1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Xspress3 INP error
To: tech-talk <[email protected]>
Date: Thu, 13 Jul 2023 11:57:19 +0800 (CST)
    I met teo question when using xspress of git. https://github.com/epics-modules/xspress3/tree/master/xspress3App/Db
    Could someone give me advice.
    I use ioc_1Channel  st.md,  OS was Rocky 9.0
*************************Error 1***************
Record "XSP3_1Chan:C1:DeadTime_RBV" does not have a field "INP"
Error at or before ")" in path "/home/xspress3/epics/xspress3/db"  file "xspress3ChannelDeadtime.template" line 12
Record "XSP3_1Chan:C1:DTFactor_RBV" does not have a field "INP"
Error#MCAs: create StdArray for Visualization:
NDStdArraysConfigure("MCA1", 5, 0, "CHAN1", 0, 0)
***** xspress3ChannelDeadtime.template *****
# percent deadtime = allevent*event width + time in reset
record(ao, "$(P)C$(CHAN):DeadTime_RBV") {
    field(DTYP, "asynFloat64")
    field(INP,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))XSP3_CHAN_DTPERCENT")   #  line 12
    field(VAL,  "0")
    field(PREC, "5")
I don't know how to solve it.
****************** Error 2 *******************************
## EPICS R7.0.3.1
## EPICS Base built Jun 26 2023
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
XSP3_1Chan:C1:DeadTime_RBV devAsynFloat64::initCommon invalid INST_IO Must be asyn(<port> <addr> <timeout>)userParams
Error (514,514) PV: XSP3_1Chan:C1:DeadTime_RBV ao: init_record
XSP3_1Chan:C1:DTFactor_RBV devAsynFloat64::initCommon invalid INST_IO Must be asyn(<port> <addr> <timeout>)userParams
Error (514,514) PV: XSP3_1Chan:C1:DTFactor_RBV ao: init_record
*** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
Lynn
RE: Xspress3 INP error Mark Rivers via Tech-talk
Re: Xspress3 INP error Matt Newville via Tech-talk
Prev: =?gb18030?b?u9i4tKO6UkU6IEEgcXVlc3Rpb24gb24gbW9kYnVz?= =?gb18030?b?QW1iZXI=?= via Tech-talk
Next: How to reset encoder counts after controller power off 岳宗仰 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Suspended thread Andrew Johnson via Tech-talk
Next: RE: Xspress3 INP error Mark Rivers via Tech-talk
