1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Question about fetching history data from MySQL by using phoebus
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: neu lzf <[email protected]>
Date: Thu, 29 Jun 2023 17:40:57 +0000
> I try to use binary SNS version of Phoebus and I checked the product/lib folder and found that the file mysql-connector-java-8.0.30.jar is present.
Right, should look something like this :
/jdk/…
/lib/…
/lib/product-sns-4.7.3-SNAPSHOT/lib/mysql-connector-java-8.0.30.jar
When you start it, it’s using the jdk/… that’s included in the download, so the menu Help, About shows java version 17, which should work with that mysql jar file.
When I then try to read data from say jdbc:mysql://localhost/archive, that either works, or it fails with a meaningful error message because there is a connection issue (network, no MySQL running, …) like this :
WARNING [org.csstudio.trends.databrowser3] No archived data for xxx
java.lang.Exception: Cannot connect to jdbc:mysql://localhost/archive as archive
Caused by: com.mysql.cj.jdbc.exceptions.CommunicationsException: Communications link failure
What you see is this :
  1. the connection issue: Cannot connect to jdbc://mysql://192.168.1.230/archive as root
  2. Caused by: java.sql.SQLException: No suitable driver found for jdbc:mysql://192.168.1.230/archive
Check the exact connection string. You mention both
and
The correct syntax is something like jdbc:mysql://localhost/archive
If I try jdbc://mysql://localhost/archive then the extra // indeed turns it into something that’s not recognized as a MySQL connection string, and then “no suitable driver” makes sense for an error.
Re: Question about fetching history data from MySQL by using phoebus neu lzf via Tech-talk
Re: Question about fetching history data from MySQL by using phoebus Kasemir, Kay via Tech-talk
RE: Question about fetching history data from MySQL by using phoebus CAOUEN Loic via Tech-talk
Prev: RE: Question about fetching history data from MySQL by using phoebus CAOUEN Loic via Tech-talk
Next: RE: [External] Re: Use phoebus toggle to adjust sign for ao record? Leblanc, Gregory via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: Question about fetching history data from MySQL by using phoebus neu lzf via Tech-talk
