I can see you’re using a “LAN IP” (192.168.1.230)
Does it mean Phoebus and Mysql are not on the same server ?
If it’s the case, did you grant the privileges in mysql ?
You must allow the connection from the server where your phoebus runs.
GRANT ALL PRIVILEGES ON *.* TO 'root'@'your_phoebus_server_ip' IDENTIFIED BY 'your_root_password'
Regards
De : Tech-talk <tech-talk-bounces at aps.anl.gov>
De la part de neu lzf via Tech-talk
Envoyé : jeudi 29 juin 2023 05:10
À : Kasemir, Kay <kasemirk at ornl.gov>
Cc : tech-talk at aps.anl.gov
Objet : Re: Question about fetching history data from MySQL by using phoebus
I try to use binary SNS version
of Phoebus and I checked the product/lib folder and found that the file mysql-connector-java-8.0.30.jar is present.
However, both problems are still exists when I run "sh phoebus.sh":
the connection issue: Cannot connect to jdbc://mysql://192.168.1.230/archive as root
Caused by: java.sql.SQLException: No suitable driver found for jdbc:mysql://192.168.1.230/archive
The user name "root" and password are the same as CSS, which is successful to connect to MySQL.
Thanks you very much in advance.
org.csstudio.trends.databrowser3/urls=jdbc:mysql://192.168.1.230/archive
org.csstudio.trends.databrowser3/archives=jdbc:mysql://192.168.1.230/archive
If there was a connection issue, you’d see an error like
Cannot connect to jdbc:mysql://192.168.1.230/archive
“No suitable driver found”
suggests that your product simply doesn’t include the MySQL library.
In your_product/lib, there should be a file mysql-connector-java-8.0.30.jar
Is that not present?
Try a binary like the one from
https://controlssoftware.sns.ornl.gov/css_phoebus/ which should include it.
-Kay
- Re: Question about fetching history data from MySQL by using phoebus Kasemir, Kay via Tech-talk
- Question about fetching history data from MySQL by using phoebus neu lzf via Tech-talk
- Re: Question about fetching history data from MySQL by using phoebus neu lzf via Tech-talk
<2023>
<2023>
ANJ, 29 Jun 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
