1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: PVA gateway status PV monitoring
From: "Ha, Kiman via Tech-talk" <[email protected]>
To: "Murray, Doug" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 1 Sep 2023 15:44:40 +0000
Hi Doug,
Thank you for the helpful information for understanding (some PVs through RPC).
I also did install python “virtualenv p4ptest” and it seems to have the same status with compiled p4p, still sees.
INFO:p4p.gw:Status PV: sts_server:StatsTime
INFO:p4p.gw:Status PV: sts_client:StatsTime
Here are simple tests using pvget.
sts_client:us:byhost:rx (p4ptest) [p4ptest]$ pvget sts_server:us:byhost:rx
sts_server:us:byhost:rx 2023-09-01 11:30:54.005
          Server "RX (B/s)"
10.0.142.27:5075        0.8
(p4ptest)[p4ptest]$ pvget sts_server:us:byhost:tx
sts_server:us:byhost:tx 2023-09-01 11:30:54.005
          Server "TX (B/s)"
>> gateway in the background by typing “pvagw &”, at least for testing purposes.
Yes, it is also working for my test.
Thanks!
Kiman
Sent: Friday, September 1, 2023 7:53 AM
To: Ha, Kiman <[email protected]>; [email protected]
Subject: Re: PVA gateway status PV monitoring
Hi again Kiman,
I wanted to let you know that the PVA gateway documentation was recently updated (within the hour prior to this message), at https://mdavidsaver.github.io/p4p/gw.html
cheers
-doug
SLAC
Date: Thursday, August 31, 2023 at 11:15 PM
To: Ha, Kiman <[email protected]>, [email protected] <[email protected]>
Hi Kiman,
The status PVs should be accessible as regular PVs using pvget or pvcall.
If you have the latest version of the p4p gateway, and the statusprefix is set to sts_server: as you’ve indicated, you could type:
pvget  sts_server:clients
pvget  sts_server:cache
and so forth.
The asTest PV is different because it uses RPC, so you could type:
                pvcall sts_server:asTest  pv=”my:pv:name”
(using one of your own PVs instead of my:pv:name)
I’m wondering if you have a previous version of the gateway because, for example mine doesn’t show a StatsTime PV.
Also you should be able to run the gateway in the background by typing “pvagw &”, at least for testing purposes.  Ideally, it would be run through something like systemd, depending on your host.
cheers
-doug
SLAC
From: Tech-talk <[email protected]> on behalf of Ha, Kiman via Tech-talk <[email protected]>
Date: Thursday, August 31, 2023 at 11:46 AM
To: [email protected] <[email protected]>
Subject: PVA gateway status PV monitoring
Hello All,
I am testing the PVA gateway and completing the installation of the PVXS and P4P modules.
In the first test, I can read/write device IOC PVs from a client, which means the pva gateway works fine.
In the next step, I’d like to monitor pvagateway provided server/clients status PVs; for example, read this PV “sts_server:StatsTime” from the client.
How do I read pvagateway internal PVs?
Would you like me to install p4p python packages?
I just run pvagw mytest.config, any more efficient way to run pvagw as background?
p4p]$ bin/linux-x86_64/pvagw mytest.conf
INFO:p4p.gw:Client theclient input config:
INFO:p4p.gw:Status PV: sts_server:asDebug
INFO:p4p.gw:Status PV: sts_server:asTest
INFO:p4p.gw:Status PV: sts_server:cache
INFO:p4p.gw:Status PV: sts_server:clients
INFO:p4p.gw:Status PV: sts_server:ds:byhost:rx
INFO:p4p.gw:Status PV: sts_server:ds:byhost:tx
INFO:p4p.gw:Status PV: sts_server:ds:bypv:rx
INFO:p4p.gw:Status PV: sts_server:ds:bypv:tx
INFO:p4p.gw:Status PV: sts_server:poke
INFO:p4p.gw:Status PV: sts_server:refs
INFO:p4p.gw:Status PV: sts_server:stats
INFO:p4p.gw:Status PV: sts_server:threads
INFO:p4p.gw:Status PV: sts_server:us:byhost:rx
INFO:p4p.gw:Status PV: sts_server:us:byhost:tx
INFO:p4p.gw:Status PV: sts_server:us:bypv:rx
INFO:p4p.gw:Status PV: sts_server:us:bypv:tx
INFO:p4p.gw:Server effective config stserver_0 :
INFO:p4p.gw:Status PV: sts_client:asDebug
INFO:p4p.gw:Status PV: sts_client:asTest
INFO:p4p.gw:Status PV: sts_client:cache
INFO:p4p.gw:Status PV: sts_client:clients
INFO:p4p.gw:Status PV: sts_client:ds:byhost:rx
INFO:p4p.gw:Status PV: sts_client:ds:byhost:tx
INFO:p4p.gw:Status PV: sts_client:ds:bypv:rx
INFO:p4p.gw:Status PV: sts_client:ds:bypv:tx
INFO:p4p.gw:Status PV: sts_client:poke
INFO:p4p.gw:Status PV: sts_client:refs
INFO:p4p.gw:Status PV: sts_client:stats
INFO:p4p.gw:Status PV: sts_client:threads
INFO:p4p.gw:Status PV: sts_client:us:byhost:rx
INFO:p4p.gw:Status PV: sts_client:us:byhost:tx
INFO:p4p.gw:Status PV: sts_client:us:bypv:rx
INFO:p4p.gw:Status PV: sts_client:us:bypv:tx
INFO:p4p.gw:Setup GW clients to ignore GW servers
Kiman
PVA gateway status PV monitoring Ha, Kiman via Tech-talk
Re: PVA gateway status PV monitoring Murray, Doug via Tech-talk
Prev: Re: Dante Mark Rivers via Tech-talk
Next: RE: [External] Requesting EPICS-Related Source Code and Documentation Leblanc, Gregory via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: PVA gateway status PV monitoring Murray, Doug via Tech-talk
Next: Requesting Feedback and Support in Consolidating Source Code and Documentation McNanney, Douglas via Tech-talk
