1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Macro max size is 256
From: Andrew Johnson via Tech-talk <[email protected]>
To: TZVETKOV Stephane <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 7 Jul 2023 10:47:19 -0500
Hi Stéphane,
On 7/7/23 4:49 AM, TZVETKOV Stephane via Tech-talk wrote:
I somehow found out that the associated NORD field was always limited to 256, and that my string was always cropped to 256 characters. It took me some time to actually understand that the limitation was that an EPICS macro has a maximum size of 256 characters.
(by the way, I also discovered that the name of a macro is also limited to 256 characters)
In order to work around this limitation, I just recompiled the EPICS base with a minor modification in `modules/libcom/src/macLib/macLib.h`. E.g., changing the maximum size from 256 to 65535:
vi modules/libcom/src/macLib/macLib.h
     ~ > #define MAC_SIZE 65535
As far as I have tested, this modification didn't seem to cause any problem. But, I wonder if more experienced EPICS developers have comments about this. Maybe increasing macro size has side effects that I didn't anticipated. Maybe there is a cleaner/better way to do this.
I'm not aware of any unwanted side-effects of doing that, the macLib code uses that setting internally, and the API ensures the code always knows the capacity of any buffer it's writing into so it won't overrun external buffers.
However I don't think using 65535 there would allow for that size of string values in the database as there are some other places in the code that still use smaller fixed-size buffers, for example:
1. The modules/database/src/ioc/dbStatic/dbLexRoutines.c code that parses and loads .db and .dbd files uses fixed-size 1024-byte buffers (change MY_BUFFER_SIZE in that file).
2. The msi program uses 4096-byte buffers, you'd need to change MAX_BUFFER_SIZE in modules/database/src/ioc/dbtemplate/msi.cpp to increase them if you use msi to expand substitution files with large strings.
3. The lexical scanners generated by flex seem to use 8192 and 16384 byte buffers by default, thus the largest string that the .db file parser can read might be a few characters less than one of those two sizes.
There might be some other places too, if you try fixing the ones above please let us know any more that you come across — it would be good to at least document where our code limits the string sizes, and the idea of unifying them all could be interesting.
HTH,
- Andrew
Complexity is free, it's Simplicity that takes work.
Macro max size is 256 TZVETKOV Stephane via Tech-talk
Prev: Re: issue of getTimeStamp from EVR Ralph Lange via Tech-talk
Next: Re: Sequencer usage/Is sequencer repo still down? Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Macro max size is 256 TZVETKOV Stephane via Tech-talk
Next: changing compiler versions Pierrick M Hanlet via Tech-talk
