1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: EPICS Ethercat motor driver
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: Jörn Dreyer <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 5 Sep 2023 14:23:04 +0000
Hej Jörn,
there is a lot of source code available ;-)
I think that you can re-use a lot of stuff...
Should we set up a video call to make an introduction ?
BR
/Torsten
On 2023-09-05, 16:03, "Tech-talk on behalf of Jörn Dreyer via Tech-talk" <[email protected] <mailto:[email protected]> on behalf of [email protected] <mailto:[email protected]>> wrote:
Hello,
I need to setup a three axes positioning system. I plan to use the ethercatMC
module for that, as our final controller hardware will be based on Beckhoff
Ethercat stepper motor controllers.
I was reading the source code but did not figure out how to implement the
needed axes in my TwinCAT project. Is there any documentation beyond the
source code available?
Regards
Jörn Dreyer
EPICS Ethercat motor driver Jörn Dreyer via Tech-talk
Prev: EPICS Ethercat motor driver Jörn Dreyer via Tech-talk
Next: Re: pheobus on AlmaLinux9 Tynan Ford via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: Static Database Access 顾月良 via Tech-talk
