1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: Starting an app from the ioc st.cmd
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, "Siddons, Peter" <siddons at bnl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 20 Sep 2023 19:33:48 +0000
At least with epics 7 there’s a “system.dbd” in base that you can include in your app’s dbd.
“softIoc” and “softIocPVA” do include it.
It contains “registrar(iocshSystemCommand)”, so same difference in the end.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
Date: Wednesday, September 20, 2023 at 3:13 PM
To: Siddons, Peter <siddons at bnl.gov>, tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] RE: Starting an app from the ioc st.cmd
Hi Pete,
I believe the “system” command is still available, but for security reasons it is disabled by default. This document:
https://epics.anl.gov/base/R3-16/2-docs/AppDevGuide.pdf
says on page 261:
Send command_string to the system command interpreter for execution. This command is present only if some application database definition file contains registrar(iocshSystemCommand) and if the system provides a suitable command interpreter (vxWorks does not).
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Siddons, David via Tech-talk
Sent: Wednesday, September 20, 2023 2:05 PM
To: tech-talk at aps.anl.gov
Subject: Starting an app from the ioc st.cmd
How can I make the IOC boot script also start an external program? THere used to be an iocsh command "system", but it doesn't seem to exist anymore. ALternativerly, how can I export the PV header info ($(P), $(R) ) so an external program can read  them?
I have a few systems running the same IOC with different PV headers, and I want to allow the external code to pick up the current device's headers so I don't have to manually change them.
Probably a dumb question, but I can't see how to do it 🙂
Pete.
Starting an app from the ioc st.cmd Siddons, David via Tech-talk
RE: Starting an app from the ioc st.cmd Mark Rivers via Tech-talk
Prev: RE: Starting an app from the ioc st.cmd Mark Rivers via Tech-talk
Next: Re: Starting an app from the ioc st.cmd Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
ANJ, 20 Sep 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
