Dear Vlad,
Your symptom and workaround sounds as if IR:something:GM10:channels
and IR:something:T1 are located in different IOCs.
Could you check if they are located in the same IOC?
If they are in different IOCs you may have to specify .PROC field in
the FLNK field , as described in the EPICS Application Developer’s
Guide, 5.12.3 FWDLINK :
https://epics.anl.gov/base/R3-15/6-docs/AppDevGuide/DatabaseLockingScanningAndProcessing.html#x6-2000005.12.3
best regards,
Shuei
Shuei Yamada,
High Energy Accelerator Research Organization (KEK)
mailto:shuei at post.kek.jp
- netDev "channels" record type problem Владимир Сергейчик via Tech-talk
- Re: netDev "channels" record type problem Shuei YAMADA via Tech-talk
- Re: netDev "channels" record type problem Владимир Сергейчик via Tech-talk
Re: [EXTERNAL] Scripts in Phoebus Florian Feldbauer via Tech-talk
Re: Using opencv with areaDetector William Smith via Tech-talk
<2023>
problem reading data from PLC S7NODAVE Abhishek Dutta via Tech-talk
<2023>
