1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Epics7
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 3 Aug 2023 11:42:15 +0200
On Thu, 3 Aug 2023 at 11:07, Liridon Deda via Tech-talk <[email protected]> wrote:
I have a working Epics7 installation on a Windows machine with Anaconda installed and tried to build pyDevSup as module, but didn't succeed so far. I also tried it on an Ubuntu machine, and there it works fine. First, I had some issues that numpy from the Anaconda installation was not found, but this is solved. No, I get the following output:
gmake -C O.windows-x64-static -f ../Makefile TOP=../.. \
    T_A=windows-x64-static install
gmake[2]: Entering directory 'C:/opt/epics/modules/pyDevSup/archApp/O.windows-x64-static'
'[' is not recognized as an internal or external command,
operable program or batch file.
'install' is not recognized as an internal or external command,
gmake[2]: *** [../../configure/RULES_PY:10: ../../python39/windows-x64-static/bplreport.py] Error 1
That looks like a line break in a Make rule inside RULES_PY might not be properly escaped for whatever shell you are using on Windows?
Cheers,
~Ralph
Epics7 Liridon Deda via Tech-talk
Prev: Epics7 Liridon Deda via Tech-talk
Next: Re: xspress3 Realtime not arrived when set 100s Matt Newville via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: Re: Epics7 (pyDevSup) Michael Davidsaver via Tech-talk
