1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: PVA connection problem
From: Ignacio Arriagada via Tech-talk <[email protected]>
To: [email protected]
Date: Thu, 14 Sep 2023 17:52:19 -0300
Hello Tech-talk,
I'm running into an issue trying to communicate between 2 VMs using pva. In VM1 I have a softIOC running with PVAccess enabled with the following standard configuration.
epics> pvasr
pvAccess Server v7.1.6
Active configuration (w/ defaults)
EPICS_PVAS_INTF_ADDR_LIST = 0.0.0.0:5075
EPICS_PVAS_BEACON_ADDR_LIST =
EPICS_PVAS_AUTO_BEACON_ADDR_LIST = YES
EPICS_PVAS_BEACON_PERIOD = 15
EPICS_PVAS_BROADCAST_PORT = 5076
EPICS_PVAS_SERVER_PORT = 5075
EPICS_PVAS_PROVIDER_NAMES = QSRV
epics> pval
testSCS:TX
testSCS:RX
testSCS:gcbTx
testSCS:page0
epics>
From VM2, I'm trying to execute pvget to get the testSCS:gcbTx. I have set the address using EPICS_PVA_ADDR_LIST, but this doesn't work, with the following debug log
$ pvget testSCS:gcbTx
2023-09-14T17:27:50.066 Creating datagram socket from: 0.0.0.0:54661.
2023-09-14T17:27:50.066 Broadcast address #0: 192.168.1.140:5076. (unicast)
2023-09-14T17:27:50.066 Broadcast address #1: 192.168.1.255:5076. (not unicast)
2023-09-14T17:27:50.066 Broadcast address #2: 192.168.122.255:5076. (not unicast)
2023-09-14T17:27:50.066 Setting up UDP for interface 192.168.1.138/255.255.255.0, broadcast 192.168.1.255, dest <none>.
2023-09-14T17:27:50.066 Creating datagram socket from: 192.168.1.138:5076.
2023-09-14T17:27:50.066 Creating datagram socket from: 192.168.1.255:5076.
2023-09-14T17:27:50.066 Setting up UDP for interface 192.168.122.1/255.255.255.0, broadcast 192.168.122.255, dest <none>.
2023-09-14T17:27:50.066 Creating datagram socket from: 192.168.122.1:5076.
2023-09-14T17:27:50.066 Creating datagram socket from: 192.168.122.255:5076.
2023-09-14T17:27:50.066 Creating datagram socket from: 224.0.0.128:5076.
2023-09-14T17:27:50.066 Local multicast enabled on 127.0.0.1/224.0.0.128:5076.
2023-09-14T17:27:50.066 Sending 59 bytes 0.0.0.0:54661 -> 192.168.1.140:5076.
2023-09-14T17:27:50.066 Sending 59 bytes 0.0.0.0:54661 -> 192.168.1.255:5076.
2023-09-14T17:27:50.067 Sending 59 bytes 0.0.0.0:54661 -> 192.168.122.255:5076.
2023-09-14T17:27:50.296 Sending 59 bytes 0.0.0.0:54661 -> 192.168.1.140:5076.
2023-09-14T17:27:50.296 Sending 59 bytes 0.0.0.0:54661 -> 192.168.1.255:5076.
2023-09-14T17:27:50.296 Sending 59 bytes 0.0.0.0:54661 -> 192.168.122.255:5076.
2023-09-14T17:27:50.754 Sending 59 bytes 0.0.0.0:54661 -> 192.168.1.140:5076.
2023-09-14T17:27:50.754 Sending 59 bytes 0.0.0.0:54661 -> 192.168.1.255:5076.
2023-09-14T17:27:50.754 Sending 59 bytes 0.0.0.0:54661 -> 192.168.122.255:5076.
2023-09-14T17:27:51.670 Sending 59 bytes 0.0.0.0:54661 -> 192.168.1.140:5076.
2023-09-14T17:27:51.670 Sending 59 bytes 0.0.0.0:54661 -> 192.168.1.255:5076.
2023-09-14T17:27:51.670 Sending 59 bytes 0.0.0.0:54661 -> 192.168.122.255:5076.
^CtestSCS:gcbTx 2023-09-14T17:27:52.545 UDP socket 0.0.0.0:0 closed.
2023-09-14T17:27:52.545 UDP Client Rx (0) 0.0.0.0:54661 <- <Ukn Addr Type>
2023-09-14T17:27:52.545 UDP socket 192.168.1.138:5076 closed.
2023-09-14T17:27:52.545 UDP Client Rx (0) 192.168.1.138:5076 <- <Ukn Addr Type>
2023-09-14T17:27:52.546 UDP socket 192.168.1.255:5076 closed.
2023-09-14T17:27:52.546 UDP Client Rx (0) 192.168.1.255:5076 <- <Ukn Addr Type>
2023-09-14T17:27:52.546 UDP socket 192.168.122.1:5076 closed.
2023-09-14T17:27:52.546 UDP Client Rx (0) 192.168.122.1:5076 <- <Ukn Addr Type>
2023-09-14T17:27:52.546 UDP socket 192.168.122.255:5076 closed.
2023-09-14T17:27:52.546 UDP Client Rx (0) 192.168.122.255:5076 <- <Ukn Addr Type>
2023-09-14T17:27:52.546 UDP socket 224.0.0.128:5076 closed.
2023-09-14T17:27:52.547 UDP Client Rx (0) 224.0.0.128:5076 <- <Ukn Addr Type>
I can get it to work by disabling the firewall (systemctl stop firewalld). Then I get the following
2023-09-14T17:26:43.289 Creating datagram socket from: 0.0.0.0:37793.
2023-09-14T17:26:43.289 Broadcast address #0: 192.168.1.140:5076. (unicast)
2023-09-14T17:26:43.289 Broadcast address #1: 192.168.1.255:5076. (not unicast)
2023-09-14T17:26:43.289 Broadcast address #2: 192.168.122.255:5076. (not unicast)
2023-09-14T17:26:43.289 Setting up UDP for interface 192.168.1.138/255.255.255.0, broadcast 192.168.1.255, dest <none>.
2023-09-14T17:26:43.289 Creating datagram socket from: 192.168.1.138:5076.
2023-09-14T17:26:43.289 Creating datagram socket from: 192.168.1.255:5076.
2023-09-14T17:26:43.290 Setting up UDP for interface 192.168.122.1/255.255.255.0, broadcast 192.168.122.255, dest <none>.
2023-09-14T17:26:43.290 Creating datagram socket from: 192.168.122.1:5076.
2023-09-14T17:26:43.290 Creating datagram socket from: 192.168.122.255:5076.
2023-09-14T17:26:43.290 Creating datagram socket from: 224.0.0.128:5076.
2023-09-14T17:26:43.290 Local multicast enabled on 127.0.0.1/224.0.0.128:5076.
2023-09-14T17:26:43.290 Sending 59 bytes 0.0.0.0:37793 -> 192.168.1.140:5076.
2023-09-14T17:26:43.290 Sending 59 bytes 0.0.0.0:37793 -> 192.168.1.255:5076.
2023-09-14T17:26:43.290 Sending 59 bytes 0.0.0.0:37793 -> 192.168.122.255:5076.
2023-09-14T17:26:43.290 UDP Client Rx (59) 192.168.1.255:5076 <- 192.168.1.138:37793
2023-09-14T17:26:43.290 UDP Client Rx (59) 192.168.122.255:5076 <- 192.168.122.1:37793
2023-09-14T17:26:43.291 UDP Client Rx (53) 0.0.0.0:37793 <- 192.168.1.140:60446
2023-09-14T17:26:43.291 Connecting to PVA server: 192.168.1.140:5075.
2023-09-14T17:26:43.291 Opening socket to PVA server 192.168.1.140:5075, attempt 1.
2023-09-14T17:26:43.292 Socket connected to PVA server: 192.168.1.140:5075.
2023-09-14T17:26:43.292 Acquiring transport to 192.168.1.140:5075.
2023-09-14T17:26:43.298 Connected to PVA server: 192.168.1.140:5075.
2023-09-14T17:26:43.298 UDP Client Rx (53) 0.0.0.0:37793 <- 192.168.1.140:60446
testSCS:gcbTx <undefined>              0 INVALID DRIVER UDF
2023-09-14T17:26:43.303 Releasing TCP transport to 192.168.1.140:5075.
2023-09-14T17:26:43.303 TCP socket to 192.168.1.140:5075 is to be closed.
2023-09-14T17:26:43.303 UDP socket 0.0.0.0:0 closed.
2023-09-14T17:26:43.303 UDP Client Rx (0) 0.0.0.0:37793 <- 192.168.1.140:60446
2023-09-14T17:26:43.303 UDP socket 192.168.1.138:5076 closed.
2023-09-14T17:26:43.303 UDP Client Rx (0) 192.168.1.138:5076 <- <Ukn Addr Type>
2023-09-14T17:26:43.303 UDP socket 192.168.1.255:5076 closed.
2023-09-14T17:26:43.303 UDP Client Rx (0) 192.168.1.255:5076 <- 192.168.1.138:37793
2023-09-14T17:26:43.303 UDP socket 192.168.122.1:5076 closed.
2023-09-14T17:26:43.303 UDP Client Rx (0) 192.168.122.1:5076 <- <Ukn Addr Type>
2023-09-14T17:26:43.303 UDP socket 192.168.122.255:5076 closed.
2023-09-14T17:26:43.303 UDP Client Rx (0) 192.168.122.255:5076 <- 192.168.122.1:37793
2023-09-14T17:26:43.303 UDP socket 224.0.0.128:5076 closed.
2023-09-14T17:26:43.303 UDP Client Rx (0) 224.0.0.128:5076 <- <Ukn Addr Type>
From VM2, caget works without issues, with and without the firewall enabled
$ caget testSCS:gcbTx
testSCS:gcbTx                  0
$ cainfo testSCS:gcbTx
testSCS:gcbTx
    State:            connected
    Host:             192.168.1.140:5064
    Access:           read, write
    Native data type: DBF_LONG
    Request type:     DBR_LONG
    Element count:    1
The firewall config for the VMs is the following
VM1:
$ sudo firewall-cmd --list-all
public (active)
  target: default
  icmp-block-inversion: no
  interfaces: enp0s3
  sources:
  services: cockpit dhcpv6-client ssh
  ports: 8888/tcp 8888/udp 5064/tcp 5065/tcp 5064/udp 5065/udp
  protocols:
  forward: no
  masquerade: no
  forward-ports:
  source-ports:
  icmp-blocks:
  rich rules:
VM2:
public (active)
  target: default
  interfaces: enp0s3
  sources:
  protocols:
  forward: no
  masquerade: no
  forward-ports:
  source-ports:
  icmp-blocks:
  rich rules:
For security reasons I need to be able to find a configuration for the firewall that works with PVAccess. Any idea what I could be missing?
Re: PVA connection problem Ralph Lange via Tech-talk
Re: PVA connection problem Michael Davidsaver via Tech-talk
Re: [EXTERNAL] PVA connection problem Kasemir, Kay via Tech-talk
Prev: Re: ADSpinnaker Grasshopper 3 NIR crashes on acquire Mark Rivers via Tech-talk
Next: Re: ADSpinnaker Grasshopper 3 NIR crashes on acquire Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: PVA connection problem Ralph Lange via Tech-talk
