1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Dynamic limits in alarms
From: Eusebio Naif Al-Soliman Fuentes via Tech-talk <[email protected]>
To: tech-talk <[email protected]>
Date: Wed, 05 Jul 2023 20:46:02 +0200
Thank you very much Rolf.
Now it's working perfectly :)
Saludos/Best regards
University of Granada
MSc. Data Science and Computer Engineering
[email protected]
El 2023-07-05 20:21, Rolf Keitel escribió:
Hi Eusebio,
the fields HIGH and LOW are scalar fields, not link fields, therefore they cannot solicit values from other records, but they can be set by output links from other records. With proper scanning added, the following should work
record(ao, "alarm_lim_dynamic:Low")
    field(DESC, "Test")
    field(PINI, "YES")
    field(OUT, "temperature.oil.LOW")
record(ao, "alarm_lim_dynamic:High")
    field(DESC, "Test")
    field(PINI, "YES")
    field(OUT, "temperature:oil.HIGH")
record(ai, "temperature:oil")
    field(DESC, "Oil temperature in the engine")
    field(HSV, "MINOR")
    field(LSV, "MINOR")
HTH - rolf -
On 2023-07-05 11:08 a.m., Eusebio Naif Al-Soliman Fuentes via Tech-talk wrote:
    field(DESC, "Test")
    field(PINI, "YES")
    field(DESC, "Test")
    field(PINI, "YES")
    field(HIGH, "alarm_lim_dynamic:High.VAL")
    field(LOW, "alarm_lim_dynamic:Low.VAL")
    field(HSV, "MINOR")
    field(LSV, "MINOR")
Dynamic limits in alarms Eusebio Naif Al-Soliman Fuentes via Tech-talk
Re: Dynamic limits in alarms Rolf Keitel via Tech-talk
Prev: Re: [EXTERNAL] phoebus Tank widget: Limits from PV? Kasemir, Kay via Tech-talk
Next: Re: [EXTERNAL] phoebus Tank widget: Limits from PV? Paul Sichta via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Dynamic limits in alarms Rolf Keitel via Tech-talk
Next: Sequencer usage/Is sequencer repo still down? Marco A. Barra Montevechi Filho via Tech-talk
