1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Process aSub record on arrival of data
To: Talk EPICS Tech <[email protected]>
Date: Thu, 27 Jul 2023 08:33:47 -1000
Hi folks,
I have 2 aSub records: Tx on IOC  A and Rx on IOC B.
IOC A and B are on different machines on my network.
I want Tx to send an array to Rx over CA (or PVA). Once the data arrives is there a stock method to trigger Rx to process? IIUC, using the CPP attribute in Tx.OUTA will not cause the Rx to process since these records are on different IOC's. I'm using another OUT link in Tx to write to Rx.PROC.
Is that the most efficient way to do this?
I know there's history to this and the genSub record at Gemini has been customized to process on the arrival of data to certain input fields. I'm trying to accomplish that in an aSub.
Example below
EPICS 7 latest build from github.
Linux Rocky 8
Thanks!
-Matt
===========IOC A==============
 record(aSub,"test:TX") {
       field(SNAM,"transmitter")
       field(NOVA, "5")
       field(OUTA, "test:RX.A NPP NMS")
       field(OUTB, "test:RX.PROC NPP NMS")
===========IOC B==============
record(aSub,"test:RX") {
      field(NOA, "5")
Re: Process aSub record on arrival of data Andrew Johnson via Tech-talk
Prev: Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus Charles Merrill Jenkins via Tech-talk
Next: Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus Charles Merrill Jenkins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: Re: Process aSub record on arrival of data Andrew Johnson via Tech-talk
