1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Issue installing StreamDevice on CentOS 7
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 16 Jun 2023 09:32:13 +0200
FWIW:
If you have multiple support modules that need to be compiled as a set, instead of going into each module and setting RELEASE (and maybe CONFIG_SITE) in their .../configure directories, you can create a single file RELEASE.local (and maybe CONFIG_SITE.local) outside of your modules in the directory directly above.
These two files will be read by all support modules underneath - which means you can configure a whole bunch of modules from a single place. (Being outside the modules, these files also don't interfere with the modules' version control.)
Cheers,
~Ralph
ps. Sorry about user-contributed documentation not being up-to-date. Adding is only the first step...
That's why attending the Documentathon 2023 is important!
Reading the manual is easy. Maintaining it needs your help!
Issue installing StreamDevice on CentOS 7 Brandon Gunn via Tech-talk
Re: Issue installing StreamDevice on CentOS 7 Lang, Keenan C. via Tech-talk
Re: Issue installing StreamDevice on CentOS 7 Han Lee via Tech-talk
Re: Issue installing StreamDevice on CentOS 7 Brandon Gunn via Tech-talk
Prev: Sequenzer repository not available Jörn Dreyer via Tech-talk
Next: Re: Issue installing StreamDevice on CentOS 7 Zimoch Dirk via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Issue installing StreamDevice on CentOS 7 Brandon Gunn via Tech-talk
