1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: IOC using Sequencer Module Attempting to use libCom.so.3.18.1
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Srinivas, Dhruv" <[email protected]>
Cc: "Wang, Andrew" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 18 Jul 2023 09:22:16 -0700
On 7/18/23 09:03, Srinivas, Dhruv via Tech-talk wrote:
To whom it may concern,
I’ve been having some unexpected issues when trying to make an IOC that uses EPICS-seq (sequencer version 2.2.9). From what I’ve been able to determine, I am adding the .st files to the Makefile in the src directory correctly. In that they’re being added in the following format: IOCName_SRCS += someFile.st
I have also verified that I’m adding the seq and pv libraries as follows: IOCName_LIBS += seq pv
Additionally, looking at the error messages I’m getting, it seems that the IOC isn’t properly building the .st files into the .c files. When I run it, I receive a few error messages that are as follows:
/filepathTosnc/snc: error while loading shared libraries: libCom.so.3.18.1: cannot open shared object file: No such file or directory
make[3]: *** No rule to make target ‘someFile.o', needed by IOCName.  Stop.
I believe I know why I’m receiving these errors. I have libCom.so.3.22.1 on my machine, so I think that the sequencer isn’t properly building the .st files. Additionally, if I manually compile the .st files into .c files, and adjust the Makefile, I am able to build the IOC. I was wondering if someone knew why this was the case, as well as what could be done to allow it to build properly using .st files directly.
You need to clean and rebuild (at least) SEQSNC.
A likely scenario is that epics-base, and perhaps other modules,
were updated without rebuilding all dependent modules.
Sincerely,
Dhruv Srinivas
[email protected] <mailto:[email protected]>
RE: IOC using Sequencer Module Attempting to use libCom.so.3.18.1 Srinivas, Dhruv via Tech-talk
RE: IOC using Sequencer Module Attempting to use libCom.so.3.18.1 Mark Rivers via Tech-talk
Prev: IOC using Sequencer Module Attempting to use libCom.so.3.18.1 Srinivas, Dhruv via Tech-talk
Next: Re: PHAS and PINI Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: RE: IOC using Sequencer Module Attempting to use libCom.so.3.18.1 Srinivas, Dhruv via Tech-talk
