1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: No rule to make target '../../../lib/linux-x86_64/libstream.a' error.
From: Peter Pitfield via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 21 Sep 2023 11:45:04 -0700
Thank you for the quick reply.
Here is the Getting Started walkthrough:
I realize this could have been caused by the error 'sCalcoutRecord.h: No such file or directory' when I try to build the asyn library, since it seems like the asyn library had not been built properly when I tried to build the stream library.
I fixed this error by commenting out the line CALC=$(SUPPORT)/calc-3-7-4 in asyn/configure/RELEASE.
However, I am now receiving the error 'vxi11core.h:9:10: fatal error: rpc/rpc.h: No such file or directory' instead, and I do not know how to fix it.
Thank you for helping,
Peter
On Thu, Sep 21, 2023 at 11:04 AM Mark Rivers <rivers at cars.uchicago.edu> wrote:
Hi Peter,
That error means that the build system could not find the stream library.  From the -I in the g++ command it looks like you have defined the location of stream as /home/raphael/EPICS/support/stream/StreamDevice in your configure/RELEASE file.  Is there a libstream.so in /home/raphael/EPICS/support/stream/StreamDevice/lib/linux-x86_64?  If not then perhaps you have not built stream yet or you have specified the wrong path in configure/RELEASE?
The name of your IOC sounds like you may be using LabJack devices.  If so you may be interested to know that there is an EPICS LabJack module with pretty complete support for the T4, T7, T7-PRO, and T8.
https://github.com/epics-modules/labjack
Can you send a more exact URL to the Getting Started walkthrough?  I didn’t see if browsing epics-controls.org.
Cheers,
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Peter Pitfield via Tech-talk
Sent: Thursday, September 21, 2023 12:39 PM
To: tech-talk at aps.anl.gov
Subject: No rule to make target '../../../lib/linux-x86_64/libstream.a' error.
Hello everyone,
I'm a new user to EPICS, and an undergraduate student in math and physics. I'm using Ubuntu 22 and have installed epics. I'm attempting to add the stream and asyn packages using the Getting Started walkthrough on epics-controls.org. I am getting the error in the subject line. The full error message looks like this:
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE        -DUSE_TYPED_RSET  -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/raphael/EPICS/support/asyn/include   -I/home/raphael/EPICS/support/stream/StreamDevice/include -I/home/raphael/EPICS/epics-base/include/compiler/gcc -I/home/raphael/EPICS/epics-base/include/os/Linux -I/home/raphael/EPICS/epics-base/include        -c ../labjackIOCMain.cpp
make[3]: *** No rule to make target '../../../lib/linux-x86_64/libstream.a', needed by 'labjackIOC'.  Stop.
make[3]: Leaving directory '/home/raphael/EPICS/IOCs/labjackIOC/labjackIOCApp/src/O.linux-x86_64'
make[2]: *** [/home/raphael/EPICS/epics-base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[2]: Leaving directory '/home/raphael/EPICS/IOCs/labjackIOC/labjackIOCApp/src'
make[1]: *** [/home/raphael/EPICS/epics-base/configure/RULES_DIRS:85: src.install] Error 2
make[1]: Leaving directory '/home/raphael/EPICS/IOCs/labjackIOC/labjackIOCApp'
make: *** [/home/raphael/EPICS/epics-base/configure/RULES_DIRS:85: labjackIOCApp.install] Error 2
Thank you so much for your help.
Peter
RE: No rule to make target '../../../lib/linux-x86_64/libstream.a' error. Mark Rivers via Tech-talk
No rule to make target '../../../lib/linux-x86_64/libstream.a' error. Peter Pitfield via Tech-talk
Prev: RE: No rule to make target '../../../lib/linux-x86_64/libstream.a' error. Mark Rivers via Tech-talk
Next: RE: No rule to make target '../../../lib/linux-x86_64/libstream.a' error. Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
ANJ, 21 Sep 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
