You need to edit stream/configure/RELEASE and set the correct paths to EPICS_BASE, ASYN, etc.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Brandon Gunn via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, June 15, 2023 1:59 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Issue installing StreamDevice on CentOS 7
Hello,
When I run make from ~/EPICS/support/stream/StreamDevice, I get these errors:
$ make
configure/CONFIG:18: /usr/local/epics/base-7.0.3/configure/CONFIG: No such file or directory
Makefile:33: /usr/local/epics/base-7.0.3/configure/RULES_TOP: No such file or directory
make: *** No rule to make target `/usr/local/epics/base-7.0.3/configure/RULES_TOP'. Stop.
Am I supposed to have an epics directory in /usr/local? I am unsure if this is an issue with setting paths correctly or an issue with my epics base install as I do not seem to see anything with the directory structure .../epics/base-7.0.3/...
Thank you,
Brandon
- Re: Issue installing StreamDevice on CentOS 7 Brandon Gunn via Tech-talk
- Issue installing StreamDevice on CentOS 7 Brandon Gunn via Tech-talk
Re: cross-compiling v7.0.7 Andrew Johnson via Tech-talk
Re: Issue installing StreamDevice on CentOS 7 Lang, Keenan C. via Tech-talk
<2023>
<2023>
ANJ, 15 Jun 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
