# PI E-518 motor controller is connected via Ethernet,
# at IP address 192.168.2.31, TCP port 50000
drvAsynIPPortConfigure("PIE518", "192.168.2.31:50000", 0, 0, 0)
asynSetTraceMask(PIE518,-1,0x21) # 0x09, 0x03, 0x01
asynSetTraceIOMask(PIE518,-1,0x1) # 0x02, 0x01, 0x00
# PI E-518 uses GCS(General Command Set). PI_GCS2_CreateController parameters:
PI_GCS2_CreateController("PIE518-1P", "PIE518", 1, 0, 0, 100, 1000)
2023/09/20 15:02:55.434 read from PIE518: (c) 2016 Physik Instrumente (PI) GmbH & Co. KG, E-518.I3, 119053229, 3.70
PIasynAxis::PIasynAxis() 0: A
2023/09/20 15:02:55.455 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_KP_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_KI_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_KFF_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_NTCHFR1_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_NTCHFR2_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_NTCHRJT1_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_NTCHRJT2_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_NTCHBDWDT1_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_NTCHBDWDT2_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBKP_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBKI_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBKFF_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBNTCHFR1_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBNTCHFR2_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBNTCHRJT1_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBNTCHRJT2_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBNTCHBDWDT1_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBNTCHBDWDT2_A to list 0, too many parameters
dbLoadRecords("/blsw/13a/software/epics/3.14.12.5/support/motor-R6-11/db/PI_Support.db","P=27a:,R=PIE518-1P:,PORT=PIE518-1P,ADDR=0,TIMEOUT=1")
dbLoadRecords("/blsw/13a/software/epics/3.14.12.5/support/asyn-4-26/db/asynRecord.db", "P=27a:,R=PIE518-1P:Asyn,PORT=PIE518,ADDR=0,OMAX=256,IMAX=256")
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 94 in list 0, bad index
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 95 in list 0, bad index
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 96 in list 0, bad index
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 97 in list 0, bad index
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 98 in list 0, bad index
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 99 in list 0, bad index
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 100 in list 0, bad index
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 101 in list 0, bad index
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 102 in list 0, bad index
## EPICS R3.14.12.5 $Date: Tue 2015-03-24 09:57:35 -0500$
## EPICS Base built Nov 6 2017
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 94 in list 0, bad index
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 95 in list 0, bad index
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 96 in list 0, bad index
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 97 in list 0, bad index
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 98 in list 0, bad index
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 99 in list 0, bad index
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 100 in list 0, bad index
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 101 in list 0, bad index
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 102 in list 0, bad index
