Your response is greatly appreciated and has been very helpful. Thank you. However, I still want to know how to simulate interrupt reads through software in the official int32Driver example.
The EPICS simulation mode can be used to do that - this is implemented in the database, so it works for all records, not just for those using the ASYN framework.
Cheers, ~Ralph
- interrupt read data in int32Driver example timesir via Tech-talk
- RE: interrupt read data in int32Driver example GAGET Alexis via Tech-talk
- Re: interrupt read data in int32Driver example timesir via Tech-talk
Re: Record process when restore using autosave Ralph Lange via Tech-talk
Macro max size is 256 TZVETKOV Stephane via Tech-talk
<2023>
2025
Re: interrupt read data in int32Driver example Mark Rivers via Tech-talk
<2023>
2025
ANJ, 07 Jul 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
