> -----Original Message-----
> From: Torsten Bögershausen <torsten.bogershausen at ess.eu>
> Sent: Monday, August 21, 2023 12:20 PM
> To: Leblanc, Gregory <leblanc at ohio.edu>
> Cc: tech-talk at aps.anl.gov
> Subject: Re: [External] Trouble with pva:// on Phoebus with often-restarted IOCs
> Hej Greg,
> … Can I force it to listen on 5076…
> Typically not.
> The TCP/IP stack is thinking that 5076 is “not allowed” (please forgive my
> wording, network experts) There may be different reasons:
> The port is "in use”, and that’s the end of the story.
> the lsof command should report it.
That's what I was assuming. For some reason it thinks something is already listening on 5076, so it can't grab that port. I thought maybe it could be configured to quit with an error instead of trying a dynamic port, but looking at blockingTCPAcceptor.cpp, I don't see anything in there that would DWIW.
> Or, it has been in use, and now it is in the “time wait” state.
> This state should be released after typically 120 seconds or so.
> So please be aware that things may change while you are debugging.
> What does
> netstat -a -n -t | grep 5076
> give you ?
Hmm, I didn't realize that the timeout was as long as 2 minutes. netstat -a -n -t | grep 5076 always returns nothing. netstat -a -n -t | grep 5075 returns the following when my IOC is listening on a non-random port:
tcp 0 0 0.0.0.0:5075 0.0.0.0:* LISTEN
netstat -lut |grep 5076 returns the following under the same circumstances (but returns nothing on 5075):
udp 0 0 224.0.0.128:5076 0.0.0.0:*
udp 0 0 10.0.255.255:5076 0.0.0.0:*
udp 0 0 epics2:5076 0.0.0.0:*
I also used lsof -I :507x and got the following:
$ lsof -i :5076
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
st.cmd 76083 eal 8u IPv4 372679 0t0 UDP epics2:5076
st.cmd 76083 eal 9u IPv4 372680 0t0 UDP 10.0.255.255:5076
st.cmd 76083 eal 10u IPv4 372681 0t0 UDP 224.0.0.128:5076
st.cmd 76083 eal 17u IPv4 372689 0t0 UDP epics2:5076
st.cmd 76083 eal 18u IPv4 372690 0t0 UDP 10.0.255.255:5076
st.cmd 76083 eal 19u IPv4 372691 0t0 UDP 224.0.0.128:5076
$ lsof -i :5075
st.cmd 76083 eal 14u IPv4 372687 0t0 TCP *:pvaccess (LISTEN)
From some further reading, it looks like setting SO_REUSEPORT will make the problem disappear, at least on linux kernels newer than 3.9, and the BSDs. Looks like a tangled mess of portability garbage between that and SO_REUSEADDR to make it work on windows as well, and I've got no idea what RTEMS and VxWorks might implement. For me it's not worth barking up that tree. I think I've at least temporarily fixed it by doing `sudo sysctl -w net.ipv4.tcp_tw_reuse=1` and ` sudo sysctl -w net.ipv4.tcp_fin_timeout=1` which I think sets the timeout to 1 second. Although this solution doesn't seem to be very robust, if I can fix it by waiting 2 minutes, I can probably live with that as well.
Greg
Gregory Leblanc
Accelerator Engineer
Edwards Accelerator Lab - Ohio University
123 University Terrace
Athens, OH 45701 USA
leblanc at ohio.edu
M: (401) 52-OUAL1 or (401) 526-8251
- Trouble with pva:// on Phoebus with often-restarted IOCs Leblanc, Gregory via Tech-talk
- RE: [External] Trouble with pva:// on Phoebus with often-restarted IOCs Leblanc, Gregory via Tech-talk
- Re: [External] Trouble with pva:// on Phoebus with often-restarted IOCs Torsten Bögershausen via Tech-talk
Re: [External] Trouble with pva:// on Phoebus with often-restarted IOCs Michael Davidsaver via Tech-talk
<2023>
2025
<2023>
2025
