1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: CA Client program throwed "pthread_create error"
To: "tech-talk" <[email protected]>
Date: Wed, 13 Sep 2023 10:41:12 +0800
Hello EPICS community!
I wrote a simple multithread CA client program like this:
 //some pvs_res init
 ca_context_create(ca_enable_preemptive_callback);
 my_ca_context = ca_current_context();
 for(unsigned int i = 0; i < pvs_cnt; i++) //pvs_cnt = 4000;
     ca_create_channel(pvs_res[i], NULL, NULL, CA_PRIORITY_DEFAULT, &pvs_res[i].pv_chid);
 ca_status = ca_pend_io(1.0);
Everything was OK in Windows compiled with Visual Studio 2017. But when I compiled it in Linux, the program crashed when exec this line:
The last message showed in the terminal was:
 pthread_create error Invalid argument
 errlogInit failed
EPICS base is 7.0.7 release version with default configure.
My linux environment:
 ~ uname -a
Linux debian 6.1.0-6-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.15-1 (2023-03-05) x86_64 GNU/Linux
~ ldd --version
ldd (Debian GLIBC 2.36-9) 2.36
~ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/12/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none:amdgcn-amdhsa
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian 12.2.0-14' --with-bugurl=file:///usr/share/doc/gcc-12/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++,m2 --prefix=/usr --with-gcc-major-version-only --program-suffix=-12 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-plugin --enable-default-pie --with-system-zlib --enable-libphobos-checking=release --with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch --disable-werror --enable-cet --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none=/build/gcc-12-bTRWOB/gcc-12-12.2.0/debian/tmp-nvptx/usr,amdgcn-amdhsa=/build/gcc-12-bTRWOB/gcc-12-12.2.0/debian/tmp-gcn/usr --enable-offload-defaulted --without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 12.2.0 (Debian 12.2.0-14)
Any help will be appreciated.
Thank you very much!
Prev: Re: scalcout and calc yielding different results Mooney, Tim M. via Tech-talk
Next: Re: scalcout and calc yielding different results Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: scalcout and calc yielding different results Marco A. Barra Montevechi Filho via Tech-talk
Next: how to configure compiler version timesir via Tech-talk
