1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: pheobus on AlmaLinux9
To: Michael Davidsaver <[email protected]>
Cc: James G Smedinghoff <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 5 Sep 2023 08:11:02 -0700
Hi Pierrick,
You could try to force phoebus to run with gtk2 and see if that helps - https://github.com/ControlSystemStudio/phoebus/wiki/Graphics-Performance#javafx-settings
Also a side note, x-forwarding doesn't always work well, we have found that tools like VNC work much more reliably for Phoebus.
Tynan
On Fri, Sep 1, 2023 at 12:14 AM Michael Davidsaver via Tech-talk <[email protected]> wrote:
On 8/31/23 18:20, Pierrick M Hanlet via Tech-talk wrote:
> Greetings,
> We are migrating our controls network to Alma Linux 9.2 and are now having issues with Pheobus,
> namely that it crashes due to "insufficient memory for the Java Runtime Environment to continue".
The text of the message mentions "or process/resource limits reached".
Have you investigated RLIMIT_NPROC?
(although I may be getting confused about OS as you mention both OSX and Windows below)
> We are using v4.7.2-SNAPSHOT.  We've done a number of tests, and the summary of results are:
> WORKS OK:
> SLF7 + openjdk-11.0.17.0.8-2       on VM with 3GB, 3 CPU
> SLF7 + openjdk-11.0.17.0.8-2       on VM with 2GB, 2 CPU
> Alma 9 + openjdk-11.0.20.0.8-3    on VM with 3GB, 3 CPU displaying on Mac + XQuartz
> This one is strange.  It works on a Mac but not on MS Windows.  The only obvious difference seen with 'xdpyinfo' is that XQuartz
> on the Mac has a WINDOWS-DRI extension which Cygwin-X does not have.
> DOESN'T WORK:  fails with "There is insufficient memory for the Java Runtime Environment to continue."
> Alma 9 + openjdk-11.0.20.0.8-3    on VM with 3GB,  3 CPU displaying on Windows+Cygwin-X and on another linux box with x-forwarding
> Alma 9 + openjdk-17.0.8.0.7-2     on VM with 3GB,  3 CPU displaying on Windows+Cygwin-X and on another linux box with x-forwarding
> Alma 9 + openjdk-11.0.20.0.8-3    on VM with 16GB, 3 CPU displaying on Windows+Cygwin-X
> A screenshot of what happens immediately before Pheobus crashes after attempting to open a 3rd bob file:
> Is there some configuration that we need that we are not providing?  Our java options are:
> NOTE: Picked up JDK_JAVA_OPTIONS:  -DCA_DISABLE_REPEATER=true -Dnashorn.args=--no-deprecation-warning -Djdk.gtk.verbose=false -Dprism.forceGPU=true -Dlogback.configurationFile=/home/train/epics-tools/setup/settings/logback.xml -Dorg.csstudio.javafx.rtplot.update_counter=false
> 2023-08-31 11:13:13 SEVERE [org.phoebus.product.Launcher] Default charset is US-ASCII instead of UTF-8.
> 2023-08-31 11:13:13 SEVERE [org.phoebus.product.Launcher] Add    -D"file.encoding=UTF-8"    to java command line or JAVA_TOOL_OPTIONS
> 2023-08-31 11:13:13 INFO [org.phoebus.product.Launcher] Loading settings from /usr/local/epics/Config/CSS/Phoebus/settings.ini
> 2023-08-31 11:13:13 INFO [java.util.prefs] Created user preferences directory.
> 2023-08-31 11:13:13 WARNING [javafx] Unsupported JavaFX configuration: classes were loaded from 'unnamed module @6a906827'
> 2023-08-31 11:13:15 SEVERE [org.phoebus.framework.preferences] No default setting for preference org.phoebus.applications.alarm.logging.ui/rawFiltering
> 2023-08-31 11:13:15 WARNING [org.phoebus.ui.application.PhoebusApplication] Cannot load state from /export/home1/hanlet/.phoebus/memento, no such file
> 2023-08-31 11:13:25 SEVERE [org.phoebus.framework.preferences] No default setting for preference org.phoebus.applications.update/gitlab_api_url
> 2023-08-31 11:13:25 SEVERE [org.phoebus.framework.preferences] No default setting for preference org.phoebus.applications.update/gitlab_project_id
> 2023-08-31 11:13:25 SEVERE [org.phoebus.framework.preferences] Reading Preferences: Java system property or Environment variable'$(arch)' is not defined
> 2023-08-31 11:13:25 SEVERE [org.phoebus.framework.preferences] No default setting for preference org.phoebus.applications.update/gitlab_token
> 2023-08-31 11:13:50 SEVERE [org.phoebus.ui.application.PhoebusApplication] UI Freezeup
> I know little about java, so I don't know how severe the SEVERE warnings are.
> Attached is the logging.properties file.
> Many thanks,
> Pierrick
> Pierrick Hanlet
> Fermi National Accelerator
> Accelerator Front End Controls
> +1-630-840-5555 -- lab
> +1-312-687-4980 -- mobile
> "Whether you think you can or think you can't, you're right" -- Henry Ford
pheobus on AlmaLinux9 Pierrick M Hanlet via Tech-talk
Re: pheobus on AlmaLinux9 Michael Davidsaver via Tech-talk
Prev: Re: EPICS Ethercat motor driver Torsten Bögershausen via Tech-talk
Next: Static Database Access 顾月良 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: pheobus on AlmaLinux9 Michael Davidsaver via Tech-talk
Next: PVA gateway status PV monitoring Ha, Kiman via Tech-talk
