On Fri, 7 Jul 2023 at 17:17, Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov> wrote:
I second that. For the ITER fast controllers, we found that going to the PXIe timing card to read the timestamp is too slow and adds a lot of jitter. Instead, we're running a PTP daemon that synchronizes the system clock to PTP. This is conceptually similar to what ntpd or chronyd are doing, but PTP allows for a better synchronization. Result: - EPICS just reads the system clock and gets a precise, low-jitter time stamp using a fast call. - IOCs on fast controllers and virtualized not-so-fast hosts run exactly the same code. It's the system clock below that is better on a fast controller with PTP. Cheers, ~Ralph
ANJ, 07 Jul 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
