Hi Pete,
I believe the “system” command is still available, but for security reasons it is disabled by default. This document:
https://epics.anl.gov/base/R3-16/2-docs/AppDevGuide.pdf
says on page 261:
Send command_string to the system command interpreter for execution. This command is present only if some application database definition
file contains registrar(iocshSystemCommand) and if the system provides a suitable command interpreter (vxWorks does not).
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of
Siddons, David via Tech-talk
Sent: Wednesday, September 20, 2023 2:05 PM
To: tech-talk at aps.anl.gov
Subject: Starting an app from the ioc st.cmd
How can I make the IOC boot script also start an external program? THere used to be an iocsh command "system", but it doesn't seem to exist anymore. ALternativerly, how can I export the PV header
info ($(P), $(R) ) so an external program can read them?
I have a few systems running the same IOC with different PV headers, and I want to allow the external code to pick up the current device's headers so I don't have to manually change them.
Probably a dumb question, but I can't see how to do it
- Re: Starting an app from the ioc st.cmd Kasemir, Kay via Tech-talk
- Re: Starting an app from the ioc st.cmd Michael Davidsaver via Tech-talk
- Starting an app from the ioc st.cmd Siddons, David via Tech-talk
<2023>
<2023>
ANJ, 20 Sep 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
