1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: Using opencv with areaDetector
From: William Smith via Tech-talk <tech-talk at aps.anl.gov>
To: "Mark Rivers" <rivers at cars.uchicago.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 08 Aug 2023 15:11:21 +0200
Title: Re: Using opencv with areaDetector
make -C /opt/epics/areaDetector/ADSimDetector install
make[1]: Entering directory '/opt/epics/areaDetector/ADSimDetector'
make -C ./configure install
make[2]: Entering directory '/opt/epics/areaDetector/ADSimDetector/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
T_A=linux-x86_64 install
make[3]: Entering directory '/opt/epics/areaDetector/ADSimDetector/configure/O.linux-x86_64'
perl -CSD /opt/epics/epics-base/bin/linux-x86_64/convertRelease.pl checkRelease
make[3]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/configure/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/configure'
make -C ./simDetectorApp install
make[2]: Entering directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp'
make -C ./src install
make[3]: Entering directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/src'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[4]: Entering directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/src/O.linux-x86_64'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/src/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/src'
make -C ./Db install
make[3]: Entering directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/Db'
make[4]: Entering directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/Db/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/Db/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/Db'
make -C ./op install
make[3]: Entering directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/op'
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/op'
make[2]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp'
make -C ./iocs install
make[2]: Entering directory '/opt/epics/areaDetector/ADSimDetector/iocs'
make -C ./simDetectorNoIOC install
make[3]: Entering directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC'
make[4]: Entering directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/configure'
make[5]: Entering directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/configure/O.linux-x86_64'
make[5]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/configure/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/configure'
make -C ./simDetectorNoIOCApp install
make[4]: Entering directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp'
make[5]: Entering directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src'
make[6]: Entering directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src/O.linux-x86_64'
make[6]: *** No rule to make target '../../../lib/linux-x86_64/libopencv_core.a', needed by 'simDetectorNoIOCApp'. Stop.
make[6]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src/O.linux-x86_64'
make[5]: *** [/opt/epics/epics-base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[5]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src'
make[4]: *** [/opt/epics/epics-base/configure/RULES_DIRS:85: src.install] Error 2
make[4]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp'
make[3]: *** [/opt/epics/epics-base/configure/RULES_DIRS:85: simDetectorNoIOCApp.install] Error 2
make[3]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC'
make[2]: *** [/opt/epics/epics-base/configure/RULES_DIRS:85: simDetectorNoIOC.install] Error 2
make[2]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs'
make[1]: *** [/opt/epics/epics-base/configure/RULES_DIRS:85: iocs.install] Error 2
make[1]: Leaving directory '/opt/epics/areaDetector/ADSimDetector'
make: *** [/opt/epics/epics-base/configure/RULES_DIRS:85: /opt/epics/areaDetector/ADSimDetector.install] Error 2
--------------------Original message--------------------
Sent: Tuesday, August 8, 2023 13:31
To: William Smith <william.smith at helmholtz-berlin.de>
Cc: tech-talk at aps.anl.gov
Send the complete link line that fails.
Sent from my iPhone
On Aug 8, 2023, at 5:17 AM, William Smith via Tech-talk <tech-talk at aps.anl.gov> wrote:
Dear Tech-Talk,
I am trying to use opencv with areaDetector. To start, I have been trying to build with the ADPluginEdge plugin
I am using ubuntu 20.04
I have pulled AD 3-12-1
I have installed opencv using the package manager. sudo apt install libopencv-dev
I have checked that the commonDriverMakefile in ADCore contains ifdef ADPLUGINBAR....
I have checked that in CONFIG_SITE.local.linux-x86_64 the following is set
WITH_OPENCV = YES
OPENCV_EXTERNAL = YES
I had to add the include directory because opencv 4.2.0 includes are under /usr/includes/opencv4
OPENCV = /usr
OPENCV_LIB = $(OPENCV)/lib
OPENCV_INCLUDE = -I$(OPENCV)/include/opencv4
ADSupport, ADCore and ADPluginEdge build without errors. Then when I try to build an example IOC using ADSimDetector I get the following error:
No rule to make target '../../../lib/linux-x86_64/libopencv_core.a', needed by 'simDetectorApp'
It feels like it isn't looking in the EXTERNAL location like I tell it to. Have I missed something? Does anyone have a suggestion?
Will
Prev: Re: Using opencv with areaDetector Mark Rivers via Tech-talk
Next: Re: Using opencv with areaDetector William Smith via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
ANJ, 08 Aug 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
