See
https://github.com/ControlSystemStudio/phoebus/wiki/Display-Builder-Compatibility#text-update:
“Some BOY displays misused Text Update widgets as labels by leaving the pv_name empty and instead directly configuring the text.”
If you want to display the value of a PV, use a text update widget and configure it’s PV name.
If you have a number but want to display that as a label, add suitable mbbi records to the IOC to convert the states into lables, and then you’re back to simply displaying that PV in a text update widget.
Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of neu lzf via Tech-talk <Tech-talk at aps.anl.gov>
Date: Monday, September 11, 2023 at 8:36 AM
To: tech-talk at aps.anl.gov <Tech-talk at aps.anl.gov>
Subject: [EXTERNAL] Question about text update widget is not updating text problem for phoebus
I use binary SNS version
of Phoebus and have two questions to consult you:
1) I want to display "OK" text in Text Update Widget according to pv1 value if it is not equal to zero. I write embedded python script for phoebus as follows:
from org.csstudio.opibuilder.scriptUtil import PVUtil
pv0=PVUtil.getDouble(pvs[0])
pv1=PVUtil.getDouble(pvs[1])
widget.setPropertyValue("text","OK")
widget.setPropertyValue("text",str(format(pv0,".3f")))
the above script works well for CSS, while for phoebus it doesn't update text content to "OK" if pv1 is not equal to zero. I have no idea what the problem of the script is.
2) The script for phoebus doesn't show any error message if there is a syntax error in it, I wonder if I miss configuration to turn this function on and where
to turn this function on.
Any help will be appreciated and thank you very much in advance.
- Re: Question about text update widget is not updating text problem for phoebus neu lzf via Tech-talk
- Question about text update widget is not updating text problem for phoebus neu lzf via Tech-talk
RE: PyDevice device module compile error with linux-arm Pearson, Matthew via Tech-talk
<2023>
<2023>
ANJ, 11 Sep 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
