You should also check that configure/RELEASE is pointing to the correct version of EPICS base in both SNCSEQ and in your IOC application directory.
-----Original Message-----
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Michael Davidsaver via Tech-talk
Sent: Tuesday, July 18, 2023 11:22 AM
To: Srinivas, Dhruv <srinivas1 at llnl.gov>
Cc: Wang, Andrew <wang126 at llnl.gov>; tech-talk at aps.anl.gov
Subject: Re: IOC using Sequencer Module Attempting to use libCom.so.3.18.1
On 7/18/23 09:03, Srinivas, Dhruv via Tech-talk wrote:
> To whom it may concern,
> I’ve been having some unexpected issues when trying to make an IOC
> that uses EPICS-seq (sequencer version 2.2.9). From what I’ve been
> able to determine, I am adding the .st files to the Makefile in the
> src directory correctly. In that they’re being added in the following
> format: IOCName_SRCS += someFile.st
> I have also verified that I’m adding the seq and pv libraries as
> follows: IOCName_LIBS += seq pv
> Additionally, looking at the error messages I’m getting, it seems that the IOC isn’t properly building the .st files into the .c files. When I run it, I receive a few error messages that are as follows:
> /filepathTosnc/snc: error while loading shared libraries:
> libCom.so.3.18.1: cannot open shared object file: No such file or
> directory
> make[3]: *** No rule to make target ‘someFile.o', needed by IOCName. Stop.
> I believe I know why I’m receiving these errors. I have libCom.so.3.22.1 on my machine, so I think that the sequencer isn’t properly building the .st files. Additionally, if I manually compile the .st files into .c files, and adjust the Makefile, I am able to build the IOC. I was wondering if someone knew why this was the case, as well as what could be done to allow it to build properly using .st files directly.
You need to clean and rebuild (at least) SEQSNC.
A likely scenario is that epics-base, and perhaps other modules, were updated without rebuilding all dependent modules.
> Sincerely,
> Dhruv Srinivas
> srinivas1 at llnl.gov <mailto:srinivas1 at llnl.gov>
- IOC using Sequencer Module Attempting to use libCom.so.3.18.1 Srinivas, Dhruv via Tech-talk
- Re: IOC using Sequencer Module Attempting to use libCom.so.3.18.1 Michael Davidsaver via Tech-talk
Re: IOC using Sequencer Module Attempting to use libCom.so.3.18.1 Johnson, Andrew N. via Tech-talk
Re: PHAS and PINI Michael Davidsaver via Tech-talk
<2023>
RE: IOC using Sequencer Module Attempting to use libCom.so.3.18.1 Srinivas, Dhruv via Tech-talk
<2023>
