On 8/3/23 02:06, Liridon Deda via Tech-talk wrote:
I have a working Epics7 installation on a Windows machine with Anaconda installed and tried to build pyDevSup as module, but didn't succeed so far. I also tried it on an Ubuntu machine, and there it works fine. First, I had some issues that numpy from the Anaconda installation was not found, but this is solved. No, I get the following output:
In short, the pyDevSup module does not current support windows.
I don't think it would be too difficult to add. Mainly an
exercise in Makefile mechanics.
https://github.com/mdavidsaver/pyDevSup/issues/31
Some work was done on this at the last codeathon by myself
and Peter Heesterman. However, this remains incomplete.
(so further/alternate PRs would be welcomed)
https://github.com/mdavidsaver/pyDevSup/pull/32
(base) C:\opt\epics\modules\pyDevSup>gmake
gmake -C ./configure install
gmake[1]: Entering directory 'C:/opt/epics/modules/pyDevSup/configure'
perl -CSD C:/opt/epics/base/bin/windows-x64-static/makeMakefile.pl O.windows-x64-static ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
gmake -C O.windows-x64-static -f ../Makefile TOP=../.. \
T_A=windows-x64-static install
gmake[2]: Entering directory 'C:/opt/epics/modules/pyDevSup/configure/O.windows-x64-static'
perl -CSD C:/opt/epics/base/bin/windows-x64-static/convertRelease.pl checkRelease
C:\ProgramData\Anaconda3\python.exe ../../makehelper.py os/CONFIG_PY.Common.windows-x64-static
"Installing config file ../../configure/os/CONFIG_PY.Common.windows-x64-static"
gmake[2]: Leaving directory 'C:/opt/epics/modules/pyDevSup/configure/O.windows-x64-static'
gmake[1]: Leaving directory 'C:/opt/epics/modules/pyDevSup/configure'
gmake -C ./archApp install
gmake[1]: Entering directory 'C:/opt/epics/modules/pyDevSup/archApp'
gmake[2]: Entering directory 'C:/opt/epics/modules/pyDevSup/archApp/O.windows-x64-static'
'[' is not recognized as an internal or external command,
operable program or batch file.
'install' is not recognized as an internal or external command,
gmake[2]: *** [../../configure/RULES_PY:10: ../../python39/windows-x64-static/bplreport.py] Error 1
gmake[2]: Leaving directory 'C:/opt/epics/modules/pyDevSup/archApp/O.windows-x64-static'
gmake[1]: *** [/opt/epics/base/configure/RULES_ARCHS:58: install.windows-x64-static] Error 2
gmake[1]: Leaving directory 'C:/opt/epics/modules/pyDevSup/archApp'
gmake: *** [/opt/epics/base/configure/RULES_DIRS:85: archApp.install] Error 2
Does anyone have an Idea what could be the problem and how can I fix it.
Thanks a lot
Liridon
- Epics7 Liridon Deda via Tech-talk
Re: archiver appliance - PVs not reconnecting Hu, Yong via Tech-talk
problem reading data from PLC Abhishek Dutta via Tech-talk
<2023>
2025
2026
Re: Epics7 Ralph Lange via Tech-talk
archiver appliance - PVs not reconnecting Pierrick M Hanlet via Tech-talk
<2023>
2025
2026
