1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Question on Accessing Data in Custom PV Structures
From: "Srinivas, Dhruv via Tech-talk" <[email protected]>
Date: Fri, 7 Jul 2023 21:03:19 +0000
To whom it may concern,
I’m attempting to create custom PVStructures which contain differing normative types. At the moment, I’ve created the below code in an IOC which creates a PV Structure with 2 NTScalars and 1 NTScalarArray.
record(ai, "rec:X") {
               field(VAL, "20")
               field(HIGH, "30")
               field(HSV, "MINOR")
               info(Q:group, {
                              "CustomDataStructure": {
                                             "X_Scalar": {
                                                            +channel:"VAL"
record(ai, "rec:Y") {
               field(VAL, "40")
               info(Q:group, {
                                             "Y_Scalar": {
                                                            +type:"scalar",
                                                            +channel:"VAL",
                                                            +id:"MyTestingPVA2PVA",
record(aai, "input_this") {
               field(NELM, "4")
               field(FTVL, "INT64")
               field(INP, "[1,2,3,4]")
               info(Q:group, {
                                             "Z_Aray": {
                                                            +channel:"VAL"
At the moment, this does create the PV Structure, and I can access it through “pvget”. However I’m unsure if this is the right way to do this. Can someone with more experience with Epics v7 correct me if so? Also, I’m not sure how to go about accessing parts of “CustomDataStructure”. Namely how would I go about accessing the value for Y_Scalar through CustomDataStructure?
I’ve also copied the output of pvget below. I apologize for the lengthy post, but I thought it was best to provide as much context as possible.
  • pvget CustomDataStructure
CustomDataStructure MyTestingPVA2PVA
    structure record
        structure _options
            uint queueSize 0
            boolean atomic true
    epics:nt/NTScalar:1.0 X_Scalar
        double value 20
        alarm_t alarm
            int severity 0
            int status 2
            string message UDF
        structure timeStamp
            long secondsPastEpoch 631152000
            int nanoseconds 0
            int userTag 0
        structure display
            double limitLow 0
            double limitHigh 0
            string description
            string units
            int precision 0
            enum_t form (0) Default
                int index 0
                string[] choices [Default, String, Binary, Decimal, Hex, Exponential, Engineering]
        control_t control
            double limitLow 0
            double limitHigh 0
            double minStep 0
        valueAlarm_t valueAlarm
            boolean active false
            double lowAlarmLimit nan
            double lowWarningLimit nan
            double highWarningLimit 30
            double highAlarmLimit nan
            int lowAlarmSeverity 0
            int lowWarningSeverity 0
            int highWarningSeverity 0
            int highAlarmSeverity 0
            byte hysteresis 0
    epics:nt/NTScalar:1.0 Y_Scalar
        double value 40
        alarm_t alarm
            int severity 0
            int status 2
            string message UDF
        structure timeStamp
            int nanoseconds 0
            int userTag 0
        structure display
            double limitLow 0
            double limitHigh 0
            string description
            string units
            int precision 0
                int index 0
        control_t control
            double limitLow 0
            double limitHigh 0
            double minStep 0
            double highWarningLimit nan
            byte hysteresis 0
    epics:nt/NTScalarArray:1.0 Z_Scalar
        long[] value [1,2,3,4]
        alarm_t alarm INVALID DRIVER UDF
            int severity 3
            int status 2
            string message UDF
        structure timeStamp
            int nanoseconds 0
            int userTag 0
        structure display
            double limitLow 0
            double limitHigh 0
            string description
            string units
            int precision 0
                int index 0
        control_t control
            double limitLow 0
            double limitHigh 0
            double minStep 0
            byte hysteresis 0
Sincerely,
Dhruv Srinivas
[email protected]
Re: Question on Accessing Data in Custom PV Structures Michael Davidsaver via Tech-talk
Prev: Re: External: changing compiler versions Niko Kivel via Tech-talk
Next: Re: External: changing compiler versions Pierrick M Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: External: changing compiler versions Pierrick M Hanlet via Tech-talk
Next: Re: Question on Accessing Data in Custom PV Structures Michael Davidsaver via Tech-talk
