Hi Mark,
I'll check the firmware version tomorrow. Yes, the vendor firmware works on Windows with the USB interface. Beyond making sure it could be pinged, I don't know if it was tested with vendor software with ethernet interface.
I looked more closely at the log file and I see this:
DanteConfig("DANTE1", 172.16.0.120, 6, 0, 0)
Dante::Dante library version=3.7.19.0
Dante::Dante ipAddress added to query=172.16.0.120
Dante::Dante number of devices=0
Dante::Dante error calling get_ids
And in particular, number of devices=0. Isn't that set in the DanteConfig line to be 6?
Pete.
Sent: Saturday, August 12, 2023 8:59 PM
To: Siddons, David <siddons at bnl.gov>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Re: Dante-1-1
Hi Pete,
What firmware is your unit running?
Does the vendor software work OK?
I’ll be back from vacation on Monday.
Sent from my iPhone
On Aug 12, 2023, at 9:09 AM, Siddons, David via Tech-talk <tech-talk at aps.anl.gov> wrote:
We have an 8-channel Dante system from XG labs. It has 6 detectors connected. I made a fresh synApps install on Ubuntu 22.04, epics 7.0.6 and added the dante-1-1 module to it. All built well.
Starting up the mcaDanteApp from iocDante8, I got a long string of errors ending in a dump. I have attached the st.cmd (renamed st.txt so it isn't blocked) file and the console output. I'm sure it is something stupid, but I don't know if it is even supposed
to work; the doc says it hasn't been tested much and I am new to both the hardware and the code.
Any suggestions appreciated.
Pete.
<log.txt>
<st.txt>
- Re: Dante-1-1 Mark Rivers via Tech-talk
- Fw: Dante-1-1 Siddons, David via Tech-talk
<2023>
<2023>
ANJ, 13 Aug 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
