1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: Issue with streamdevice and I/o Intr
From: Florian Feldbauer via Tech-talk <tech-talk at aps.anl.gov>
To: Zimoch Dirk <dirk.zimoch at psi.ch>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 4 Jul 2023 11:09:59 +0200
Hey Dirk,
thanks for the detailed explanation.
I worked with StreamDevice and I/O intr a lot before, but always with the asynSerialPort as lower level driver.
Just to be clear: Let's assume my input record with "I/O Intr" is the only record reading on the bus, do I need to create a polling on the bus myself or does StreamDevice internally create a polling thread?
Thx for the advice with the eomReason, I changed my driver accordingly.
My protocol and record now look like this:
Terminator = '';
recv {
  MaxInput = 4;
  in  0x07 $1 "%r";
record( longin, "CAN${N}:TEST:R" ) {
  field( DTYP, "stream" )
  field( SCAN, "I/O Intr" )
  field( INP,  "@can.proto recv(0x00) ${port}" )
The first two bytes contain the 11bit CAN arbitration ID followed by the up to 8 data bytes. We have one device that sends 32bit floats via CAN bus, which is why we use the raw format, so we can parse those values later with the %R format converter.
My IOC has 2 CAN interfaces and I was trying to send a frame from can0 to can1 or vise versa.
Here is the complete log from Stream:
epics> dbpf CAN0:TEST:W 21
2023/07/04 11:03:07.127321 _main_ StreamEpics.cc:908: Stream::process(CAN0:TEST:W) 2023/07/04 11:03:07.127508 _main_ StreamEpics.cc:934: Stream::process(CAN0:TEST:W) start 2023/07/04 11:03:07.127628 _main_ StreamCore.cc:429: StreamCore::startProtocol(CAN0:TEST:W, startMode=StartNormal) 2023/07/04 11:03:07.127725 _main_ StreamCore.cc:564: StreamCore::evalCommand(CAN0:TEST:W): activeCommand = out 2023/07/04 11:03:07.127828 _main_ StreamCore.cc:689: StreamCore::formatOutput(CAN0:TEST:W): format = %.2r 2023/07/04 11:03:07.127945 _main_ StreamEpics.cc:1173: Stream::formatValue(CAN0:TEST:W, format=%r, fieldaddr=(nil) 2023/07/04 11:03:07.128054 _main_ StreamEpics.cc:1298: Stream::formatValue(CAN0:TEST:W) format=%r type=DBF_LONG 2023/07/04 11:03:07.128166 _main_ StreamEpics.cc:693: streamPrintf(CAN0:TEST:W,format=%r) 2023/07/04 11:03:07.128284 _main_ StreamCore.cc:777: StreamCore::printValue(CAN0:TEST:W, %r, 21 = 0x15): "<07><00><00><15>" 2023/07/04 11:03:07.128402 _main_ StreamCore.cc:612: StreamCore::evalOut: outputLine = "<07><00><00><15>" 2023/07/04 11:03:07.128503 _main_ StreamCore.cc:623: StreamCore::evalOut(CAN0:TEST:W): lockRequest(5000) 2023/07/04 11:03:07.128599 _main_ AsynDriverInterface.cc:549: AsynDriverInterface::lockRequest(CAN0:TEST:W, 5000 msec) 2023/07/04 11:03:07.128739 _main_ StreamEpics.cc:948: Stream::process(CAN0:TEST:W): protocol started 2023/07/04 11:03:07.128794 can0 AsynDriverInterface.cc:590: AsynDriverInterface::lockHandler(CAN0:TEST:W)
DBF_LONG:           21 = 0x15
2023/07/04 11:03:07.129004 can0 StreamCore.cc:832: StreamCore::lockCallback(CAN0:TEST:W, StreamIoSuccess) 2023/07/04 11:03:07.129122 can0 AsynDriverInterface.cc:627: AsynDriverInterface::writeRequest(CAN0:TEST:W, "<07><00><00><15>", 300 msec) epics> 2023/07/04 11:03:07.129265 can0 AsynDriverInterface.cc:649: AsynDriverInterface::writeHandler(CAN0:TEST:W) 2023/07/04 11:03:07.129375 can0 AsynDriverInterface.cc:667: AsynDriverInterface::writeHandler(CAN0:TEST:W): reading old input
2023/07/04 11:03:07.130 can0: wrote 4 bytes to can0, return asynSuccess
2023/07/04 11:03:07.129714 can0 AsynDriverInterface.cc:715: AsynDriverInterface::writeHandler(CAN0:TEST:W): write(..., "<07><00><00><15>", outputSize=4, written=4) [timeout=0.3 sec] = asynSuccess 2023/07/04 11:03:07.129844 can0 StreamCore.cc:877: StreamCore::writeCallback(CAN0:TEST:W, StreamIoSuccess) 2023/07/04 11:03:07.129948 can0 StreamCore.cc:564: StreamCore::evalCommand(CAN0:TEST:W): activeCommand = end 2023/07/04 11:03:07.130403 can0 StreamCore.cc:465: StreamCore::finishProtocol(CAN0:TEST:W, Success) bus owner 2023/07/04 11:03:07.130508 can0 AsynDriverInterface.cc:610: AsynDriverInterface::unlock(CAN0:TEST:W) 2023/07/04 11:03:07.130606 can0 AsynDriverInterface.cc:1468: AsynDriverInterface::finish(CAN0:TEST:W) start 2023/07/04 11:03:07.130697 can0 AsynDriverInterface.cc:1478: AsynDriverInterface::finish(CAN0:TEST:W) done 2023/07/04 11:03:07.130792 can0 StreamEpics.cc:1034: Stream::protocolFinishHook(CAN0:TEST:W, Success) 2023/07/04 11:03:07.130967 cbLow StreamEpics.cc:1112: recordProcessCallback(CAN0:TEST:W) processing record 2023/07/04 11:03:07.131135 cbLow StreamEpics.cc:908: Stream::process(CAN0:TEST:W) 2023/07/04 11:03:07.131230 cbLow StreamEpics.cc:922: Stream::process(CAN0:TEST:W) ready. don't convert 2023/07/04 11:03:07.131344 cbLow StreamEpics.cc:1116: recordProcessCallback(CAN0:TEST:W) processing record done
2023/07/04 11:03:07.484 can1: read 5 bytes from can1, return asynSuccess
2023/07/04 11:03:07.483786 can1 AsynDriverInterface.cc:951: AsynDriverInterface::readHandler(CAN1:TEST:R): ioAction=AsyncRead read(4 bytes, timeout=0 sec) returned status asynSuccess: received=5 bytes, eomReason=END, buffer="<07><00><00><15><00>" 2023/07/04 11:03:07.483917 can1 AsynDriverInterface.cc:977: AsynDriverInterface::readHandler(CAN1:TEST:R): AsyncRead poll: received 5 of 4 bytes "<07><00><00><15><00>" eomReason=END [data ignored] 2023/07/04 11:03:07.484024 can1 AsynDriverInterface.cc:1123: AsynDriverInterface::readHandler(CAN1:TEST:R) readMore=-1 bytesToRead=63 2023/07/04 11:03:07.484160 can1 AsynDriverInterface.cc:951: AsynDriverInterface::readHandler(CAN1:TEST:R): ioAction=AsyncRead read(63 bytes, timeout=0.5 sec) returned status asynTimeout: received=0 bytes, eomReason=NONE, buffer="" 2023/07/04 11:03:07.484273 can1 AsynDriverInterface.cc:1051: AsynDriverInterface::readHandler(CAN1:TEST:R): ioAction=AsyncRead, timeout [0.5 sec] after 0 of 63 bytes "" 2023/07/04 11:03:07.484397 can1 StreamCore.cc:963: StreamCore::readCallback(CAN1:TEST:R, StreamIoTimeout input="", size=0) 2023/07/04 11:03:07.484504 can1 StreamCore.cc:1015: StreamCore::readCallback(CAN1:TEST:R) inputBuffer="", size 0 2023/07/04 11:03:07.484806 can1 StreamCore.cc:1108: StreamCore::readCallback(CAN1:TEST:R) async timeout: just restart 2023/07/04 11:03:07.484975 can1 AsynDriverInterface.cc:806: AsynDriverInterface::readRequest(CAN1:TEST:R, 500 msec reply, 500 msec read, expect 4 bytes, async=yes) 2023/07/04 11:03:07.485125 can1 AsynDriverInterface.cc:831: AsynDriverInterface::readRequest CAN1:TEST:R: queueRequest(..., priority=0, queueTimeout=-1 sec) = asynSuccess [async=true]
Setting eomReason to ASYN_EOM_END seems to attach a 0 to the received data, but it still should match the %r format converter.
Cheres,
Florian
On 7/4/23 10:45, Zimoch Dirk wrote:
Hi Florian,
For "I/O Intr" records, StreamDevice uses intrCallbackOctet but still needs to
poll the device, because despite its name, intrCallbackOctet does not deliver
any data asynchronously when nobody reads synchronously. The "I/O Intr" records
receives ALL input, regardless of the active reader, which may be the record
itself, some other StreamDevice Record or even non-StreamDevice records or any
other software calling asynOctet->read on that port.
Thus, to avoid receiving the data twice, in case the intrCallbackOctet receiver
is the polling record, StreamDevice discards the input received with the polled
read and only uses the input received with intrCallbackOctet.
As ALL "I/O Intr" StreamDevice records receive ALL input, they all match the
input against their 'in' commands. Only those records  which could match the
input successfully are processed. All others silently ignore the input!
The intrCallbackOctet input log messages should show up in the logs BEFORE the
message form the polled read (because asyn calls the interrupt callbacks before
returning from read). What do you have in the logs right before the first line
you posted? Anything from AsynDriverInterface::asynReadHandler() and
StreamCore::readCallback()?
As StreamDevice did not receive a termination signal, it assumes there may be
more input and tries to read it. But that results in a timeout, which is then
interpreted as a termination signal, because no InTerminator is used.
This is probably not what you want. If the message never exceeds one CAN frame,
set eomReason to ASYN_EOM_END. This avoids wasting time on another read attempt.
If you may have messages that span multiple frames and have a method to find out
when this is the case in your driver, do that. Otherwise waiting for timeout (or
InTerminator or maxInput) is in fact the only way.
Now the question is why the input is rejected. Hard to say without knowing your
protocol. What do you have in your 'in' command?
Dirk
On Tue, 2023-07-04 at 09:05 +0200, Florian Feldbauer via Tech-talk wrote:
Hey all,
we have some devices controlled via CAN bus.
Since CAN bus is based on the transmission of 1-8 bytes, I wrote an
AsynPortDriver with an asynOctet interface as lower level driver.
I wanted to use StreamDevice as higher level driver defining the actual
payload data that is tranmitted between our PC and the devices.
Sending and receiving messages in principal works, but I have an issue
with I/O Interrupts and I don't know why.
Setting the streamDebug variable to 1, I see the following output from
StreamDevice:
2023/07/04 08:54:44.301618 can1 AsynDriverInterface.cc:951:
read(63 bytes, timeout=0 sec) returned status asynSuccess: received=4
bytes, eomReason=NONE, buffer="<07><00><00><ea>"
2023/07/04 08:54:44.301765 can1 AsynDriverInterface.cc:977:
4 of 63 bytes "<07><00><00><ea>" eomReason=NONE [data ignored]
2023/07/04 08:54:44.301889 can1 AsynDriverInterface.cc:1123:
2023/07/04 08:54:44.302015 can1 AsynDriverInterface.cc:951:
2023/07/04 08:54:44.302140 can1 AsynDriverInterface.cc:1051:
2023/07/04 08:54:44.302262 can1 StreamCore.cc:963:
2023/07/04 08:54:44.302378 can1 StreamCore.cc:1015:
2023/07/04 08:54:44.302490 can1 StreamCore.cc:1067:
StreamCore::readCallback(CAN1:TEST:R) end flag received
2023/07/04 08:54:44.302605 can1 StreamCore.cc:1127:
StreamCore::readCallback(CAN1:TEST:R) input line: ""
2023/07/04 08:54:44.302726 can1 StreamCore.cc:1151:
StreamCore::readCallback(CAN1:TEST:R) async match failure: just restart
2023/07/04 08:54:44.302847 can1 AsynDriverInterface.cc:806:
read, expect 0 bytes, async=yes)
2023/07/04 08:54:44.302964 can1 AsynDriverInterface.cc:831:
The readHandler reads the message from the bus but ignores it. According
to the comments in the code it is ignored because the asyncReadHandler
should also receive this message and handle the I/O interrupt, but it
seems the Interrupt callback is not executed.
Any idea why the callbacks don't work?
I'm using
base 7.0.6.1
stream 2.8.24
asyn (current HEAD on master branch)
Cheers,
Florian
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Re: Issue with streamdevice and I/o Intr Zimoch Dirk via Tech-talk
Issue with streamdevice and I/o Intr Florian Feldbauer via Tech-talk
Prev: Re: Issue with streamdevice and I/o Intr Zimoch Dirk via Tech-talk
Next: RE : VME configuration : mrfioc2-master version in the new vme-evg-300, vme-evr-300 environment 이민균 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Next: Re: Issue with streamdevice and I/o Intr Zimoch Dirk via Tech-talk
ANJ, 04 Jul 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
