1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: "I/O Intr" record not processing
Date: Fri, 22 Sep 2023 12:15:14 +0200
Dear all
I am implementing a very simple serial communication IOC, where each call to the instrument returns all relevant values.
The StremDevice manual suggests to use "I/O Intr" record processing.
The database, protocol and startup file is given below.
The "V" record is processed as expected, but the "Time" record is never updated. If i enable "SCAN, "5 second""  for the "Time" record this also works so the protocol is returning valid (using the same out string as for the "V" record.
Am I overlooking something here , or is there anyway to debug why the record is not processed?
I am running the 3.15 branch of EPICS , under linux using a soft ioc
Thanks in advance for any hints
Bo
** Database file: ENG110_test.db:
record(ai, "$(BASE):V") {
  field(DTYP, "stream")
  field(INP, "@ENG110_test.proto GetV asynstream1")
  field(SCAN, "5 second")
record(ai, "$(BASE):Time") {
  field(INP, "@ENG110_test.proto GetTime asynstream1")
  field(SCAN, "I/O Intr")
** Protocol file ENG110_test.proto:
ExtraInput = Ignore;
GetV {
  out "\x02\x05\x95\x61\x03";
  in "%*9r%#4R";
GetTime {
        in "%*9r%*#4R%*#4R%*#4R%*#4R%*#4R%*#4R%#4R";
** Startup file
dbLoadDatabase("/usr/lib/epics/dbd/stream-Ioc.dbd",0,0)
stream_Ioc_registerRecordDeviceDriver(pdbbase)
#Specify the TCP endpoint and give your 'bus' an arbitrary name eg. "asynstream1".
drvAsynSerialPortConfigure("asynstream1", "/dev/ttyUSB0",0,0,0)
asynSetOption("asynstream1",-1,"baud","9600")
asynSetOption("asynstream1",-1,"bits","8")
asynSetOption("asynstream1",-1,"parity","none")
asynSetOption("asynstream1",-1,"stop","1")
asynSetOption("asynstream1",-1,"clocal","Y")
asynSetOption("asynstream1",-1,"crtscts","N")
## Load record instances for 8 channel module
dbLoadRecords("ENG110_test.db","BASE=IntLab2:ENG110")
Re: "I/O Intr" record not processing Érico Nogueira Rolim via Tech-talk
Prev: Strange error in EPICS client program Jörn Dreyer via Tech-talk
Next: Re: "I/O Intr" record not processing Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Strange error in EPICS client program Michael Davidsaver via Tech-talk
