1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: how to configure compiler version
To: epics community <[email protected]>
Date: Thu, 14 Sep 2023 00:08:37 +0800
Is it possible to modify the compiler version only when compiling a specific package is. I.e., the compiler version in the Makefile for a specific package overrides the version in the epics-base.
Andrew Johnson <[email protected]> 于2023年9月13日周三 23:57写道:
On 9/13/23 10:43 AM, Soliday, Robert T. via Tech-talk wrote:
I set the version in configure/CONFIG
CC=/usr/local/gcc-11.3.0/bin/gcc
CCC=/usr/local/gcc-11.3.0/bin/g++
AR=/usr/local/gcc-11.3.0/bin/gcc-ar -rc
CPP = /usr/local/gcc-11.3.0/bin/gcc -x c -E
RANLIB=/usr/local/gcc-11.3.0/bin/gcc-ranlib
That would work (if you put those at the end of the file) as long as you are only building for the host architecture. If you will need to be able to cross-build for IOCs of other architectures and/or operating systems the settings for your particular host target should be added to the file configure/os/CONFIG_SITE.Common.<host-arch> or configure/os/CONFIG_SITE.<host-arch>.<host-arch> where <host-arch> would be linux-x86_64 for 64-bit Linux on Intel or amd64 hosts. Configuring builds for any cross architectures is more complicated.
- Andrew
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of timesir via Tech-talk
Sent: Wednesday, September 13, 2023 10:38 AM
Subject: how to configure compiler version
Dear all,
  If there are three versions of gcc installed on the OS, how should I
set up epics to use a particular version of gcc. Right now I find that
/usr/bin/gcc is always used.
Complexity comes for free, Simplicity you have to work for.
Re: how to configure compiler version Pierrick M Hanlet via Tech-talk
Re: how to configure compiler version Michael Davidsaver via Tech-talk
how to configure compiler version timesir via Tech-talk
RE: how to configure compiler version Soliday, Robert T. via Tech-talk
Re: how to configure compiler version Andrew Johnson via Tech-talk
Prev: Re: how to configure compiler version Andrew Johnson via Tech-talk
Next: Re: how to configure compiler version Pierrick M Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
