I have a Linux IOC connecting to a PXIe chassis. The IOC is triggered by
a PXI EVR at 50 Hz. About 300 records are processed every 20 ms.
Sometimes the IOC misses the trigger.
When I analyze the IOC overhead using `perf`, I find that the usage of
getTimeStamp function from mrfioc2 is very high (see below). Then I use
`perf annotate` to check getTimeStamp() and I find the CPU is waiting
for below instructions. So I think the main reason is that the reading
time from EVR takes too long.
https://github.com/epics-modules/mrfioc2/blob/master/evrMrmApp/src/drvem.cpp#L801-L818
// Get current absolute time
epicsUInt32 ctrl=READ32(base, Control);
// Latch timestamp
WRITE32(base, Control, ctrl|Control_tsltch);
ts.secPastEpoch=READ32(base, TSSecLatch);
ts.nsec=READ32(base, TSEvtLatch);
epicsUInt32 ctrl2=READ32(base, Control);
As a General Time Provider, the EVR has the highest priority, it is
nature that every record calls getTimeStamp() to read timestamp from EVR.
Is such pciread latency normal? How to solve it? Or should I increase
the OS Clock priority to avoid calling getTimeStamp()?
Cheers,
Di WANG
KEK
epics> generalTimeReport
Backwards time errors prevented 0 times.
Current Time Providers:
"EVR", priority = 50
Current Time is 2023-07-06 19:28:39.738546.
"OS Clock", priority = 999
Current Time is 2023-07-06 19:28:39.738719.
Event Time Providers:
# perf report
overhead Command Shared Object Symbol
45.26% cbLow libevrMrm.so.2.3 [.] EVRMRM::getTimeStamp
11.60% CAS-event libevrMrm.so.2.3 [.] EVRMRM::getTimeStamp
3.32% cbHigh libevrMrm.so.2.3 [.] mrmBufRx::drainbuf
2.26% cbHigh libevrMrm.so.2.3 [.] EVRMRM::getTimeStamp
1.85% cbLow libc.so.6 [.]
__memmove_avx_unaligned_erms
1.76% CAS-UDP libevrMrm.so.2.3 [.] EVRMRM::getTimeStamp
1.28% CAS-event [kernel.kallsyms] [k]
syscall_return_via_sysret
1.00% CAS-event [kernel.kallsyms] [k]
entry_SYSCALL_64_after_hwframe
Samples: 95K of event 'cycles', 4000 Hz, Event count (approx.): 84846615925
/home/acc/epics/R3.15.9/modules/mrfioc2-2.3.0/lib/linux-x86_64/libevrMrm.so.2.3
[Percent: local period]
0.00 │ → callq EVRMRM::convertTS@plt
0.00 │ mov %eax,%r13d
│ test %al,%al
│ ↓ je 90
0.02 │ mov 0x8(%rsp),%rax
0.01 │ mov %rax,(%r12)
│ ↓ jmp 93
│ nop
│90: xor %r13d,%r13d
│93: mov %r14,%rdi
│ → callq epicsMutex::unlock@plt
0.00 │ add $0x10,%rsp
│ mov %r13d,%eax
0.01 │ pop %rbx
0.00 │ pop %rbp
0.01 │ pop %r12
│ pop %r13
│ pop %r14
│ ← retq
│ nop
│b0: mov 0xe8(%rbp),%rax
24.10 │ mov 0x4(%rax),%ebx
0.04 │ mov %ebx,%edx
0.00 │ or $0x4,%dh
0.01 │ mov %edx,0x4(%rax)
26.23 │ mov 0x68(%rax),%edx
0.08 │ mov %edx,0x8(%rsp)
25.25 │ mov 0x6c(%rax),%edx
0.06 │ mov %edx,0xc(%rsp)
24.03 │ mov 0x4(%rax),%edx
0.03 │ cmp %ebx,%edx
- Re: issue of getTimeStamp from EVR Timo Korhonen via Tech-talk
- Re: issue of getTimeStamp from EVR Shen, Guobao via Tech-talk
- Re: issue of getTimeStamp from EVR Michael Davidsaver via Tech-talk
Re: [EXTERNAL] phoebus Tank widget: Limits from PV? Jure Varlec via Tech-talk
Re: Error in alarm-logger.sh Giovanni Savarese LNL via Tech-talk
<2023>
Re: interrupt read data in int32Driver example Mark Rivers via Tech-talk
<2023>
