On Fri, 7 Jul 2023 at 03:54, 吴煊 via Tech-talk <tech-talk at aps.anl.gov> wrote:
When you're doing an autosave restore procedure as part of the IOC boot, the restore will not process records. It will just be as if the restored values were in your database files. When you do the restore while the IOC is up, restoring a value to a record will in most cases process the record immediately. For your case, you need to add the processing-after-reboot as part of your database. A single fanout or seq record with PINI=YES setting will be processed at reboot. From that record you can link to all the records that need to be processed. By doing this, you have full control over the order of processing and the single initial PINI=YES record makes sure the processing chain happens exactly once, when the IOC is coming up. Cheers, ~Ralph
ANJ, 09 Jul 2023 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
