Hi Mark,
You are right, of course, and I found the place in the program code tonight as well:
The error is generated by NDArray.cpp:
"NDArray.cpp" line 224
/** Calls NDArrayPool::release() for this object; decreases the reference count for this array. */
int NDArray::release()
const char *functionName = "NDArray::release";
if (!pNDArrayPool) {
printf("%s: WARNING, no owner\n", functionName);
return(ND_ERROR);
return(pNDArrayPool->release(this));
Unfortunately I don't understand why pNDArrayPool doesn't exist?
NDArray::NDArray()
: referenceCount(0), pNDArrayPool(0), pDriver(0),
uniqueId(0), timeStamp(0.0), ndims(0), dataType(NDInt8),
dataSize(0), pData(0)
Your reference to memory corruption is of course good. I run the software on a M2 (aarch64). Possibly this leads to the problem.
My first "quick shot" to mutexes was guided by the error message "no owner”. I have had problems in the past with mutexes
that were released from from a different thread than the one that had taken the mutex.
"Mutexes have ownership, unlike semaphores. Only the thread that locked a mutex, (that is, the owner of the mutex), should unlock it.”
e
Danke Heinz
> On 27. Sep 2023, at 23:35, Mark Rivers <rivers at cars.uchicago.edu> wrote:
> Hi Heinz,
>> NDArray::release: WARNING, no owner
> That message means that NDArray.pNDArrayPool is 0. That could be a memory corruption problem. What leads you to think that it might be a mutex problem?
> Mark
> -----Original Message-----
> From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Heinz Junkes via Tech-talk
> Sent: Wednesday, September 27, 2023 8:30 AM
> To: Heinz Junkes via Tech-talk <tech-talk at aps.anl.gov>
> Subject: Running area detector simulator IOC on OS X aarch64 (M2) , segmentation fault
> Hello,
> I am trying to test on a new MAC with M2 processor areadetector.
> I was able to build it and start a simulator IOC. But when I start the simulator camera I get a segmentation fault. I haven't searched further for the error and wanted to ask here first if someone has alrerady seen this (and maybe solved it).
> epics> dbpf 13SIM1:cam1:Acquire 1
> DBF_STRING: "Acquire"
> ./start_epics: line 2: 31835 Segmentation fault: 11 ../../bin/darwin-aarch64/simDetectorApp st.cmd.darwin
> I guess it has something to do with Apple's lack of (limited) support for POSIX mutexes?
> Danke Heinz
smime.p7s
Description: S/MIME cryptographic signature
- Re: Running area detector simulator IOC on OS X aarch64 (M2) , segmentation fault Mark Rivers via Tech-talk
- Running area detector simulator IOC on OS X aarch64 (M2) , segmentation fault Heinz Junkes via Tech-talk
- RE: Running area detector simulator IOC on OS X aarch64 (M2) , segmentation fault Mark Rivers via Tech-talk
<2023>
2025
<2023>
2025
