Hi Mark,
I see LightField is compiled with /clr and I think this may be leading to the warning. An
epicsThreadId is defined as a pointer to a “struct epicsThreadOSD”
https://github.com/epics-base/epics-base/blob/60fa2d31da2deaaa89636b4a1f5b852efe0b2699/modules/libcom/src/osi/epicsThread.h#L108
and this is returned by epicsThreadCreate() which is used in the lightfield code. The epicsThreadOSD structure is not defined in a
public header on windows, which doesn’t normally matter as the native pointer is not meant to be dereferenced in public code, but as per
https://learn.microsoft.com/en-us/cpp/error-messages/tool-errors/linker-tools-warning-lnk4248?view=msvc-170 I think the linker is unsure whether it could be a CLR type or a native type hence the warning message you see. If you changed the typedef in epicsThread.h
to be:
typedef void *epicsThreadId;
I think that may remove the warning as it has broken the link to the undefined epicsThreadOSD type
Freddie
On Behalf Of Mark Rivers via Tech-talk
Sent: 30 September 2023 22:05
To: [email protected]
Subject: Re: Warning when building ADLightField for windows-x64 with VS2022
LightField.obj : warning LNK4248: unresolved typeref token (01000038) for 'epicsThreadOSD'; image may not run
Does anyone know what causes this warning, and if it is serious?
It does not appear to be serious, because the application seems to run fine. But I am still interested to know what might be causing that warning.
Sent: Wednesday, September 27, 2023 12:37 PM
To: [email protected] <[email protected]>
Subject: Warning when building ADLightField for windows-x64 with VS2022
Folks,
I am getting a warning for an unresolved typeref in epicsThreadOSD when building ADLightField for windows-x64 with Visual Studio 2022 Community Edition.
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release -MACHINE:X64 -out:LightField.dll -implib:LightField.lib LightField.obj
J:/epics/support/areaDetector-3-12-1/ADCore/lib/windows-x64/ADBase.lib J:/epics/support/asyn-4-44-2/lib/windows-x64/asyn.lib J:/epics/support/areaDetector-3-12-1/ADCore/lib/windows-x64/ntndArrayConverter.lib H:/epics/base-7.0.7/lib/windows-x64/nt.lib H:/epics/base-7.0.7/lib/windows-x64/pvDatabase.lib
H:/epics/base-7.0.7/lib/windows-x64/pvAccess.lib H:/epics/base-7.0.7/lib/windows-x64/pvData.lib J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/netCDF.lib J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/tiff.lib J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/xml2.lib
J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/NeXus.lib J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/hdf5.lib J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/hdf5_hl.lib J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/bitshuffle.lib
J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/blosc.lib J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/szip.lib J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/zlib.lib J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/jpeg.lib
H:/epics/base-7.0.7/lib/windows-x64/dbRecStd.lib H:/epics/base-7.0.7/lib/windows-x64/dbCore.lib H:/epics/base-7.0.7/lib/windows-x64/ca.lib H:/epics/base-7.0.7/lib/windows-x64/Com.lib gdi32.lib oleaut32.lib
Creating library LightField.lib and object LightField.exp
- Warning when building ADLightField for windows-x64 with VS2022 Mark Rivers via Tech-talk
- Re: Warning when building ADLightField for windows-x64 with VS2022 Mark Rivers via Tech-talk
Tech Talk Mailing List Abdalla Ahmad via Tech-talk
<2023>
2025
2026
Phoebus EDM autoconvert issue with a button widget Lucas Russo via Tech-talk
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
