We have an 8-channel Dante system from XG labs. It has 6 detectors connected. I made a fresh synApps install on Ubuntu 22.04, epics 7.0.6 and added the dante-1-1 module to it. All built well.
Starting up the mcaDanteApp from iocDante8, I got a long string of errors ending in a dump. I have attached the st.cmd (renamed st.txt so it isn't blocked) file and the console output. I'm sure it is something stupid, but I don't know if it is even supposed
to work; the doc says it hasn't been tested much and I am new to both the hardware and the code.
Any suggestions appreciated.
Pete.
< envPaths
epicsEnvSet("IOC","iocDante8")
epicsEnvSet("TOP","/home/kuczewski/epics/synApps/support/dante-1-1")
epicsEnvSet("SUPPORT","/home/kuczewski/epics/synApps/support")
epicsEnvSet("SNCSEQ","/home/kuczewski/epics/synApps/support/sequencer-mirror-R2-2-9")
epicsEnvSet("MCA","/home/kuczewski/epics/synApps/support/mca-R7-9")
epicsEnvSet("DANTE","/home/kuczewski/epics/synApps/support/dante-1-1")
epicsEnvSet("AREA_DETECTOR","/home/kuczewski/epics/synApps/support/areaDetector-R3-11")
epicsEnvSet("ASYN","/home/kuczewski/epics/synApps/support/asyn-R4-42")
epicsEnvSet("ADSUPPORT","/home/kuczewski/epics/synApps/support/areaDetector-R3-11/ADSupport")
epicsEnvSet("ADCORE","/home/kuczewski/epics/synApps/support/areaDetector-R3-11/ADCore")
epicsEnvSet("AUTOSAVE","/home/kuczewski/epics/synApps/support/autosave-R5-10-2")
epicsEnvSet("BUSY","/home/kuczewski/epics/synApps/support/busy-R1-7-3")
epicsEnvSet("CALC","/home/kuczewski/epics/synApps/support/calc-R3-7-4")
epicsEnvSet("SSCAN","/home/kuczewski/epics/synApps/support/sscan-R2-11-5")
epicsEnvSet("DEVIOCSTATS","/home/kuczewski/epics/synApps/support/iocStats-3-1-16")
epicsEnvSet("EPICS_BASE","/home/kuczewski/epics/base-7.0.6.1")
# Tell EPICS all about the record types, device-support modules, drivers,
# etc. in this build from dxpApp
dbLoadDatabase("/home/kuczewski/epics/synApps/support/dante-1-1/dbd/mcaDanteApp.dbd")
mcaDanteApp_registerRecordDeviceDriver(pdbbase)
# The search path for database files
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/home/kuczewski/epics/synApps/support/areaDetector-R3-11/ADCore/db")
# Prefix for all records
epicsEnvSet("PREFIX", "Dante:")
# The port name for the detector
epicsEnvSet("PORT", "DANTE1")
# The queue size for all plugins
epicsEnvSet("QSIZE", "20")
# The maximum image width; used to set the maximum size for row profiles in the NDPluginStats plugin
epicsEnvSet("XSIZE", "1024")
# The maximum image height; used to set the maximum size for column profiles in the NDPluginStats plugin
epicsEnvSet("YSIZE", "1024")
# The maximum number of time series points in the NDPluginStats plugin
epicsEnvSet("NCHANS", "2048")
# The maximum number of frames buffered in the NDPluginCircularBuff plugin
epicsEnvSet("CBUFFS", "500")
# The maximum number of threads for plugins which can run in multiple threads
epicsEnvSet("MAX_THREADS", "8")
# The maximum number of channels in the MCA records
epicsEnvSet("MCA_CHANS", "2048")
# The maximum number of points in the ADC trace waveform records
epicsEnvSet("TRACE_LEN", "16384")
# DanteConfig(portName, ipAddress, numDetectors, maxBuffers, maxMemory)
DanteConfig("DANTE1", 172.16.0.120, 6, 0, 0)
Dante::Dante library version=3.7.19.0
Dante::Dante ipAddress added to query=172.16.0.120
Dante::Dante number of devices=0
Dante::Dante error calling get_ids
dbLoadTemplate(/home/kuczewski/epics/synApps/support/dante-1-1/db/"dante8.substitutions", "P=Dante:, NCHAN=2048, TRACE_LEN=16384")
# Load all other plugins using commonPlugins.cmd
< /home/kuczewski/epics/synApps/support/areaDetector-R3-11/ADCore/iocBoot/commonPlugins.cmd
# This is an example file for creating plugins
# It uses the following environment variable macros
# Many of the parameters defined in this file are also in commonPlugins_settings.req so if autosave is being
# use the autosave value will replace the value passed to this file.
# $(PREFIX) Prefix for all records
# $(PORT) The port name for the detector. In autosave.
# $(QSIZE) The queue size for all plugins. In autosave.
# $(XSIZE) The maximum image width; used to set the maximum size for row profiles in the NDPluginStats plugin and 1-D FFT
# profiles in NDPluginFFT.
# $(YSIZE) The maximum image height; used to set the maximum size for column profiles in the NDPluginStats plugin
# $(NCHANS) The maximum number of time series points in the NDPluginStats, NDPluginROIStats, and NDPluginAttribute plugins
# $(CBUFFS) The maximum number of frames buffered in the NDPluginCircularBuff plugin
# $(MAX_THREADS) The maximum number of threads for plugins which can run in multiple threads. Defaults to 5.
# Create a netCDF file saving plugin
NDFileNetCDFConfigure("FileNetCDF1", 20, 0, "DANTE1", 0)
dbLoadRecords("NDFileNetCDF.template","P=Dante:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
# Create a TIFF file saving plugin
NDFileTIFFConfigure("FileTIFF1", 20, 0, "DANTE1", 0)
dbLoadRecords("NDFileTIFF.template", "P=Dante:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
# Create a JPEG file saving plugin
NDFileJPEGConfigure("FileJPEG1", 20, 0, "DANTE1", 0)
dbLoadRecords("NDFileJPEG.template", "P=Dante:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
# Create a NeXus file saving plugin
NDFileNexusConfigure("FileNexus1", 20, 0, "DANTE1", 0)
dbLoadRecords("NDFileNexus.template", "P=Dante:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
# Create an HDF5 file saving plugin
NDFileHDF5Configure("FileHDF1", 20, 0, "DANTE1", 0)
dbLoadRecords("NDFileHDF5.template", "P=Dante:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1,XMLSIZE=2048,NDARRAY_PORT=DANTE1")
# Create a Magick file saving plugin
#NDFileMagickConfigure("FileMagick1", $(QSIZE), 0, "$(PORT)", 0)
#dbLoadRecords("NDFileMagick.template","P=$(PREFIX),R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
# Create 4 ROI plugins
NDROIConfigure("ROI1", 20, 0, "DANTE1", 0, 0, 0, 0, 0, 8)
dbLoadRecords("NDROI.template", "P=Dante:,R=ROI1:, PORT=ROI1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
NDROIConfigure("ROI2", 20, 0, "DANTE1", 0, 0, 0, 0, 0, 8)
dbLoadRecords("NDROI.template", "P=Dante:,R=ROI2:, PORT=ROI2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
NDROIConfigure("ROI3", 20, 0, "DANTE1", 0, 0, 0, 0, 0, 8)
dbLoadRecords("NDROI.template", "P=Dante:,R=ROI3:, PORT=ROI3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
NDROIConfigure("ROI4", 20, 0, "DANTE1", 0, 0, 0, 0, 0, 8)
dbLoadRecords("NDROI.template", "P=Dante:,R=ROI4:, PORT=ROI4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
# Create 8 ROIStat plugins
NDROIStatConfigure("ROISTAT1", 20, 0, "DANTE1", 0, 8, 0, 0, 0, 0, 8)
dbLoadRecords("NDROIStat.template", "P=Dante:,R=ROIStat1: ,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template", "P=Dante:,R=ROIStat1:1:,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template", "P=Dante:,R=ROIStat1:2:,PORT=ROISTAT1,ADDR=1,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template", "P=Dante:,R=ROIStat1:3:,PORT=ROISTAT1,ADDR=2,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template", "P=Dante:,R=ROIStat1:4:,PORT=ROISTAT1,ADDR=3,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template", "P=Dante:,R=ROIStat1:5:,PORT=ROISTAT1,ADDR=4,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template", "P=Dante:,R=ROIStat1:6:,PORT=ROISTAT1,ADDR=5,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template", "P=Dante:,R=ROIStat1:7:,PORT=ROISTAT1,ADDR=6,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template", "P=Dante:,R=ROIStat1:8:,PORT=ROISTAT1,ADDR=7,TIMEOUT=1,NCHANS=2048")
# Create a processing plugin
NDProcessConfigure("PROC1", 20, 0, "DANTE1", 0, 0, 0)
dbLoadRecords("NDProcess.template", "P=Dante:,R=Proc1:, PORT=PROC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
# Create a TIFF file plugin to read dark and flatfield images into the processing plugin
NDFileTIFFConfigure("PROC1TIFF", 20, 0, "DANTE1", 0)
dbLoadRecords("NDFileTIFF.template", "P=Dante:,R=Proc1:TIFF:,PORT=PROC1TIFF,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
# Create a scatter plugin
NDScatterConfigure("SCATTER1", 20, 0, "DANTE1", 0, 0, 0)
dbLoadRecords("NDScatter.template", "P=Dante:,R=Scatter1:, PORT=SCATTER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
# Create a gather plugin with 8 ports
NDGatherConfigure("GATHER1", 20, 0, 8, 0, 0)
dbLoadRecords("NDGather.template", "P=Dante:,R=Gather1:, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
dbLoadRecords("NDGatherN.template", "P=Dante:,R=Gather1:, N=1, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
dbLoadRecords("NDGatherN.template", "P=Dante:,R=Gather1:, N=2, PORT=GATHER1,ADDR=1,TIMEOUT=1,NDARRAY_PORT=DANTE1")
dbLoadRecords("NDGatherN.template", "P=Dante:,R=Gather1:, N=3, PORT=GATHER1,ADDR=2,TIMEOUT=1,NDARRAY_PORT=DANTE1")
dbLoadRecords("NDGatherN.template", "P=Dante:,R=Gather1:, N=4, PORT=GATHER1,ADDR=3,TIMEOUT=1,NDARRAY_PORT=DANTE1")
dbLoadRecords("NDGatherN.template", "P=Dante:,R=Gather1:, N=5, PORT=GATHER1,ADDR=4,TIMEOUT=1,NDARRAY_PORT=DANTE1")
dbLoadRecords("NDGatherN.template", "P=Dante:,R=Gather1:, N=6, PORT=GATHER1,ADDR=5,TIMEOUT=1,NDARRAY_PORT=DANTE1")
dbLoadRecords("NDGatherN.template", "P=Dante:,R=Gather1:, N=7, PORT=GATHER1,ADDR=6,TIMEOUT=1,NDARRAY_PORT=DANTE1")
dbLoadRecords("NDGatherN.template", "P=Dante:,R=Gather1:, N=8, PORT=GATHER1,ADDR=7,TIMEOUT=1,NDARRAY_PORT=DANTE1")
# Create 5 statistics plugins
NDStatsConfigure("STATS1", 20, 0, "DANTE1", 0, 0, 0, 0, 0, 8)
dbLoadRecords("NDStats.template", "P=Dante:,R=Stats1:, PORT=STATS1,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1024,YSIZE=1024,NCHANS=2048,NDARRAY_PORT=DANTE1")
NDTimeSeriesConfigure("STATS1_TS", 20, 0, "STATS1", 1, 23)
dbLoadRecords("/home/kuczewski/epics/synApps/support/areaDetector-R3-11/ADCore/db/NDTimeSeries.template", "P=Dante:,R=Stats1:TS:, PORT=STATS1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS2", 20, 0, "ROI1", 0, 0, 0, 0, 0, 8)
dbLoadRecords("NDStats.template", "P=Dante:,R=Stats2:, PORT=STATS2,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1024,YSIZE=1024,NCHANS=2048,NDARRAY_PORT=DANTE1")
NDTimeSeriesConfigure("STATS2_TS", 20, 0, "STATS2", 1, 23)
dbLoadRecords("/home/kuczewski/epics/synApps/support/areaDetector-R3-11/ADCore/db/NDTimeSeries.template", "P=Dante:,R=Stats2:TS:, PORT=STATS2_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS2,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS3", 20, 0, "ROI2", 0, 0, 0, 0, 0, 8)
dbLoadRecords("NDStats.template", "P=Dante:,R=Stats3:, PORT=STATS3,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1024,YSIZE=1024,NCHANS=2048,NDARRAY_PORT=DANTE1")
NDTimeSeriesConfigure("STATS3_TS", 20, 0, "STATS3", 1, 23)
dbLoadRecords("/home/kuczewski/epics/synApps/support/areaDetector-R3-11/ADCore/db/NDTimeSeries.template", "P=Dante:,R=Stats3:TS:, PORT=STATS3_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS3,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS4", 20, 0, "ROI3", 0, 0, 0, 0, 0, 8)
dbLoadRecords("NDStats.template", "P=Dante:,R=Stats4:, PORT=STATS4,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1024,YSIZE=1024,NCHANS=2048,NDARRAY_PORT=DANTE1")
NDTimeSeriesConfigure("STATS4_TS", 20, 0, "STATS4", 1, 23)
dbLoadRecords("/home/kuczewski/epics/synApps/support/areaDetector-R3-11/ADCore/db/NDTimeSeries.template", "P=Dante:,R=Stats4:TS:, PORT=STATS4_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS4,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS5", 20, 0, "ROI4", 0, 0, 0, 0, 0, 8)
dbLoadRecords("NDStats.template", "P=Dante:,R=Stats5:, PORT=STATS5,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1024,YSIZE=1024,NCHANS=2048,NDARRAY_PORT=DANTE1")
NDTimeSeriesConfigure("STATS5_TS", 20, 0, "STATS5", 1, 23)
dbLoadRecords("/home/kuczewski/epics/synApps/support/areaDetector-R3-11/ADCore/db/NDTimeSeries.template", "P=Dante:,R=Stats5:TS:, PORT=STATS5_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS5,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
# Create a transform plugin
NDTransformConfigure("TRANS1", 20, 0, "DANTE1", 0, 0, 0, 0, 0, 8)
dbLoadRecords("NDTransform.template", "P=Dante:,R=Trans1:, PORT=TRANS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
# Create an overlay plugin with 8 overlays
NDOverlayConfigure("OVER1", 20, 0, "DANTE1", 0, 8, 0, 0, 0, 0, 8)
dbLoadRecords("NDOverlay.template", "P=Dante:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
dbLoadRecords("NDOverlayN.template","P=Dante:,R=Over1:1:,NAME=ROI1, SHAPE=1,O=Over1:,XPOS=Dante:ROI1:MinX_RBV,YPOS=Dante:ROI1:MinY_RBV,XSIZE=Dante:ROI1:SizeX_RBV,YSIZE=Dante:ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=Dante:,R=Over1:2:,NAME=ROI2, SHAPE=1,O=Over1:,XPOS=Dante:ROI2:MinX_RBV,YPOS=Dante:ROI2:MinY_RBV,XSIZE=Dante:ROI2:SizeX_RBV,YSIZE=Dante:ROI2:SizeY_RBV,PORT=OVER1,ADDR=1,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=Dante:,R=Over1:3:,NAME=ROI3, SHAPE=1,O=Over1:,XPOS=Dante:ROI3:MinX_RBV,YPOS=Dante:ROI3:MinY_RBV,XSIZE=Dante:ROI3:SizeX_RBV,YSIZE=Dante:ROI3:SizeY_RBV,PORT=OVER1,ADDR=2,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=Dante:,R=Over1:4:,NAME=ROI4, SHAPE=1,O=Over1:,XPOS=Dante:ROI4:MinX_RBV,YPOS=Dante:ROI4:MinY_RBV,XSIZE=Dante:ROI4:SizeX_RBV,YSIZE=Dante:ROI4:SizeY_RBV,PORT=OVER1,ADDR=3,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=Dante:,R=Over1:5:,NAME=Cursor1,SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=4,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=Dante:,R=Over1:6:,NAME=Cursor2,SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=5,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=Dante:,R=Over1:7:,NAME=Box1, SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=6,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=Dante:,R=Over1:8:,NAME=Box2, SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=7,TIMEOUT=1")
# Create 2 color conversion plugins
NDColorConvertConfigure("CC1", 20, 0, "DANTE1", 0, 0, 0, 0, 0, 8)
dbLoadRecords("NDColorConvert.template", "P=Dante:,R=CC1:, PORT=CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
NDColorConvertConfigure("CC2", 20, 0, "DANTE1", 0, 0, 0, 0, 0, 8)
dbLoadRecords("NDColorConvert.template", "P=Dante:,R=CC2:, PORT=CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
# Create a circular buffer plugin
NDCircularBuffConfigure("CB1", 20, 0, "DANTE1", 0, 500, 0)
dbLoadRecords("NDCircularBuff.template", "P=Dante:,R=CB1:, PORT=CB1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=DANTE1")
# Create an NDAttribute plugin with 8 attributes
NDAttrConfigure("ATTR1", 20, 0, "DANTE1", 0, 8, 0, 0, 0)
dbLoadRecords("NDAttribute.template", "P=Dante:,R=Attr1:, PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048,NDARRAY_PORT=DANTE1")
dbLoadRecords("NDAttributeN.template", "P=Dante:,R=Attr1:1:, PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=Dante:,R=Attr1:2:, PORT=ATTR1,ADDR=1,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=Dante:,R=Attr1:3:, PORT=ATTR1,ADDR=2,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=Dante:,R=Attr1:4:, PORT=ATTR1,ADDR=3,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=Dante:,R=Attr1:5:, PORT=ATTR1,ADDR=4,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=Dante:,R=Attr1:6:, PORT=ATTR1,ADDR=5,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=Dante:,R=Attr1:7:, PORT=ATTR1,ADDR=6,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=Dante:,R=Attr1:8:, PORT=ATTR1,ADDR=7,TIMEOUT=1,NCHANS=2048")
NDTimeSeriesConfigure("ATTR1_TS", 20, 0, "ATTR1", 1, 8)
dbLoadRecords("/home/kuczewski/epics/synApps/support/areaDetector-R3-11/ADCore/db/NDTimeSeries.template", "P=Dante:,R=Attr1:TS:, PORT=ATTR1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ATTR1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
# Create an FFT plugin
NDFFTConfigure("FFT1", 20, 0, "DANTE1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDFFT.template", "P=Dante:, R=FFT1:, PORT=FFT1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=DANTE1, NAME=FFT1, NCHANS=1024")
# Create 2 Codec plugins
NDCodecConfigure("CODEC1", 20, 0, "DANTE1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDCodec.template", "P=Dante:, R=Codec1:, PORT=CODEC1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=DANTE1")
NDCodecConfigure("CODEC2", 20, 0, "DANTE1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDCodec.template", "P=Dante:, R=Codec2:, PORT=CODEC2, ADDR=0, TIMEOUT=1, NDARRAY_PORT=DANTE1")
# Create a bStarting iocInit
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
save_restore: Can't open file './autosave/auto_settings.sav'.
save_restore: Trying backup file './autosave/auto_settings.savB'
save_restore: Can't open file './autosave/auto_settings.savB'.
save_restore: Can't figure out which seq file is most recent,
save_restore: so I'm just going to start with './autosave/auto_settings.sav0'.
save_restore: Trying backup file './autosave/auto_settings.sav0'
save_restore: Can't open file './autosave/auto_settings.sav0'.
save_restore: Trying backup file './autosave/auto_settings.sav1'
save_restore: Can't open file './autosave/auto_settings.sav1'.
save_restore: Trying backup file './autosave/auto_settings.sav2'
save_restore: Can't open file './autosave/auto_settings.sav2'.
save_restore: Can't find a file to restore from...save_restore: ...last tried './autosave/auto_settings.sav2'. I give up.
save_restore: Can't open save file.2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DantePollTime
Error (514,11) PV: Dante:dante:PollTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter MCA_PRESET_REAL
Error (514,11) PV: Dante:dante:PresetReal ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTraceTime
Error (514,11) PV: Dante:dante:TraceTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTraceTriggerWait
Error (514,11) PV: Dante:dante:TraceTriggerWait ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteMaxEnergy
Error (514,11) PV: Dante:dante1:MaxEnergy ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteFastFilterThreshold
Error (514,11) PV: Dante:dante1:FastThreshold ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteEnergyFilterThreshold
Error (514,11) PV: Dante:dante1:EnergyThreshold ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteBaselineThreshold
ad pixel plugin
NDBadPixelConfigure("BADPIX1", 20, 0, "DANTE1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDBadPixel.template", "P=Dante:, R=BadPix1:, PORT=BADPIX1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=DANTE1")
set_requestfile_path("./")
set_requestfile_path("/home/kuczewski/epics/synApps/support/areaDetector-R3-11/ADCore/ADApp/Db")
set_requestfile_path("/home/kuczewski/epics/synApps/support/areaDetector-R3-11/ADCore/iocBoot")
set_savefile_path("./autosave")
set_pass0_restoreFile("auto_settings.sav")
set_pass1_restoreFile("auto_settings.sav")
save_restoreSet_status_prefix("Dante:")
dbLoadRecords("/home/kuczewski/epics/synApps/support/autosave-R5-10-2/asApp/Db/save_restoreStatus.db", "P=Dante:")
# Optional: load NDPluginPva plugin
#NDPvaConfigure("PVA1", $(QSIZE), 0, "$(PORT)", 0, $(PREFIX)Pva1:Image, 0, 0, 0)
#dbLoadRecords("NDPva.template", "P=$(PREFIX),R=Pva1:, PORT=PVA1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
# Must start PVA server if this is enabled
#startPVAServer
# Optional: load ffmpegServer plugin
#ffmpegServerConfigure(8081)
#ffmpegStreamConfigure("FfmStream1", 2, 0, "$(PORT)", 0, -1, 0)
#dbLoadRecords("$(FFMPEGSERVER)/db/ffmpegStream.template", "P=$(PREFIX),R=ffmstream1:,PORT=FfmStream1,NDARRAY_PORT=$(PORT)")
#ffmpegFileConfigure("FfmFile1", 16, 0, "$(PORT)", 0, -1, 0)
#dbLoadRecords("$(FFMPEGSERVER)/db/ffmpegFile.template", "P=$(PREFIX),R=ffmfile1:,PORT=FfmFile1,NDARRAY_PORT=$(PORT)")
# Optional: load NDPluginEdge plugin
#NDEdgeConfigure("EDGE1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0)
#dbLoadRecords("$(ADPLUGINEDGE)/db/NDEdge.template", "P=$(PREFIX),R=Edge1:, PORT=EDGE1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
#set_requestfile_path("$(ADPLUGINEDGE)/edgeApp/Db")
# Optional: load NDPluginCV plugin
#NDCVConfigure("CV1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0, 0, $(MAX_THREADS=5))
#dbLoadRecords("$(ADCOMPVISION)/db/NDCV.template", "P=$(PREFIX),R=CV1:, PORT=CV1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
#set_requestfile_path("$(ADCOMPVISION)/adcvApp/Db")
# Optional: load NDPluginBar plugin
#NDBarConfigure("BAR1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0, 0, $(MAX_THREADS=5))
#dbLoadRecords("$(ADPLUGINBAR)/db/NDBar.template", "P=$(PREFIX),R=Bar1:, PORT=BAR1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
#set_requestfile_path("$(ADPLUGINBAR)/barApp/Db")
# Optional: load scan records
#dbLoadRecords("$(SSCAN)/sscanApp/Db/scan.db", "P=$(PREFIX),MAXPTS1=2000,MAXPTS2=200,MAXPTS3=20,MAXPTS4=10,MAXPTSH=10")
#set_requestfile_path("$(SSCAN)/sscanApp/Db")
# Optional: load sseq record for acquisition sequence
#dbLoadRecords("$(CALC)/calcApp/Db/sseqRecord.db", "P=$(PREFIX), S=AcquireSequence")
#set_requestfile_path("$(CALC)/calcApp/Db")
# Optional: load devIocStats records (requires DEVIOCSTATS module)
#dbLoadRecords("$(DEVIOCSTATS)/db/iocAdminSoft.db", "IOC=$(PREFIX)")
# Optional: load alive record (requires ALIVE module)
#dbLoadRecords("$(ALIVE)/aliveApp/Db/alive.db", "P=$(PREFIX),RHOST=192.168.1.254")
# Set the callback queue size to 5000, up from default of 2000 in base.
# This can be needed to avoid errors "callbackRequest: cbLow ring buffer full".
callbackSetQueueSize(5000)
set_requestfile_path("/home/kuczewski/epics/synApps/support/dante-1-1/danteApp/Db")
set_requestfile_path("/home/kuczewski/epics/synApps/support/mca-R7-9/mcaApp/Db")
asynSetTraceIOMask(DANTE1,0,ESCAPE)
#asynSetTraceMask($(PORT),0,ERROR|WARNING)
iocInit
## EPICS R7.0.6.1
## Rev. 2022-05-17T10:47-0400
save_restore: **********************************
Dante:dante:PollTime devAsynFloat64::initCommon drvUserCreate
Dante:dante:PresetReal devAsynFloat64::initCommon drvUserCreate
Dante:dante:TraceTime devAsynFloat64::initCommon drvUserCreate
Dante:dante:TraceTriggerWait devAsynFloat64::initCommon drvUserCreate
Dante:dante1:MaxEnergy devAsynFloat64::initCommon drvUserCreate
Dante:dante1:FastThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante1:EnergyThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante1:BaselineThreshoError (514,11) PV: Dante:dante1:BaselineThreshold ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteMaxRiseTime
Error (514,11) PV: Dante:dante1:MaxRiseTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteGain
Error (514,11) PV: Dante:dante1:Gain ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DantePeakingTime
Error (514,11) PV: Dante:dante1:PeakingTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteMaxPeakingTime
Error (514,11) PV: Dante:dante1:MaxPeakingTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteFastPeakingTime
Error (514,11) PV: Dante:dante1:FastPeakingTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteFlatTop
Error (514,11) PV: Dante:dante1:FlatTopTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteFastFlatTop
Error (514,11) PV: Dante:dante1:FastFlatTopTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteResetRecoveryTime
Error (514,11) PV: Dante:dante1:ResetRecoveryTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteZeroPeakFreq
Error (514,11) PV: Dante:dante1:ZeroPeakFreq ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTimeConstant
Error (514,11) PV: Dante:dante1:TimeConstant ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteMaxEnergy
Error (514,11) PV: Dante:dante2:MaxEnergy ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteFastFilterThreshold
Error (514,11) PV: Dante:dante2:FastThreshold ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteEnergyFilterThreshold
Error (514,11) PV: Dante:dante2:EnergyThreshold ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteBaselineThreshold
Error (514,11) PV: Dante:dante2:BaselineThreshold ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteMaxRiseTime
Error (514,11) PV: Dante:dante2:MaxRiseTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteGain
Error (514,11) PV: Dante:dante2:Gain ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DantePeakingTime
Error (514,11) PV: Dante:dante2:PeakingTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteMaxPeakingTime
Error (514,11) PV: Dante:dante2:MaxPeakingTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteFastPeakingTime
Error (514,11) PV: Dante:dante2:FastPeakingTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteFlatTop
Error (514,11) PV: Dante:dante2:FlatTopTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteFastFlatTop
Error (514,11) PV: Dante:dante2:FastFlatTopTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteResetRecoveryTime
Error (514,11) PV: Dante:dante2:ResetRecoveryTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteZeroPeakFreq
Error (514,11) PV: Dante:dante2:ZeroPeakFreq ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteTimeConstant
Error (514,11) PV: Dante:dante2:TimeConstant ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteMaxEnergy
Error (514,11) PV: Dante:dante3:MaxEnergy ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteFastFilterThreshold
Error (514,11) PV: Dante:dante3:FastThreshold ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteEnergyFilterThreshold
Error (514,11) PV: Dante:dante3:EnergyThreshold ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteBaselineThreshold
Error (514,11) PV: Dante:dante3:BaselineThreshold ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteMaxRiseTime
Error (514,11) PV: Dante:dante3:MaxRiseTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteGain
Error (514,11) PV: Dante:dante3:Gain ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DantePeakingTime
Error (514,11) PV: Dante:dante3:PeakingTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteMaxPeakingTime
Error (514,11) PV: Dante:dante3:MaxPeakingTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteFastPeakingTime
Error (514,11) PV: Dante:dante3:FastPeakingTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteFlatTop
Error (514,11) PV: Dante:dante3:FlatTopTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteFastFlatTop
Error (514,11) PV: Dante:dante3:FastFlatTopTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteResetRecoveryTime
Error (514,11) PV: Dante:dante3:ResetRecoveryTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteZeroPeakFreq
Error (514,11) PV: Dante:dante3:ZeroPeakFreq ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteTimeConstant
Error (514,11) PV: Dante:dante3:TimeConstant ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteMaxEnergy
Error (514,11) PV: Dante:dante4:MaxEnergy ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteFastFilterThreshold
Error (514,11) PV: Dante:dante4:FastThreshold ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteEnergyFilterThreshold
Error (514,11) PV: Dante:dante4:EnergyThreshold ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteBaselineThreshold
Error (514,11) PV: Dante:dante4:BaselineThreshold ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteMaxRiseTime
Error (514,11) PV: Dante:dante4:MaxRiseTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteGain
Error (514,11) PV: Dante:dante4:Gain ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DantePeakingTime
Error (514,11) PV: Dante:dante4:PeakingTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteMaxPeakingTime
Error (514,11) PV: Dante:dante4:MaxPeakingTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteFastPeakingTime
Error (514,11) PV: Dante:dante4:FastPeakingTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteFlatTop
Error (514,11) PV: Dante:dante4:FlatTopTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteFastFlatTop
Error (514,11) PV: Dante:dante4:FastFlatTopTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteResetRecoveryTime
Error (514,11) PV: Dante:dante4:ResetRecoveryTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteZeroPeakFreq
Error (514,11) PV: Dante:dante4:ZeroPeakFreq ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteTimeConstant
Error (514,11) PV: Dante:dante4:TimeConstant ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteMaxEnergy
Error (514,11) PV: Dante:dante5:MaxEnergy ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteFastFilterThreshold
Error (514,11) PV: Dante:dante5:FastThreshold ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteEnergyFilterThreshold
Error (514,11) PV: Dante:dante5:EnergyThreshold ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteBaselineThreshold
Error (514,11) PV: Dante:dante5:BaselineThreshold ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteMaxRiseTime
Error (514,11) PV: Dante:dante5:MaxRiseTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteGain
Error (514,11) PV: Dante:dante5:Gain ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DantePeakingTime
Error (514,11) PV: Dante:dante5:PeakingTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteMaxPeakingTime
Dante:dante1:MaxRiseTime devAsynFloat64::initCommon drvUserCreate
Dante:dante1:Gain devAsynFloat64::initCommon drvUserCreate
Dante:dante1:PeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante1:MaxPeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante1:FastPeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante1:FlatTopTime devAsynFloat64::initCommon drvUserCreate
Dante:dante1:FastFlatTopTime devAsynFloat64::initCommon drvUserCreate
Dante:dante1:ResetRecoveryTime devAsynFloat64::initCommon drvUserCreate
Dante:dante1:ZeroPeakFreq devAsynFloat64::initCommon drvUserCreate
Dante:dante1:TimeConstant devAsynFloat64::initCommon drvUserCreate
Dante:dante2:MaxEnergy devAsynFloat64::initCommon drvUserCreate
Dante:dante2:FastThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante2:EnergyThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante2:BaselineThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante2:MaxRiseTime devAsynFloat64::initCommon drvUserCreate
Dante:dante2:Gain devAsynFloat64::initCommon drvUserCreate
Dante:dante2:PeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante2:MaxPeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante2:FastPeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante2:FlatTopTime devAsynFloat64::initCommon drvUserCreate
Dante:dante2:FastFlatTopTime devAsynFloat64::initCommon drvUserCreate
Dante:dante2:ResetRecoveryTime devAsynFloat64::initCommon drvUserCreate
Dante:dante2:ZeroPeakFreq devAsynFloat64::initCommon drvUserCreate
Dante:dante2:TimeConstant devAsynFloat64::initCommon drvUserCreate
Dante:dante3:MaxEnergy devAsynFloat64::initCommon drvUserCreate
Dante:dante3:FastThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante3:EnergyThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante3:BaselineThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante3:MaxRiseTime devAsynFloat64::initCommon drvUserCreate
Dante:dante3:Gain devAsynFloat64::initCommon drvUserCreate
Dante:dante3:PeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante3:MaxPeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante3:FastPeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante3:FlatTopTime devAsynFloat64::initCommon drvUserCreate
Dante:dante3:FastFlatTopTime devAsynFloat64::initCommon drvUserCreate
Dante:dante3:ResetRecoveryTime devAsynFloat64::initCommon drvUserCreate
Dante:dante3:ZeroPeakFreq devAsynFloat64::initCommon drvUserCreate
Dante:dante3:TimeConstant devAsynFloat64::initCommon drvUserCreate
Dante:dante4:MaxEnergy devAsynFloat64::initCommon drvUserCreate
Dante:dante4:FastThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante4:EnergyThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante4:BaselineThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante4:MaxRiseTime devAsynFloat64::initCommon drvUserCreate
Dante:dante4:Gain devAsynFloat64::initCommon drvUserCreate
Dante:dante4:PeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante4:MaxPeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante4:FastPeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante4:FlatTopTime devAsynFloat64::initCommon drvUserCreate
Dante:dante4:FastFlatTopTime devAsynFloat64::initCommon drvUserCreate
Dante:dante4:ResetRecoveryTime devAsynFloat64::initCommon drvUserCreate
Dante:dante4:ZeroPeakFreq devAsynFloat64::initCommon drvUserCreate
Dante:dante4:TimeConstant devAsynFloat64::initCommon drvUserCreate
Dante:dante5:MaxEnergy devAsynFloat64::initCommon drvUserCreate
Dante:dante5:FastThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante5:EnergyThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante5:BaselineThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante5:MaxRiseTime devAsynFloat64::initCommon drvUserCreate
Dante:dante5:Gain devAsynFloat64::initCommon drvUserCreate
Dante:dante5:PeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante5:MaxPError (514,11) PV: Dante:dante5:MaxPeakingTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteFastPeakingTime
Error (514,11) PV: Dante:dante5:FastPeakingTime ao: init_record
2023/08/10 15:43:51.822 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteFlatTop
Error (514,11) PV: Dante:dante5:FlatTopTime ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteFastFlatTop
Error (514,11) PV: Dante:dante5:FastFlatTopTime ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteResetRecoveryTime
Error (514,11) PV: Dante:dante5:ResetRecoveryTime ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteZeroPeakFreq
Error (514,11) PV: Dante:dante5:ZeroPeakFreq ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteTimeConstant
Error (514,11) PV: Dante:dante5:TimeConstant ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteMaxEnergy
Error (514,11) PV: Dante:dante6:MaxEnergy ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteFastFilterThreshold
Error (514,11) PV: Dante:dante6:FastThreshold ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteEnergyFilterThreshold
Error (514,11) PV: Dante:dante6:EnergyThreshold ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteBaselineThreshold
Error (514,11) PV: Dante:dante6:BaselineThreshold ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteMaxRiseTime
Error (514,11) PV: Dante:dante6:MaxRiseTime ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteGain
Error (514,11) PV: Dante:dante6:Gain ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DantePeakingTime
Error (514,11) PV: Dante:dante6:PeakingTime ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteMaxPeakingTime
Error (514,11) PV: Dante:dante6:MaxPeakingTime ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteFastPeakingTime
Error (514,11) PV: Dante:dante6:FastPeakingTime ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteFlatTop
Error (514,11) PV: Dante:dante6:FlatTopTime ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteFastFlatTop
Error (514,11) PV: Dante:dante6:FastFlatTopTime ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteResetRecoveryTime
Error (514,11) PV: Dante:dante6:ResetRecoveryTime ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteZeroPeakFreq
Error (514,11) PV: Dante:dante6:ZeroPeakFreq ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteTimeConstant
Error (514,11) PV: Dante:dante6:TimeConstant ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteMaxEnergy
Error (514,11) PV: Dante:dante7:MaxEnergy ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteFastFilterThreshold
Error (514,11) PV: Dante:dante7:FastThreshold ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteEnergyFilterThreshold
Error (514,11) PV: Dante:dante7:EnergyThreshold ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteBaselineThreshold
Error (514,11) PV: Dante:dante7:BaselineThreshold ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteMaxRiseTime
Error (514,11) PV: Dante:dante7:MaxRiseTime ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteGain
Error (514,11) PV: Dante:dante7:Gain ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DantePeakingTime
Error (514,11) PV: Dante:dante7:PeakingTime ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteMaxPeakingTime
Error (514,11) PV: Dante:dante7:MaxPeakingTime ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteFastPeakingTime
Error (514,11) PV: Dante:dante7:FastPeakingTime ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteFlatTop
Error (514,11) PV: Dante:dante7:FlatTopTime ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteFastFlatTop
Error (514,11) PV: Dante:dante7:FastFlatTopTime ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteResetRecoveryTime
Error (514,11) PV: Dante:dante7:ResetRecoveryTime ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteZeroPeakFreq
Error (514,11) PV: Dante:dante7:ZeroPeakFreq ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteTimeConstant
Error (514,11) PV: Dante:dante7:TimeConstant ao: init_record
2023/08/10 15:43:51.823 asynPortDriver:getAddress: DANTE1 invalid address=7, must be in range 0 to 6
Error (514,11) PV: Dante:dante8:MaxEnergy ao: init_record
Error (514,11) PV: Dante:dante8:FastThreshold ao: init_record
Error (514,11) PV: Dante:dante8:EnergyThreshold ao: init_record
Error (514,11) PV: Dante:dante8:BaselineThreshold ao: init_record
Error (514,11) PV: Dante:dante8:MaxRiseTime ao: init_record
Error (514,11) PV: Dante:dante8:Gain ao: init_record
Error (514,11) PV: Dante:dante8:PeakingTime ao: init_record
Error (514,11) PV: Dante:dante8:MaxPeakingTime ao: init_record
Error (514,11) PV: Dante:dante8:FastPeakingTime ao: init_record
Error (514,11) PV: Dante:dante8:FlatTopTime ao: init_record
Error (514,11) PV: Dante:dante8:FastFlatTopTime ao: init_record
Error (514,11) PV: Dante:dante8:ResetRecoveryTime ao: init_record
Error (514,11) PV: Dante:dante8:ZeroPeakFreq ao: init_record
Error (514,11) PV: Dante:dante8:TimeConstant ao: init_record
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteCurrentPixel
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteMappingPoints
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteListBufferSize
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTraceTriggerLevel
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTraceLength
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTriggers
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteEvents
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteFastDT
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteFilt1DT
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteZeroCounts
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteBaselinesValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DantePUPValue
Dante:dante5:FastPeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante5:FlatTopTime devAsynFloat64::initCommon drvUserCreate
Dante:dante5:FastFlatTopTime devAsynFloat64::initCommon drvUserCreate
Dante:dante5:ResetRecoveryTime devAsynFloat64::initCommon drvUserCreate
Dante:dante5:ZeroPeakFreq devAsynFloat64::initCommon drvUserCreate
Dante:dante5:TimeConstant devAsynFloat64::initCommon drvUserCreate
Dante:dante6:MaxEnergy devAsynFloat64::initCommon drvUserCreate
Dante:dante6:FastThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante6:EnergyThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante6:BaselineThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante6:MaxRiseTime devAsynFloat64::initCommon drvUserCreate
Dante:dante6:Gain devAsynFloat64::initCommon drvUserCreate
Dante:dante6:PeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante6:MaxPeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante6:FastPeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante6:FlatTopTime devAsynFloat64::initCommon drvUserCreate
Dante:dante6:FastFlatTopTime devAsynFloat64::initCommon drvUserCreate
Dante:dante6:ResetRecoveryTime devAsynFloat64::initCommon drvUserCreate
Dante:dante6:ZeroPeakFreq devAsynFloat64::initCommon drvUserCreate
Dante:dante6:TimeConstant devAsynFloat64::initCommon drvUserCreate
Dante:dante7:MaxEnergy devAsynFloat64::initCommon drvUserCreate
Dante:dante7:FastThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante7:EnergyThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante7:BaselineThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante7:MaxRiseTime devAsynFloat64::initCommon drvUserCreate
Dante:dante7:Gain devAsynFloat64::initCommon drvUserCreate
Dante:dante7:PeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante7:MaxPeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante7:FastPeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante7:FlatTopTime devAsynFloat64::initCommon drvUserCreate
Dante:dante7:FastFlatTopTime devAsynFloat64::initCommon drvUserCreate
Dante:dante7:ResetRecoveryTime devAsynFloat64::initCommon drvUserCreate
Dante:dante7:ZeroPeakFreq devAsynFloat64::initCommon drvUserCreate
Dante:dante7:TimeConstant devAsynFloat64::initCommon drvUserCreate
Dante:dante8:MaxEnergy devAsynFloat64::initCommon drvUserCreate
Dante:dante8:FastThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante8:EnergyThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante8:BaselineThreshold devAsynFloat64::initCommon drvUserCreate
Dante:dante8:MaxRiseTime devAsynFloat64::initCommon drvUserCreate
Dante:dante8:Gain devAsynFloat64::initCommon drvUserCreate
Dante:dante8:PeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante8:MaxPeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante8:FastPeakingTime devAsynFloat64::initCommon drvUserCreate
Dante:dante8:FlatTopTime devAsynFloat64::initCommon drvUserCreate
Dante:dante8:FastFlatTopTime devAsynFloat64::initCommon drvUserCreate
Dante:dante8:ResetRecoveryTime devAsynFloat64::initCommon drvUserCreate
Dante:dante8:ZeroPeakFreq devAsynFloat64::initCommon drvUserCreate
Dante:dante8:TimeConstant devAsynFloat64::initCommon drvUserCreate
Dante:dante:CurrentPixel devAsynInt32::initCommon drvUserCreate
Dante:dante:MappingPoints_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante:ListBufferSize_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante:TraceTriggerLevel_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante:TraceLength_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante1:Triggers devAsynInt32::initCommon drvUserCreate
Dante:dante1:Events devAsynInt32::initCommon drvUserCreate
Dante:dante1:FastDeadTime devAsynInt32::initCommon drvUserCreate
Dante:dante1:F1DeadTime devAsynInt32::initCommon drvUserCreate
Dante:dante1:ZeroCounts devAsynInt32::initCommon drvUserCreate
Dante:dante1:BaselineCount devAsynInt32::initCommon drvUserCreate
Dante:dante1:P2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DantePUPF1Value
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DantePUPNotF1Value
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteResetCounterValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteBaselineSamples
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteBaseOffset
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteResetThreshold
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteAnalogOffset
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteTriggers
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteEvents
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteFastDT
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteFilt1DT
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteZeroCounts
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteBaselinesValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DantePUPValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DantePUPF1Value
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DantePUPNotF1Value
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteResetCounterValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteBaselineSamples
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteBaseOffset
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteResetThreshold
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteAnalogOffset
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteTriggers
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteEvents
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteFastDT
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteFilt1DT
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteZeroCounts
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteBaselinesValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DantePUPValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DantePUPF1Value
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DantePUPNotF1Value
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteResetCounterValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteBaselineSamples
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteBaseOffset
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteResetThreshold
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteAnalogOffset
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteTriggers
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteEvents
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteFastDT
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteFilt1DT
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteZeroCounts
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteBaselinesValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DantePUPValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DantePUPF1Value
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DantePUPNotF1Value
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteResetCounterValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteBaselineSamples
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteBaseOffset
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteResetThreshold
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteAnalogOffset
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteTriggers
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteEvents
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteFastDT
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteFilt1DT
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteZeroCounts
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteBaselinesValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DantePUPValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DantePUPF1Value
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DantePUPNotF1Value
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteResetCounterValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteBaselineSamples
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteBaseOffset
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteResetThreshold
ileUp devAsynInt32::initCommon drvUserCreate
Dante:dante1:F1PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante1:NotF1PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante1:ResetCounts devAsynInt32::initCommon drvUserCreate
Dante:dante1:BaselineSamples_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante1:BaseOffset_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante1:ResetThreshold_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante1:AnalogOffset_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante2:Triggers devAsynInt32::initCommon drvUserCreate
Dante:dante2:Events devAsynInt32::initCommon drvUserCreate
Dante:dante2:FastDeadTime devAsynInt32::initCommon drvUserCreate
Dante:dante2:F1DeadTime devAsynInt32::initCommon drvUserCreate
Dante:dante2:ZeroCounts devAsynInt32::initCommon drvUserCreate
Dante:dante2:BaselineCount devAsynInt32::initCommon drvUserCreate
Dante:dante2:PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante2:F1PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante2:NotF1PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante2:ResetCounts devAsynInt32::initCommon drvUserCreate
Dante:dante2:BaselineSamples_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante2:BaseOffset_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante2:ResetThreshold_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante2:AnalogOffset_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante3:Triggers devAsynInt32::initCommon drvUserCreate
Dante:dante3:Events devAsynInt32::initCommon drvUserCreate
Dante:dante3:FastDeadTime devAsynInt32::initCommon drvUserCreate
Dante:dante3:F1DeadTime devAsynInt32::initCommon drvUserCreate
Dante:dante3:ZeroCounts devAsynInt32::initCommon drvUserCreate
Dante:dante3:BaselineCount devAsynInt32::initCommon drvUserCreate
Dante:dante3:PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante3:F1PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante3:NotF1PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante3:ResetCounts devAsynInt32::initCommon drvUserCreate
Dante:dante3:BaselineSamples_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante3:BaseOffset_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante3:ResetThreshold_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante3:AnalogOffset_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante4:Triggers devAsynInt32::initCommon drvUserCreate
Dante:dante4:Events devAsynInt32::initCommon drvUserCreate
Dante:dante4:FastDeadTime devAsynInt32::initCommon drvUserCreate
Dante:dante4:F1DeadTime devAsynInt32::initCommon drvUserCreate
Dante:dante4:ZeroCounts devAsynInt32::initCommon drvUserCreate
Dante:dante4:BaselineCount devAsynInt32::initCommon drvUserCreate
Dante:dante4:PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante4:F1PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante4:NotF1PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante4:ResetCounts devAsynInt32::initCommon drvUserCreate
Dante:dante4:BaselineSamples_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante4:BaseOffset_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante4:ResetThreshold_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante4:AnalogOffset_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante5:Triggers devAsynInt32::initCommon drvUserCreate
Dante:dante5:Events devAsynInt32::initCommon drvUserCreate
Dante:dante5:FastDeadTime devAsynInt32::initCommon drvUserCreate
Dante:dante5:F1DeadTime devAsynInt32::initCommon drvUserCreate
Dante:dante5:ZeroCounts devAsynInt32::initCommon drvUserCreate
Dante:dante5:BaselineCount devAsynInt32::initCommon drvUserCreate
Dante:dante5:PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante5:F1PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante5:NotF1PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante5:ResetCounts devAsynInt32::initCommon drvUserCreate
Dante:dante5:BaselineSamples_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante5:BaseOffset_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante5:ResetThreshold_RBV devAsynInt32:2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteAnalogOffset
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteTriggers
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteEvents
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteFastDT
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteFilt1DT
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteZeroCounts
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteBaselinesValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DantePUPValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DantePUPF1Value
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DantePUPNotF1Value
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteResetCounterValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteBaselineSamples
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteBaseOffset
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteResetThreshold
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteAnalogOffset
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteTriggers
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteEvents
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteFastDT
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteFilt1DT
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteZeroCounts
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteBaselinesValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DantePUPValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DantePUPF1Value
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DantePUPNotF1Value
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteResetCounterValue
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteBaselineSamples
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteBaseOffset
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteResetThreshold
2023/08/10 15:43:51.825 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteAnalogOffset
2023/08/10 15:43:51.825 asynPortDriver:getAddress: DANTE1 invalid address=7, must be in range 0 to 6
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=0, cannot find parameter MCA_ACQUIRING
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTraceTriggerInstant
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTraceTriggerRising
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTraceTriggerFalling
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteEnableBoard
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteInvertedInput
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteEnableBoard
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteInvertedInput
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteEnableBoard
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteInvertedInput
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteEnableBoard
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteInvertedInput
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteEnableBoard
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteInvertedInput
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteEnableBoard
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteInvertedInput
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteEnableBoard
2023/08/10 15:43:51.830 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteInvertedInput
Dante:dante5:AnalogOffset_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante6:Triggers devAsynInt32::initCommon drvUserCreate
Dante:dante6:Events devAsynInt32::initCommon drvUserCreate
Dante:dante6:FastDeadTime devAsynInt32::initCommon drvUserCreate
Dante:dante6:F1DeadTime devAsynInt32::initCommon drvUserCreate
Dante:dante6:ZeroCounts devAsynInt32::initCommon drvUserCreate
Dante:dante6:BaselineCount devAsynInt32::initCommon drvUserCreate
Dante:dante6:PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante6:F1PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante6:NotF1PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante6:ResetCounts devAsynInt32::initCommon drvUserCreate
Dante:dante6:BaselineSamples_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante6:BaseOffset_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante6:ResetThreshold_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante6:AnalogOffset_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante7:Triggers devAsynInt32::initCommon drvUserCreate
Dante:dante7:Events devAsynInt32::initCommon drvUserCreate
Dante:dante7:FastDeadTime devAsynInt32::initCommon drvUserCreate
Dante:dante7:F1DeadTime devAsynInt32::initCommon drvUserCreate
Dante:dante7:ZeroCounts devAsynInt32::initCommon drvUserCreate
Dante:dante7:BaselineCount devAsynInt32::initCommon drvUserCreate
Dante:dante7:PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante7:F1PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante7:NotF1PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante7:ResetCounts devAsynInt32::initCommon drvUserCreate
Dante:dante7:BaselineSamples_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante7:BaseOffset_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante7:ResetThreshold_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante7:AnalogOffset_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante8:Triggers devAsynInt32::initCommon drvUserCreate
Dante:dante8:Events devAsynInt32::initCommon drvUserCreate
Dante:dante8:FastDeadTime devAsynInt32::initCommon drvUserCreate
Dante:dante8:F1DeadTime devAsynInt32::initCommon drvUserCreate
Dante:dante8:ZeroCounts devAsynInt32::initCommon drvUserCreate
Dante:dante8:BaselineCount devAsynInt32::initCommon drvUserCreate
Dante:dante8:PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante8:F1PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante8:NotF1PileUp devAsynInt32::initCommon drvUserCreate
Dante:dante8:ResetCounts devAsynInt32::initCommon drvUserCreate
Dante:dante8:BaselineSamples_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante8:BaseOffset_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante8:ResetThreshold_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante8:AnalogOffset_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante:MCAAcquiring devAsynInt32::initCommon drvUserCreate
Dante:dante:TraceTriggerInstant_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante:TraceTriggerRising_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante:TraceTriggerFalling_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante1:EnableBoard_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante1:InputPolarity_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante2:EnableBoard_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante2:InputPolarity_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante3:EnableBoard_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante3:InputPolarity_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante4:EnableBoard_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante4:InputPolarity_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante5:EnableBoard_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante5:InputPolarity_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante6:EnableBoard_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante6:InputPolarity_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante7:EnableBoard_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante7:InputPolarity_RBV devAsynInt32:2023/08/10 15:43:51.830 asynPortDriver:getAddress: DANTE1 invalid address=7, must be in range 0 to 6
2023/08/10 15:43:51.832 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteCollectMode
2023/08/10 15:43:51.832 asynPortDriver:drvUserCreate: addr=0, cannot find parameter MCA_NUM_CHANNELS
2023/08/10 15:43:51.832 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteGatingMode
2023/08/10 15:43:51.832 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteInputMode
2023/08/10 15:43:51.832 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteInputMode
2023/08/10 15:43:51.832 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteInputMode
2023/08/10 15:43:51.832 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteInputMode
2023/08/10 15:43:51.832 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteInputMode
2023/08/10 15:43:51.832 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteInputMode
2023/08/10 15:43:51.832 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteInputMode
2023/08/10 15:43:51.832 asynPortDriver:getAddress: DANTE1 invalid address=7, must be in range 0 to 6
2023/08/10 15:43:51.833 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTraceTimeArray
devAsynFloat64Array::initCommon, Dante:dante:TraceTimeArray drvUserCreate failed
2023/08/10 15:43:51.833 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTraceData
devAsynInt32Array::initCommon, Dante:dante1:TraceData drvUserCreate failed
2023/08/10 15:43:51.833 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteTraceData
devAsynInt32Array::initCommon, Dante:dante2:TraceData drvUserCreate failed
2023/08/10 15:43:51.833 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteTraceData
devAsynInt32Array::initCommon, Dante:dante3:TraceData drvUserCreate failed
2023/08/10 15:43:51.833 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteTraceData
devAsynInt32Array::initCommon, Dante:dante4:TraceData drvUserCreate failed
2023/08/10 15:43:51.833 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteTraceData
devAsynInt32Array::initCommon, Dante:dante5:TraceData drvUserCreate failed
2023/08/10 15:43:51.833 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteTraceData
devAsynInt32Array::initCommon, Dante:dante6:TraceData drvUserCreate failed
2023/08/10 15:43:51.833 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteTraceData
devAsynInt32Array::initCommon, Dante:dante7:TraceData drvUserCreate failed
2023/08/10 15:43:51.833 asynPortDriver:getAddress: DANTE1 invalid address=7, must be in range 0 to 6
devAsynInt32Array::initCommon, Dante:dante8:TraceData drvUserCreate failed
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DantePollTime
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter MCA_ELAPSED_REAL
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter MCA_ELAPSED_LIVE
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTraceTime
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTraceTriggerWait
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteMaxEnergy
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteInputCountRate
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteOutputCountRate
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteLastTimeStamp
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteFastFilterThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteEnergyFilterThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteBaselineThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteMaxRiseTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteGain
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DantePeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteMaxPeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteFastPeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteFlatTopRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteFastFlatTopRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteResetRecoveryTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteZeroPeakFreq
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTimeConstant
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteMaxEnergy
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter MCA_ELAPSED_REAL
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter MCA_ELAPSED_LIVE
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteInputCountRate
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteOutputCountRate
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteLastTimeStamp
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteFastFilterThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteEnergyFilterThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteBaselineThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteMaxRiseTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteGain
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DantePeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteMaxPeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteFastPeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteFlatTopRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteFastFlatTopRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteResetRecoveryTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteZeroPeakFreq
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteTimeConstant
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteMaxEnergy
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter MCA_ELAPSED_REAL
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter MCA_ELAPSED_LIVE
Dante:dante8:EnableBoard_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante8:InputPolarity_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante:CollectMode devAsynInt32::initCommon drvUserCreate
Dante:dante:NumMCAChannels devAsynInt32::initCommon drvUserCreate
Dante:dante:GatingMode devAsynInt32::initCommon drvUserCreate
Dante:dante1:InputMode devAsynInt32::initCommon drvUserCreate
Dante:dante2:InputMode devAsynInt32::initCommon drvUserCreate
Dante:dante3:InputMode devAsynInt32::initCommon drvUserCreate
Dante:dante4:InputMode devAsynInt32::initCommon drvUserCreate
Dante:dante5:InputMode devAsynInt32::initCommon drvUserCreate
Dante:dante6:InputMode devAsynInt32::initCommon drvUserCreate
Dante:dante7:InputMode devAsynInt32::initCommon drvUserCreate
Dante:dante8:InputMode devAsynInt32::initCommon drvUserCreate
Dante:dante:PollTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante:ElapsedReal devAsynFloat64::initCommon drvUserCreate
Dante:dante:ElapsedLive devAsynFloat64::initCommon drvUserCreate
Dante:dante:TraceTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante:TraceTriggerWait_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante1:MaxEnergy_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante1:ElapsedRealTime devAsynFloat64::initCommon drvUserCreate
Dante:dante1:ElapsedLiveTime devAsynFloat64::initCommon drvUserCreate
Dante:dante1:InputCountRate devAsynFloat64::initCommon drvUserCreate
Dante:dante1:OutputCountRate devAsynFloat64::initCommon drvUserCreate
Dante:dante1:LastTimeStamp devAsynFloat64::initCommon drvUserCreate
Dante:dante1:FastThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante1:EnergyThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante1:BaselineThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante1:MaxRiseTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante1:Gain_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante1:PeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante1:MaxPeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante1:FastPeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante1:FlatTopTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante1:FastFlatTopTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante1:ResetRecoveryTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante1:ZeroPeakFreq_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante1:TimeConstant_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante2:MaxEnergy_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante2:ElapsedRealTime devAsynFloat64::initCommon drvUserCreate
Dante:dante2:ElapsedLiveTime devAsynFloat64::initCommon drvUserCreate
Dante:dante2:InputCountRate devAsynFloat64::initCommon drvUserCreate
Dante:dante2:OutputCountRate devAsynFloat64::initCommon drvUserCreate
Dante:dante2:LastTimeStamp devAsynFloat64::initCommon drvUserCreate
Dante:dante2:FastThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante2:EnergyThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante2:BaselineThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante2:MaxRiseTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante2:Gain_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante2:PeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante2:MaxPeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante2:FastPeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante2:FlatTopTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante2:FastFlatTopTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante2:ResetRecoveryTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante2:ZeroPeakFreq_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante2:TimeConstant_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante3:MaxEnergy_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante3:ElapsedRealTime devAsynFloat64::initCommon drvUserCreate
Dante:dante3:2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteInputCountRate
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteOutputCountRate
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteLastTimeStamp
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteFastFilterThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteEnergyFilterThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteBaselineThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteMaxRiseTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteGain
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DantePeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteMaxPeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteFastPeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteFlatTopRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteFastFlatTopRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteResetRecoveryTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteZeroPeakFreq
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteTimeConstant
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteMaxEnergy
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter MCA_ELAPSED_REAL
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter MCA_ELAPSED_LIVE
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteInputCountRate
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteOutputCountRate
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteLastTimeStamp
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteFastFilterThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteEnergyFilterThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteBaselineThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteMaxRiseTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteGain
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DantePeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteMaxPeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteFastPeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteFlatTopRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteFastFlatTopRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteResetRecoveryTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteZeroPeakFreq
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteTimeConstant
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteMaxEnergy
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter MCA_ELAPSED_REAL
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter MCA_ELAPSED_LIVE
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteInputCountRate
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteOutputCountRate
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteLastTimeStamp
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteFastFilterThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteEnergyFilterThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteBaselineThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteMaxRiseTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteGain
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DantePeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteMaxPeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteFastPeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteFlatTopRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteFastFlatTopRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteResetRecoveryTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteZeroPeakFreq
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteTimeConstant
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteMaxEnergy
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter MCA_ELAPSED_REAL
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter MCA_ELAPSED_LIVE
Dante:dante3:InputCountRate devAsynFloat64::initCommon drvUserCreate
Dante:dante3:OutputCountRate devAsynFloat64::initCommon drvUserCreate
Dante:dante3:LastTimeStamp devAsynFloat64::initCommon drvUserCreate
Dante:dante3:FastThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante3:EnergyThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante3:BaselineThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante3:MaxRiseTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante3:Gain_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante3:PeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante3:MaxPeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante3:FastPeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante3:FlatTopTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante3:FastFlatTopTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante3:ResetRecoveryTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante3:ZeroPeakFreq_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante3:TimeConstant_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante4:MaxEnergy_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante4:ElapsedRealTime devAsynFloat64::initCommon drvUserCreate
Dante:dante4:ElapsedLiveTime devAsynFloat64::initCommon drvUserCreate
Dante:dante4:InputCountRate devAsynFloat64::initCommon drvUserCreate
Dante:dante4:OutputCountRate devAsynFloat64::initCommon drvUserCreate
Dante:dante4:LastTimeStamp devAsynFloat64::initCommon drvUserCreate
Dante:dante4:FastThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante4:EnergyThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante4:BaselineThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante4:MaxRiseTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante4:Gain_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante4:PeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante4:MaxPeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante4:FastPeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante4:FlatTopTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante4:FastFlatTopTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante4:ResetRecoveryTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante4:ZeroPeakFreq_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante4:TimeConstant_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante5:MaxEnergy_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante5:ElapsedRealTime devAsynFloat64::initCommon drvUserCreate
Dante:dante5:ElapsedLiveTime devAsynFloat64::initCommon drvUserCreate
Dante:dante5:InputCountRate devAsynFloat64::initCommon drvUserCreate
Dante:dante5:OutputCountRate devAsynFloat64::initCommon drvUserCreate
Dante:dante5:LastTimeStamp devAsynFloat64::initCommon drvUserCreate
Dante:dante5:FastThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante5:EnergyThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante5:BaselineThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante5:MaxRiseTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante5:Gain_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante5:PeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante5:MaxPeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante5:FastPeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante5:FlatTopTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante5:FastFlatTopTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante5:ResetRecoveryTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante5:ZeroPeakFreq_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante5:TimeConstant_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante6:MaxEnergy_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante6:ElapsedRealTime devAsynFloat64::initCommon drvUserCreate
Dante2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteInputCountRate
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteOutputCountRate
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteLastTimeStamp
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteFastFilterThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteEnergyFilterThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteBaselineThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteMaxRiseTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteGain
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DantePeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteMaxPeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteFastPeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteFlatTopRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteFastFlatTopRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteResetRecoveryTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteZeroPeakFreq
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteTimeConstant
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteMaxEnergy
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter MCA_ELAPSED_REAL
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter MCA_ELAPSED_LIVE
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteInputCountRate
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteOutputCountRate
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteLastTimeStamp
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteFastFilterThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteEnergyFilterThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteBaselineThresholdRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteMaxRiseTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteGain
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DantePeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteMaxPeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteFastPeakingTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteFlatTopRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteFastFlatTopRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteResetRecoveryTimeRBV
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteZeroPeakFreq
2023/08/10 15:43:51.835 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteTimeConstant
2023/08/10 15:43:51.835 asynPortDriver:getAddress: DANTE1 invalid address=7, must be in range 0 to 6
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteMappingPoints
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteListBufferSize
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTraceTriggerLevel
:dante6:ElapsedLiveTime devAsynFloat64::initCommon drvUserCreate
Dante:dante6:InputCountRate devAsynFloat64::initCommon drvUserCreate
Dante:dante6:OutputCountRate devAsynFloat64::initCommon drvUserCreate
Dante:dante6:LastTimeStamp devAsynFloat64::initCommon drvUserCreate
Dante:dante6:FastThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante6:EnergyThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante6:BaselineThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante6:MaxRiseTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante6:Gain_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante6:PeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante6:MaxPeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante6:FastPeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante6:FlatTopTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante6:FastFlatTopTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante6:ResetRecoveryTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante6:ZeroPeakFreq_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante6:TimeConstant_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante7:MaxEnergy_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante7:ElapsedRealTime devAsynFloat64::initCommon drvUserCreate
Dante:dante7:ElapsedLiveTime devAsynFloat64::initCommon drvUserCreate
Dante:dante7:InputCountRate devAsynFloat64::initCommon drvUserCreate
Dante:dante7:OutputCountRate devAsynFloat64::initCommon drvUserCreate
Dante:dante7:LastTimeStamp devAsynFloat64::initCommon drvUserCreate
Dante:dante7:FastThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante7:EnergyThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante7:BaselineThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante7:MaxRiseTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante7:Gain_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante7:PeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante7:MaxPeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante7:FastPeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante7:FlatTopTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante7:FastFlatTopTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante7:ResetRecoveryTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante7:ZeroPeakFreq_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante7:TimeConstant_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante8:MaxEnergy_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante8:ElapsedRealTime devAsynFloat64::initCommon drvUserCreate
Dante:dante8:ElapsedLiveTime devAsynFloat64::initCommon drvUserCreate
Dante:dante8:InputCountRate devAsynFloat64::initCommon drvUserCreate
Dante:dante8:OutputCountRate devAsynFloat64::initCommon drvUserCreate
Dante:dante8:LastTimeStamp devAsynFloat64::initCommon drvUserCreate
Dante:dante8:FastThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante8:EnergyThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante8:BaselineThreshold_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante8:MaxRiseTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante8:Gain_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante8:PeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante8:MaxPeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante8:FastPeakingTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante8:FlatTopTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante8:FastFlatTopTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante8:ResetRecoveryTime_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante8:ZeroPeakFreq_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante8:TimeConstant_RBV devAsynFloat64::initCommon drvUserCreate
Dante:dante:MappingPoints devAsynInt32::initCommon drvUserCreate
Dante:dante:ListBufferSize devAsynInt32::initCommon drvUserCreate
Dant2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTraceLength
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteBaselineSamples
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteBaseOffset
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteResetThreshold
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteAnalogOffset
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteBaselineSamples
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteBaseOffset
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteResetThreshold
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteAnalogOffset
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteBaselineSamples
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteBaseOffset
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteResetThreshold
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteAnalogOffset
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteBaselineSamples
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteBaseOffset
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteResetThreshold
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteAnalogOffset
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteBaselineSamples
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteBaseOffset
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteResetThreshold
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteAnalogOffset
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteBaselineSamples
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteBaseOffset
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteResetThreshold
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteAnalogOffset
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteBaselineSamples
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteBaseOffset
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteResetThreshold
2023/08/10 15:43:51.837 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteAnalogOffset
2023/08/10 15:43:51.837 asynPortDriver:getAddress: DANTE1 invalid address=7, must be in range 0 to 6
2023/08/10 15:43:51.842 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteCollectMode
2023/08/10 15:43:51.842 asynPortDriver:drvUserCreate: addr=0, cannot find parameter MCA_NUM_CHANNELS
2023/08/10 15:43:51.842 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteGatingMode
2023/08/10 15:43:51.842 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteInputMode
2023/08/10 15:43:51.842 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteInputMode
2023/08/10 15:43:51.842 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteInputMode
2023/08/10 15:43:51.842 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteInputMode
2023/08/10 15:43:51.842 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteInputMode
2023/08/10 15:43:51.842 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteInputMode
2023/08/10 15:43:51.842 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteInputMode
2023/08/10 15:43:51.842 asynPortDriver:getAddress: DANTE1 invalid address=7, must be in range 0 to 6
2023/08/10 15:43:51.843 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteEnableConfigure
2023/08/10 15:43:51.843 asynPortDriver:drvUserCreate: addr=0, cannot find parameter MCA_START_ACQUIRE
2023/08/10 15:43:51.843 asynPortDriver:drvUserCreate: addr=0, cannot find parameter MCA_STOP_ACQUIRE
2023/08/10 15:43:51.843 asynPortDriver:drvUserCreate: addr=0, cannot find parameter MCA_READ_STATUS
2023/08/10 15:43:51.843 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteKeepAlive
2023/08/10 15:43:51.843 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteReadTrace
2023/08/10 15:43:51.844 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTraceTriggerInstant
2023/08/10 15:43:51.844 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTraceTriggerRising
2023/08/10 15:43:51.844 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteTraceTriggerFalling
2023/08/10 15:43:51.844 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteEnableBoard
2023/08/10 15:43:51.844 asynPortDriver:drvUserCreate: addr=0, cannot find parameter DanteInvertedInput
2023/08/10 15:43:51.844 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteEnableBoard
2023/08/10 15:43:51.844 asynPortDriver:drvUserCreate: addr=1, cannot find parameter DanteInvertedInput
2023/08/10 15:43:51.844 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteEnableBoard
2023/08/10 15:43:51.844 asynPortDriver:drvUserCreate: addr=2, cannot find parameter DanteInvertedInput
2023/08/10 15:43:51.844 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteEnableBoard
2023/08/10 15:43:51.844 asynPortDriver:drvUserCreate: addr=3, cannot find parameter DanteInvertedInput
e:dante:TraceTriggerLevel devAsynInt32::initCommon drvUserCreate
Dante:dante:TraceLength devAsynInt32::initCommon drvUserCreate
Dante:dante1:BaselineSamples devAsynInt32::initCommon drvUserCreate
Dante:dante1:BaseOffset devAsynInt32::initCommon drvUserCreate
Dante:dante1:ResetThreshold devAsynInt32::initCommon drvUserCreate
Dante:dante1:AnalogOffset devAsynInt32::initCommon drvUserCreate
Dante:dante2:BaselineSamples devAsynInt32::initCommon drvUserCreate
Dante:dante2:BaseOffset devAsynInt32::initCommon drvUserCreate
Dante:dante2:ResetThreshold devAsynInt32::initCommon drvUserCreate
Dante:dante2:AnalogOffset devAsynInt32::initCommon drvUserCreate
Dante:dante3:BaselineSamples devAsynInt32::initCommon drvUserCreate
Dante:dante3:BaseOffset devAsynInt32::initCommon drvUserCreate
Dante:dante3:ResetThreshold devAsynInt32::initCommon drvUserCreate
Dante:dante3:AnalogOffset devAsynInt32::initCommon drvUserCreate
Dante:dante4:BaselineSamples devAsynInt32::initCommon drvUserCreate
Dante:dante4:BaseOffset devAsynInt32::initCommon drvUserCreate
Dante:dante4:ResetThreshold devAsynInt32::initCommon drvUserCreate
Dante:dante4:AnalogOffset devAsynInt32::initCommon drvUserCreate
Dante:dante5:BaselineSamples devAsynInt32::initCommon drvUserCreate
Dante:dante5:BaseOffset devAsynInt32::initCommon drvUserCreate
Dante:dante5:ResetThreshold devAsynInt32::initCommon drvUserCreate
Dante:dante5:AnalogOffset devAsynInt32::initCommon drvUserCreate
Dante:dante6:BaselineSamples devAsynInt32::initCommon drvUserCreate
Dante:dante6:BaseOffset devAsynInt32::initCommon drvUserCreate
Dante:dante6:ResetThreshold devAsynInt32::initCommon drvUserCreate
Dante:dante6:AnalogOffset devAsynInt32::initCommon drvUserCreate
Dante:dante7:BaselineSamples devAsynInt32::initCommon drvUserCreate
Dante:dante7:BaseOffset devAsynInt32::initCommon drvUserCreate
Dante:dante7:ResetThreshold devAsynInt32::initCommon drvUserCreate
Dante:dante7:AnalogOffset devAsynInt32::initCommon drvUserCreate
Dante:dante8:BaselineSamples devAsynInt32::initCommon drvUserCreate
Dante:dante8:BaseOffset devAsynInt32::initCommon drvUserCreate
Dante:dante8:ResetThreshold devAsynInt32::initCommon drvUserCreate
Dante:dante8:AnalogOffset devAsynInt32::initCommon drvUserCreate
Dante:dante:CollectMode_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante:NumMCAChannels_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante:GatingMode_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante1:InputMode_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante2:InputMode_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante3:InputMode_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante4:InputMode_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante5:InputMode_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante6:InputMode_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante7:InputMode_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante8:InputMode_RBV devAsynInt32::initCommon drvUserCreate
Dante:dante:EnableConfigure devAsynInt32::initCommon drvUserCreate
Dante:dante:StartAll devAsynInt32::initCommon drvUserCreate
Dante:dante:StopAll devAsynInt32::initCommon drvUserCreate
Dante:dante:DoReadAll1 devAsynInt32::initCommon drvUserCreate
Dante:dante:KeepAlive devAsynInt32::initCommon drvUserCreate
Dante:dante:ReadTrace devAsynInt32::initCommon drvUserCreate
Dante:dante:TraceTriggerInstant devAsynInt32::initCommon drvUserCreate
Dante:dante:TraceTriggerRising devAsynInt32::initCommon drvUserCreate
Dante:dante:TraceTriggerFalling devAsynInt32::initCommon drvUserCreate
Dante:dante1:EnableBoard devAsynInt32::initCommon drvUserCreate
Dante:dante1:InputPolarity devAsynInt32::initCommon drvUserCreate
Dante:dante2:EnableBoard devAsynInt32::initCommon drvUserCreate
Dante:dante2:InputPolarity devAsynInt32::initCommon drvUserCreate
Dante:dante3:EnableBoard devAsynInt32::initCommon drvUserCreate
Dante:dante3:InputPolarity devAsynInt32::initCommon drvUserCreate
Dante:dante4:EnableBoard devAsynInt32::initCommon drvUserCreate
Dante:dante4:InputPolarity devAsynIn2023/08/10 15:43:51.844 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteEnableBoard
2023/08/10 15:43:51.844 asynPortDriver:drvUserCreate: addr=4, cannot find parameter DanteInvertedInput
2023/08/10 15:43:51.844 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteEnableBoard
2023/08/10 15:43:51.844 asynPortDriver:drvUserCreate: addr=5, cannot find parameter DanteInvertedInput
2023/08/10 15:43:51.844 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteEnableBoard
2023/08/10 15:43:51.844 asynPortDriver:drvUserCreate: addr=6, cannot find parameter DanteInvertedInput
2023/08/10 15:43:51.844 asynPortDriver:getAddress: DANTE1 invalid address=7, must be in range 0 to 6
2023/08/10 15:43:51.847 asynPortDriver:drvUserCreate: addr=0, cannot find parameter MCA_DATA
2023/08/10 15:43:51.847 devMcaAsyn::findDrvInfo, Dante:mca1 drvUserCreate failed for MCA_DATA
2023/08/10 15:43:51.847 asynPortDriver:setIntegerParam: port=DANTE1 error setting parameter 0 in list 0, wrong type
2023/08/10 15:43:51.847 asynPortDriver:getIntegerParam: port=DANTE1 error getting parameter 0 PORT_NAME_SELF, in list 0, wrong type
2023/08/10 15:43:51.847 asynPortDriver:getDoubleParam: port=DANTE1 error getting parameter 0 PORT_NAME_SELF, in list 0, wrong type
< envPaths
# Tell EPICS all about the record types, device-support modules, drivers,
# etc. in this build from dxpApp
dbLoadDatabase("$(DANTE)/dbd/mcaDanteApp.dbd")
mcaDanteApp_registerRecordDeviceDriver(pdbbase)
# The search path for database files
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "$(ADCORE)/db")
# Prefix for all records
epicsEnvSet("PREFIX", "Dante:")
# The port name for the detector
epicsEnvSet("PORT", "DANTE1")
# The queue size for all plugins
epicsEnvSet("QSIZE", "20")
# The maximum image width; used to set the maximum size for row profiles in the NDPluginStats plugin
epicsEnvSet("XSIZE", "1024")
# The maximum image height; used to set the maximum size for column profiles in the NDPluginStats plugin
epicsEnvSet("YSIZE", "1024")
# The maximum number of time series points in the NDPluginStats plugin
epicsEnvSet("NCHANS", "2048")
# The maximum number of frames buffered in the NDPluginCircularBuff plugin
epicsEnvSet("CBUFFS", "500")
# The maximum number of threads for plugins which can run in multiple threads
epicsEnvSet("MAX_THREADS", "8")
# The maximum number of channels in the MCA records
epicsEnvSet("MCA_CHANS", "2048")
# The maximum number of points in the ADC trace waveform records
epicsEnvSet("TRACE_LEN", "16384")
# DanteConfig(portName, ipAddress, numDetectors, maxBuffers, maxMemory)
DanteConfig("$(PORT)", 172.16.0.120, 6, 0, 0)
dbLoadTemplate($(DANTE)/db/"dante8.substitutions", "P=$(PREFIX), NCHAN=$(MCA_CHANS), TRACE_LEN=$(TRACE_LEN)")
# Load all other plugins using commonPlugins.cmd
< $(ADCORE)/iocBoot/commonPlugins.cmd
set_requestfile_path("$(DANTE)/danteApp/Db")
set_requestfile_path("$(MCA)/mcaApp/Db")
asynSetTraceIOMask($(PORT),0,ESCAPE)
#asynSetTraceMask($(PORT),0,ERROR|WARNING)
iocInit
seq danteMED "P=$(PREFIX), DANTE=dante, MCA=mca, N_DETECTORS=8")
### Start up the autosave task and tell it what to do.
# Save settings every thirty seconds
create_monitor_set("auto_settings.req", 30, "P=$(PREFIX), R=dante:, M=mca1")
# Wait 5 seconds for all records with PINI=YES to process
epicsThreadSleep(5)
# Enable downloading configurations
dbpf("$(PREFIX)dante:EnableConfigure", "Enable")
# There is a problem with the GatingMode record.
# Even though it has PINI=YES and has already processed and written the value to the Dante,
# the value appears to have been changed, and it need to be processed again.
# This needs to be tracked down.
dbpf("$(PREFIX)dante:GatingMode.PROC", "1")
- Re: Dante-1-1 Mark Rivers via Tech-talk
- static libraries Siddons, David via Tech-talk
EPICS documentation community survey NICOLE Remi via Tech-talk
<2023>
Reminder: EPICS documentation community survey NICOLE Remi via Tech-talk
<2023>
