On 9/13/23 10:43 AM, Soliday, Robert T. via Tech-talk wrote:
I set the version in configure/CONFIG
CC=/usr/local/gcc-11.3.0/bin/gcc
CCC=/usr/local/gcc-11.3.0/bin/g++
AR=/usr/local/gcc-11.3.0/bin/gcc-ar -rc
CPP = /usr/local/gcc-11.3.0/bin/gcc -x c -E
RANLIB=/usr/local/gcc-11.3.0/bin/gcc-ranlib
That would work (if you put those at the end of the file) as long as
you are only building for the host architecture. If you will need to
be able to cross-build for IOCs of other architectures and/or
operating systems the settings for your particular host target
should be added to the file
configure/os/CONFIG_SITE.Common.<host-arch> or
configure/os/CONFIG_SITE.<host-arch>.<host-arch> where
<host-arch> would be linux-x86_64 for 64-bit Linux on Intel or
amd64 hosts. Configuring builds for any cross architectures is more
complicated.
- Andrew
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of timesir via Tech-talk
Sent: Wednesday, September 13, 2023 10:38 AM
To: epics community <[email protected]>
Subject: how to configure compiler version
Dear all,
If there are three versions of gcc installed on the OS, how should I
set up epics to use a particular version of gcc. Right now I find that
/usr/bin/gcc is always used.
Complexity comes for free, Simplicity you have to work for.
- Re: how to configure compiler version timesir via Tech-talk
- how to configure compiler version timesir via Tech-talk
- RE: how to configure compiler version Soliday, Robert T. via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
