1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: static libraries
From: "Siddons, David via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 18 Sep 2023 18:32:19 +0000
Hi Tech-talk,
I need to use a library in an EPICS app, set up using MakeBaseApp. It wants to have a static version of the library, which the library package doesn't supply. Why does it need the static library? I'm not trying to build a static program. Here's the Makefile fragment which builds it:
PROD_HOST += display
display_SRCS   += display.c
display_LIBS   += ezca
display_DIR    = /usr/local/lib/
display_LIBS   += ssd1306_i2c
display_LIBS   += $(EPICS_BASE_HOST_LIBS)
and it gives:
make[1]: *** No rule to make target '../../lib/linux-arm/libssd1306_i2c.a', need
ed by 'display'.  Stop.
I'm building it natively on a Zynq Debian 10 system. The shared libraries are in /usr/local/lib:
/usr/local/lib/libssd1306_i2c.la  /usr/local/lib/libssd1306_i2c.so.0
/usr/local/lib/libssd1306_i2c.so  /usr/local/lib/libssd1306_i2c.so.0.0.3
Pete.
Re: static libraries Mark Rivers via Tech-talk
Fw: Dante-1-1 Siddons, David via Tech-talk
Prev: Re: Monitor timeouts with asyn/StreamDevice, and issues in DRTO with UDP Mark Rivers via Tech-talk
Next: Re: static libraries Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Re: Dante-1-1 Siddons, David via Tech-talk
ANJ, 18 Sep 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
