1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Question on Accessing Data in Custom PV Structures
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Srinivas, Dhruv" <[email protected]>
Date: Sat, 8 Jul 2023 18:05:21 -0700
On 7/7/23 14:03, Srinivas, Dhruv via Tech-talk wrote:
To whom it may concern,
I’m attempting to create custom PVStructures which contain differing normative types. At the moment, I’ve created the below code in an IOC which creates a PV Structure with 2 NTScalars and 1 NTScalarArray.
Can you say something about what you are trying to accomplish,
and what kind of client(s) will consume this data structure?
record(ai, "rec:X") {
                field(VAL, "20")
                field(HIGH, "30")
                field(HSV, "MINOR")
                info(Q:group, {
                               "CustomDataStructure": {
                                              "X_Scalar": {
                                                             +channel:"VAL"
record(ai, "rec:Y") {
                field(VAL, "40")
                info(Q:group, {
                                              "Y_Scalar": {
                                                             +type:"scalar",
                                                             +channel:"VAL",
                                                             +id:"MyTestingPVA2PVA",
record(aai, "input_this") {
                field(NELM, "4")
                field(FTVL, "INT64")
                field(INP, "[1,2,3,4]")
                info(Q:group, {
                                              "Z_Aray": {
                                                             +channel:"VAL"
At the moment, this does create the PV Structure, and I can access it through “pvget”. However I’m unsure if this is the right way to do this. Can someone with more experience with Epics v7 correct me if so? Also, I’m not sure how to go about accessing parts of “CustomDataStructure”. Namely how would I go about accessing the value for Y_Scalar through CustomDataStructure?
I’ve also copied the output of pvget below. I apologize for the lengthy post, but I thought it was best to provide as much context as possible.
  * pvget CustomDataStructure
CustomDataStructure MyTestingPVA2PVA
     structure record
         structure _options
             uint queueSize 0
             boolean atomic true
     epics:nt/NTScalar:1.0 X_Scalar
         double value 20
         alarm_t alarm
             int severity 0
             int status 2
             string message UDF
         structure timeStamp
             long secondsPastEpoch 631152000
             int nanoseconds 0
             int userTag 0
         structure display
             double limitLow 0
             double limitHigh 0
             string description
             string units
             int precision 0
             enum_t form (0) Default
                 int index 0
                 string[] choices [Default, String, Binary, Decimal, Hex, Exponential, Engineering]
         control_t control
             double limitLow 0
             double limitHigh 0
             double minStep 0
         valueAlarm_t valueAlarm
             boolean active false
             double lowAlarmLimit nan
             double lowWarningLimit nan
             double highWarningLimit 30
             double highAlarmLimit nan
             int lowAlarmSeverity 0
             int lowWarningSeverity 0
             int highWarningSeverity 0
             int highAlarmSeverity 0
             byte hysteresis 0
     epics:nt/NTScalar:1.0 Y_Scalar
         double value 40
         alarm_t alarm
             int severity 0
             int status 2
             string message UDF
         structure timeStamp
             int nanoseconds 0
             int userTag 0
         structure display
             double limitLow 0
             double limitHigh 0
             string description
             string units
             int precision 0
                 int index 0
         control_t control
             double limitLow 0
             double limitHigh 0
             double minStep 0
             double highWarningLimit nan
             byte hysteresis 0
     epics:nt/NTScalarArray:1.0 Z_Scalar
         long[] value [1,2,3,4]
         alarm_t alarm INVALID DRIVER UDF
             int severity 3
             int status 2
             string message UDF
         structure timeStamp
             int nanoseconds 0
             int userTag 0
         structure display
             double limitLow 0
             double limitHigh 0
             string description
             string units
             int precision 0
                 int index 0
         control_t control
             double limitLow 0
             double limitHigh 0
             double minStep 0
             byte hysteresis 0
Sincerely,
Dhruv Srinivas
[email protected] <mailto:[email protected]>
RE: Question on Accessing Data in Custom PV Structures Srinivas, Dhruv via Tech-talk
Prev: Re: Sequencer usage/Is sequencer repo still down? Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Re: Record process when restore using autosave 吴煊 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Question on Accessing Data in Custom PV Structures Srinivas, Dhruv via Tech-talk
Next: RE: Question on Accessing Data in Custom PV Structures Srinivas, Dhruv via Tech-talk
