1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Issue installing StreamDevice on CentOS 7
From: "Lang, Keenan C. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Gunn, Brandon E." <[email protected]>
Date: Thu, 15 Jun 2023 19:09:41 +0000
Hello Brandon,
EPICS modules are made aware about the location of other files they must include or link against through the use of the configure/RELEASE file. In StreamDevice, the configure/RELEASE file has the following line:
EPICS_BASE=/usr/local/epics/base-7.0.3
Thus, when you build, the module will try to find certain makefile rules, config files, headers, and libraries it needs in /usr/local/epics/base-7.0.3
When you are adding in a new module, you have to edit the configure/RELEASE file to match up the named macros with the locations where epics-base or the given modules are located on your system.
Keenan
From: Tech-talk <[email protected]> on behalf of Brandon Gunn via Tech-talk <[email protected]>
Sent: Thursday, June 15, 2023 1:59 PM
To: [email protected] <[email protected]>
Subject: Issue installing StreamDevice on CentOS 7
Hello,
I am encountering an issue when attempting to install StreamDevice on our CentOS 7.9.2009 machine using this tutorial (step 7): https://epics-controls.org/resources-and-support/documents/getting-started/
When I run make from ~/EPICS/support/stream/StreamDevice, I get these errors:
$ make
configure/CONFIG:18: /usr/local/epics/base-7.0.3/configure/CONFIG: No such file or directory
Makefile:33: /usr/local/epics/base-7.0.3/configure/RULES_TOP: No such file or directory
make: *** No rule to make target `/usr/local/epics/base-7.0.3/configure/RULES_TOP'.  Stop.
Am I supposed to have an epics directory in /usr/local? I am unsure if this is an issue with setting paths correctly or an issue with my epics base install as I do not seem to see anything with the directory structure .../epics/base-7.0.3/...
Thank you,
Brandon
Re: Issue installing StreamDevice on CentOS 7 Han Lee via Tech-talk
Re: Issue installing StreamDevice on CentOS 7 Zimoch Dirk via Tech-talk
Issue installing StreamDevice on CentOS 7 Brandon Gunn via Tech-talk
Prev: Re: Issue installing StreamDevice on CentOS 7 Mark Rivers via Tech-talk
Next: Re: cross-compiling v7.0.7 Pierrick M Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Issue installing StreamDevice on CentOS 7 Brandon Gunn via Tech-talk
Next: Re: Issue installing StreamDevice on CentOS 7 Han Lee via Tech-talk
