Hi Kay,
Thanks for your reply.
I try to use binary SNS version
of Phoebus and I checked the product/lib folder and found that the file mysql-connector-java-8.0.30.jar
is present.
However, both problems are still exists when I run "sh phoebus.sh":
the connection issue: Cannot connect to jdbc://mysql://192.168.1.230/archive as root
Caused by: java.sql.SQLException: No suitable driver found for jdbc:mysql://192.168.1.230/archive
The user name "root" and password are the same as CSS, which is successful to connect to MySQL.
Is that the issue?
Thanks you very much in advance.
Sent: 28 June 2023 13:09
To: neu lzf <lzfneu at live.com>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Re: Question about fetching history data from MySQL by using phoebus
> org.csstudio.trends.databrowser3/urls=jdbc:mysql://192.168.1.230/archive
> org.csstudio.trends.databrowser3/archives=jdbc:mysql://192.168.1.230/archive
If there was a connection issue, you’d see an error like
Cannot connect to jdbc:mysql://192.168.1.230/archive
“No suitable driver found” suggests that your product simply doesn’t include the MySQL library.
In your_product/lib, there should be a file mysql-connector-java-8.0.30.jar
Is that not present?
Try a binary like the one from
https://controlssoftware.sns.ornl.gov/css_phoebus/ which should include it.
-Kay
- RE: Question about fetching history data from MySQL by using phoebus CAOUEN Loic via Tech-talk
- Question about fetching history data from MySQL by using phoebus neu lzf via Tech-talk
- Re: Question about fetching history data from MySQL by using phoebus Kasemir, Kay via Tech-talk
Senior Controls Engineer Position at Sigray Ernesto Paiser via Tech-talk
<2023>
2025
Re: [EXTERNAL] Re: Question about fetching history data from MySQL by using phoebus Han Lee via Tech-talk
<2023>
2025
ANJ, 29 Jun 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
