1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: compilation error with stream device
From: Vishnu Patel via Tech-talk <[email protected]>
To: Zimoch Dirk <[email protected]>, "Tech Talk ([email protected])" <[email protected]>
Date: Wed, 30 Aug 2023 08:51:50 +0000
Dear Dirk,
        Thank you for quick reply.
Now i have next error with epicsShareFunc.
I am using base-7.0.7 and asyn-R4-43
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I../../../..//asyn-R4-43/include   -I../../../..//calc/include   -I../../../..//sscan/include -I../../../../../base-7.0.7/include/compiler/gcc -I../../../../../base-7.0.7/include/os/Linux -I../../../../../base-7.0.7/include        -c ../StreamEpics.cc
In file included from ../../../../../base-7.0.7/include/dbStaticLib.h:23,
                 from ../StreamEpics.cc:39:
../../../../../base-7.0.7/include/dbBase.h:164:22: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
  164 |     rset            *prset;
In file included from ../../../../../base-7.0.7/include/dbBase.h:22,
../../../../../base-7.0.7/include/recSup.h:89:21: note: declared here
   89 | typedef struct rset rset EPICS_DEPRECATED;
../StreamEpics.cc:72:1: error: ‘epicsShareFunc’ does not name a type
   72 | epicsShareFunc int epicsShareAPI iocshCmd(const char *command);
../StreamEpics.cc:72:1: note: the macro ‘epicsShareFunc’ had not yet been defined
In file included from ../devStream.h:64,
                 from ../StreamEpics.cc:80:
../../../../../base-7.0.7/include/shareLib.h:169: note: it was later defined here
  169 | #   define epicsShareFunc __attribute__ ((visibility("default")))
In file included from ../../../../../base-7.0.7/include/dbAccess.h:24,
                 from ../devStream.h:57,
../../../../../base-7.0.7/include/dbAccessDefs.h:210:55: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
  210 | DBCORE_API rset * dbGetRset(const struct dbAddr *paddr);
make[3]: *** [../../../../../base-7.0.7/configure/RULES_BUILD:263: StreamEpics.o] Error 1
make[3]: Leaving directory '/opt/epics/support/stream/StreamDevice/src/O.linux-x86_64'
make[2]: *** [../../../../base-7.0.7/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[2]: Leaving directory '/opt/epics/support/stream/StreamDevice/src'
make[1]: *** [../../../base-7.0.7/configure/RULES_DIRS:85: src.install] Error 2
make[1]: Leaving directory '/opt/epics/support/stream/StreamDevice'
make: *** [configure/RULES_DIRS:88: StreamDevice.install] Error 2
Thank you
Vishnu
Sent: 29 August 2023 17:03
To: Vishnu Patel <[email protected]>; Tech Talk ([email protected]) <[email protected]>
Subject: RE: compilation error with stream device
Hello Vishnu,
The scalcout record type is in the "calc" module which is part of SynApps.
You can either build StreamDevice without support for scalcout or you have to add the calc module to your project.
Dirk
From: Tech-talk <[email protected]> On Behalf Of Vishnu Patel via Tech-talk
Sent: Dienstag, 29. August 2023 12:42
To: Tech Talk ([email protected]) <[email protected]>
Subject: compilation error with stream device
    I am using stream device in my application.
with stream device i am getting error below
usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE        -DUSE_TYPED_RSET  -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/opt/epics/support/s7nodave-3.0.2/include   -I/opt/epics/support/seq-2.2.5/include   -I/opt/epics/support/asyn-R4-43/include   -I/opt/epics/support/modbus/include   -I/opt/epics/support/stream/include -I/opt/epics/base-7.0.7/include/compiler/gcc -I/opt/epics/base-7.0.7/include/os/Linux -I/opt/epics/base-7.0.7/include        -MM -MF lcpcMain.d  ../lcpcMain.cpp
Creating dbd file lcpc.dbd
perl -CSD /opt/epics/base-7.0.7/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/opt/epics/support/s7nodave-3.0.2/dbd -I/opt/epics/support/seq-2.2.5/dbd -I/opt/epics/support/asyn-R4-43/dbd -I/opt/epics/support/modbus/dbd -I/opt/epics/support/stream/dbd -I/opt/epics/base-7.0.7/dbd -o lcpc.dbd base.dbd xxxSupport.dbd dbSub.dbd devlcpcVersion.dbd lcpcHello.dbd initTrace.dbd s7nodave.dbd asyn.dbd drvAsynSerialPort.dbd drvAsynIPPort.dbd stream.dbd modbusSupport.dbd sncExample.dbd PVAServerRegister.dbd qsrv.dbd
dbdExpand.pl: Device 'stream' refers to unknown record type 'scalcout'.
      DBD files must be combined in the correct order.
Context: file '/opt/epics/support/stream/dbd/stream.dbd'
  while reading 'stream.dbd' to create 'lcpc.dbd'
dbdExpand.pl: Exiting due to errors
make[3]: *** [/opt/epics/base-7.0.7/configure/RULES.Db:406: ../O.Common/lcpc.dbd] Error 255
make[3]: Leaving directory '/home/ipr/epicsDev/lcpc/lcpcApp/src/O.linux-x86_64'
make[2]: *** [/opt/epics/base-7.0.7/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[2]: Leaving directory '/home/ipr/epicsDev/lcpc/lcpcApp/src'
make[1]: *** [/opt/epics/base-7.0.7/configure/RULES_DIRS:85: src.install] Error 2
make[1]: Leaving directory '/home/ipr/epicsDev/lcpc/lcpcApp'
make: *** [/opt/epics/base-7.0.7/configure/RULES_DIRS:85: lcpcApp.install] Error 2
dbd  order in make file is
# lcpc.dbd will include these files:
lcpc_DBD += base.dbd
lcpc_DBD += xxxSupport.dbd
lcpc_DBD += dbSub.dbd
lcpc_DBD += devlcpcVersion.dbd
lcpc_DBD += lcpcHello.dbd
lcpc_DBD += initTrace.dbd
lcpc_DBD += s7nodave.dbd
lcpc_DBD += asyn.dbd
lcpc_DBD += drvAsynSerialPort.dbd
lcpc_DBD += drvAsynIPPort.dbd
lcpc_DBD += stream.dbd
lcpc_DBD += modbusSupport.dbd
what can be the reason for error?
Thanks
Vishnu
RE: compilation error with stream device Zimoch Dirk via Tech-talk
compilation error with stream device Vishnu Patel via Tech-talk
Prev: Re: PV Access timeout Hu, Yong via Tech-talk
Next: RE: compilation error with stream device Zimoch Dirk via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: RE: compilation error with stream device Zimoch Dirk via Tech-talk
