES file but they were mostly intended for other applications that want to adopt the submodules scheme (the motor record uses it too).
- Andrew
Complexity is free, it's Simplicity that takes work.
Re: cross-compiling v7.0.7 Pierrick M Hanlet via Tech-talk
Prev: Re: cross-compiling v7.0.7 Pierrick M Hanlet via Tech-talk
Next: Re: cross-compiling v7.0.7 Pierrick M Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: cross-compiling v7.0.7 Simon Rose via Tech-talk
