1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: areadetector, extra IOC only for plugins
From: Pete Jemian via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Tue, 19 Sep 2023 13:02:44 -0500
Perhaps a screen view might help (using caQtDM screens).
https://anl.box.com/s/ws3w1rihw1xj3rup3xxyodsl0hwmn3lf
On 9/19/2023 10:19 AM, Heinz Junkes via Tech-talk wrote:
I would be happy if someone here could enlighten me 😉
 Two IOCs are used in this example:
* `bdpad:` ADSimDetector with image and PVA plugins enabled
* `bdppva:` pvaDriver with image plugin enabled
The image data is created by the ADSimDetector IOC cam and published by both CA
(image plugin) and PVA (PVA plugin).  Publishing involves enabling the respective
plugins on the IOC.  Within each IOC, plugins receive image data (NTNDArray) via
an asyn port.  Between IOCs, image data is received as PVs (either ca or PVA).
The pvaDriver IOC subscribes to the PVA PV from the ADSimDetector IOC. The PVA
is where the pvaDriver IOC cam gets its image data.
Other area detector plugins are optional for this example.
Bottom left screen shows simulated sawtooth image generated by the ADSimDetector.
Next screen to the right shows the image as received by the pvaDriver IOC.
On the far right, the pvaDriver IOC "cam1" configuration shows, in the "pvaDriver"
section of the screen, where to enter the (PVA) PV name to be received as input.
This is the PV name published by the ADSimDetector IOC.
Pete R. Jemian, Ph.D.                 <jemian at anl.gov>
Beam line Controls and Data Acquisition (BC, aka BCDA)
Advanced Photon Source,    Argonne National Laboratory
Argonne, IL  60439                    630 - 252 - 3189
      Education is the one thing for which people
         are willing to pay yet not receive.
areadetector, extra IOC only for plugins Heinz Junkes via Tech-talk
Prev: Re: areadetector, extra IOC only for plugins Mark Rivers via Tech-talk
Next: Re: Streamdevice reads weird 1 byte null data Hyung Jin Kim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Re: areadetector, extra IOC only for plugins Heinz Junkes via Tech-talk
Next: Use sscan with transform record coordinate motion Abdalla Ahmad via Tech-talk
ANJ, 20 Sep 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
