1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Looking for idiomatic/maintainable pattern for ai/ao record unit conversion
From: Érico Nogueira Rolim via Tech-talk <[email protected]>
To: tech-talk <[email protected]>
Date: Tue, 27 Jun 2023 21:02:40 +0000
Hi!
I'm looking into using the ASLO and ROFF fields in my ai and ao records.
These records are used for current and voltage values which are in ADC
and DAC counts, and which I'd like to convert to amperes and volts.
Our setup for current (voltage is equivalent) has the following
structure (SP and RB are setpoint and readback, respectively):
Current-SP (ao) -> CurrentConvSP (calcout) -> CurrentRaw-SP (longout and
asynInt32) -> hardware
and
hardware -> CurrentRaw-RB (longin and asynInt32) -> Current-RB (ai)
CurrentConvSP is necessary because, as I understood it, the calc and
calcout records don't have device support. It and Current-RB use another
two PVs in their calculations: CurrGain (conversion factor between
amperes and ADC counts) and CurrOffset (raw current measured when
current is zero).
My intended structure using the ASLO and ROFF fields was:
Current-SP.VAL (ao and asynInt32) -> Current-SP.RVAL -> hardware
and
hardware -> Current-RB.RVAL -> Current-RB.VAL (ai and asynInt32)
My initial attempt at using ASLO and ROFF was with database links to
CurrGain and CurrOffset, which didn't work. It seems the record only
really expects numeric values there. I have worked around this so far by
turning CurrGain and CurrOffset into dfanout records, but this requires
that whenever I add a new record that uses some current information from
the hardware, I update the dfanout outputs. It doesn`t seem scalable and
feels like a mistake would be easy to miss.
These values, especially CurrOffset, can be configured in the field, so
it isn't enough to define a variable for them when reading the template.
*Is there some alternative I`m missing for propagating the values I'd
like to have in all ASLO and ROFF fields?*
On top of that, my IOC has two types of users:
- operators and high level scripts, who use current in amperes
- experts, who use currents in amperes and in hardware units
The experts require being able to control the hardware using hardware
units, and I expected this to be supported by writing into the RVAL
field, but it isn't (caput writes, succeeds, and the value doesn't
change). I had to change my setpoint chain to the one below, to work
around this:
Current-SP (ao and Raw Soft Channel) -> CurrentRaw-SP (longout and
It is still better than the previous version, since the math and input
links don't have to be copied for each new record every time and we have
one fewer record, but being able to write into Current-SP.RVAL seems
like it would be the ideal solution. It would even have the advantage of
supporting updating VAL for the new RVAL, which would work around the
issue we currently face (with the new or old scheme) of writes into raw
setpoints not being propagated to normal setpoints.
*Are writes into RVAL supposed to work / going to work in the future, or
should I stick to the intermediary record, or is there some better way?*
Cheers and thank you for the help,
Érico
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Prev: RE: [External] Re: Strangeness in ai/mbbiDirect with StreamDevice on PINI Leblanc, Gregory via Tech-talk
Next: RE: [EXTERNAL] Re: starting IOC with systemd Leblanc, Gregory via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Display custom TCP data in CS-Studio Ralph Lange via Tech-talk
Next: Use phoebus toggle to adjust sign for ao record? Leblanc, Gregory via Tech-talk
