1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: A question on modbus
To: "tech-talk" <[email protected]>
Date: Tue, 11 Jul 2023 16:03:55 +0800
Hello everyone,
I am using a device with Modbus-RTU protocol. The communication data is transmitted in hexadecimal words.
I want to use the modbus module in epics to solve this problelm.
When reading device data, the follwing sentence is used in the .cmd file:
drvModbusAsynConfigure("V1","Power", 1,3,0,1,0,1000, "Power")
and in the substitution file:
file "../../db/ai.template" { pattern
{P,         R,      PORT,               OFFSET, BITS,  EGUL,  EGUF,   PREC,   SCAN}
{power:,    V_read,   V1,   0,      16,    0.,   655.35,     2,      "I/O Intr"}
There is another command to open the device, which should write " \x01 \x05 \x00 \x00 \xFF \x00  \x8C \x3A" to the device.
Command
01
05
00
00
FF
00
8C
3A
Address
Function code
Register address 0
Data 0
CRC
Reply
Be same with command
After reading all the examples I still don't know how to send this command with modbus module correctly. I think I didn't understand them clearly.
Would you like to give me some advice?  Is it suitable to use modbus module?  How to realize it?
Thank you very much.
with my best wishes,
Kevin
RE: A question on modbus Mark Rivers via Tech-talk
Prev: Re: [EXTERNAL] Re: EPICS Software Supply Chain Risk Management (SSCRM) Evans, Richard K. (GRC-H000) via Tech-talk
Next: Re: Question on Accessing Data in Custom PV Structures Timo Korhonen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: [EXTERNAL] Re: EPICS Software Supply Chain Risk Management (SSCRM) Jonathan Jacky via Tech-talk
Next: RE: A question on modbus Mark Rivers via Tech-talk
