1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Use phoebus toggle to adjust sign for ao record?
From: "Leblanc, Gregory via Tech-talk" <[email protected]>
Date: Tue, 27 Jun 2023 21:38:35 +0000
Hi folks,
One of my next steps is to get polarity reversal working on the Heinzinger supplies.  I've got the attached bob file where I am hoping to use the slider to tune the beam. The PCUs want me to send a negative value to indicate one polarity and a positive value to indicate the opposite polarity.  The command 'DA 0,025000' will run the supply to 25A.  The command 'DA 0,-025000' will reverse the polarity switch and run the supply to 25A (the software on the supply takes care of running everything down before switching).  I would prefer not to have a slider that goes from -300 to 300.  This makes it harder to run the supply down to 0 and is also more confusing for operators.  My thought is to implement a toggle button and display which deflection the user has selected.  I think I can then add a CALC record to set the sign of the number as positive or negative, and then send that composite out to the instrument.  Does it sound like I'm on the right track or feedback on how you've accomplished something like this?
     Greg
Gregory Leblanc
Accelerator Engineer
Edwards Accelerator Lab - Ohio University
123 University Terrace
Athens, OH 45701 USA
[email protected]
M: (401) 52-OUAL1 or (401) 526-8251
Attachment: Analyzer_Magnet.bob
Description: Analyzer_Magnet.bob
Prev: RE: [EXTERNAL] Re: starting IOC with systemd Leblanc, Gregory via Tech-talk
Next: Question about fetching history data from MySQL by using phoebus neu lzf via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Looking for idiomatic/maintainable pattern for ai/ao record unit conversion Érico Nogueira Rolim via Tech-talk
Next: RE: [External] Re: Use phoebus toggle to adjust sign for ao record? Leblanc, Gregory via Tech-talk
