On 9/22/23 01:19, Jörn Dreyer via Tech-talk wrote:
Hello,
I recently run into a problem with a client code that throws strange errors at
me during runtime:
CA client library tcp recieve thread terminating due to C++ exception
"epicsMutex::invalidMutex()"
"invalidMutex" indicates a coding error. (NULL dereference, memory corruption,
use-after-free, ...)
Hopefully you can reproduce this error quickly, I would suggest running in GDB and
setting a breakpoint on the exception class ctor 'epicsMutex::invalidMutex::invalidMutex()'.
Then look for signs of corruption.
epicsMutex pthread_mutex_lock failed: error epicsMutexOSDLock
epicsThread: Unexpected C++ exception "epicsMutex::invalidMutex()" with type
"N10epicsMutex12invalidMutexE" in thread "CAC-TCP-send" at XXX
terminate called after throwing an instance of 'epicsMutex::invalidMutex()'
what(): epicsMutex::invalidMutex()
After that my program crashes. Can anybody shed some light on that. It was
running all good until two days ago when this error started to pop up when a
connection to a PV is made.
Jörn Dreyer
- Strange error in EPICS client program Jörn Dreyer via Tech-talk
Re: Monitor timeouts with asyn/StreamDevice, and issues in DRTO with UDP Zimoch Dirk via Tech-talk
Synapps CAMAC debian Rute Mendes via Tech-talk
<2023>
"I/O Intr" record not processing boj via Tech-talk
<2023>
